winkleink
Converting voltages from 3.3V to 5V
Wed Jul 04, 2012 10:30 am
I was looking for a simple way to convert the Raspberry Pi voltages form 3.3V to 5V for interfacing and came across the following.
4-Way Bi-directional Logic Level Converter
http://www.hobbytronics.co.uk/logic-level-4
Would using one of these enable 4 of the lines to become bi-directional with buffering to sort out the current or have I missed something.
Albert.
Twitter:Winkleink
Google+: Winkleink
pygmy_giant
Re: Converting voltages from 3.3V to 5V
Wed Jul 04, 2012 4:04 pm
Hi - I just ordered something similar for connecting the Flexel data aquisition module. The Flexel is I2C but designed for the Arduino which is 5v so I need to step it down as the PIs GPIO are not 5v tollerent. I think you can get away with jus using 2x BSS138 if the slave device is open collector but mine has integral pull-up resistors so need an arrangement with further resistors also. I think all such devices are much of a muchness and do this:
I'm not sure if the BSS138 solution is the best for you - I have seen other more complex solutions by googling 'logic level convert 3.3 5v I2c' etc... I tend to google via pictures and look for schematics - saves a lot of time.
Ostendo ignarus addo scientia.
