Connecting Multiple Servos to Single Battery Pack
Posted: Wed May 06, 2015 12:26 pm
by JosephProject
I wish to connect 17 Servos to a single NiMH Battery Pack. I would like to avoid soldering the wires together. Are there any types of connectors which I could use to connect all the Servos to the Battery? The Servos have a Standard Connector.
Thank you.
Joseph
Re: Connecting Multiple Servos to Single Battery Pack
Posted: Wed May 06, 2015 12:57 pm
by Laurens-wuyts
Posted: Wed May 06, 2015 2:43 pm
by BMS Doug
Laurens-wuyts wrote:You can use two of these:
https://www.servocity.com/html/servo_power_boards.html
Laurens
or make your own from stripboard and male header strip.
Posted: Wed May 06, 2015 3:01 pm
by JosephProject
Thank you very much to both of you for your quick responses.
Regards,
Joseph
Posted: Thu May 14, 2015 3:46 am
by LinuxCircle
You could use a breadboard, and attach the battery to the side positive / ground rail.
Or you could also use external boards:
http://www.linuxcircle.com/2013/02/11/r ... on-boards/
