Mailserver with Postfix/Dovecot
Posted: Tue Jun 26, 2012 6:41 am
by wtrdk
Hi all,
I'd like to set up a mailserver for personal use. I've done this before on Ubuntu server, so I have a little experience.
When I want to install Postfix not all packages are available. When I look at sources.list I only see one repository. Are there any additional repositories I can use for Debian Wheezy which contain Postfix/Dovecot?
Thanks in advance!
Re: Mailserver with Postfix/Dovecot
Posted: Tue Jun 26, 2012 7:36 am
by symes
I want to run a mail server as well, haven't had enough time with my pi to sort it yet, having yet to find a complete install set.
I found a post in which a pi was running Citadel, but the repository is missing a couple of files and won't install completely - just don't have the time now to find them or install alternatives...
I think this application (mail server with webmail access) is an ideal subject for a pi so I hope it can be sorted soon.
Posted: Mon Jul 23, 2012 6:01 pm
by Goss1982
Hi guys
My friend and I, managed to get an email server working on Debian using the following setup guides;
https://help.ubuntu.com/community/Postfix
https://help.ubuntu.com/community/Dovecot
Bothh of these worked perfectly, unfortunately having just moved to Raspbian the dovecot config setup has changed and we are currently having issues.
If you are on the original debian image, I suggest the above. If you on Raspbian, any help would be required sorting the SSL config out!!
Posted: Sat Jul 28, 2012 8:30 pm
by dove
I just started with the dovecut based solution on the Debian 6 image.
The installation is not finished yet but I'll post when I make progress.
Posted: Fri Aug 17, 2012 5:18 pm
by Goss1982
Anyone had any joy with dovecot. With the old debian image it ran version 1.x without too much bother. Since moving to the rapbian image dovecot 2.x installs instead and can't get the thing to authenticate at all let alone with SSL.
If anyone has this working, it would be great to hear.
Have managed a botch togther using courier, but again no ssl for some reason. Suspect a postfix config issue but cant see it???
Posted: Fri Aug 24, 2012 9:12 am
by dove
No joy yet. That's not dovecots fault. The HD I want to use has not been delivered yet.
Posted: Fri Aug 24, 2012 7:12 pm
by Lirex
my mailserver with postfix, dovecot, roundcube and fetchmail runs perfectly on my raspberry pi.
only managesieve fails momentarily. :roll: the system is raspbian.
Posted: Sat Aug 25, 2012 8:52 am
by Elect
Postfix is easily installable, take this as a starter
http://piserv.nl/blog/index.php/postfix ... pberry-pi/
Posted: Mon Aug 27, 2012 2:06 am
by nicknml
I found this guide useful in spite of it being for CentOS:
http://www.linuxmail.info/
Posted: Sat Sep 01, 2012 7:23 pm
by dove
So finally my recipe:
I set up the dovecot in Debian 6.0 by executing the following three lines:
sudo bash
apt-get install dovecot-imapd dovecot-pop3d
echo "mail_location = maildir:/home/%u/Maildir" > /etc/dovecot/conf.d/30-mailLoc.conf
Well, I needed more lines to find out that what I needed were those.
I hardened security slightly by setting up a new ssh-key:
sudo rm /etc/ssh/ssh_host_* && sudo dpkg-reconfigure openssh-server
and changing pis password.
For a quick test I can recommend the small example at the end of:
http://docs.python.org/library/imaplib.html
dovecot -n prints the actual configuration.
Don't worry about activating encrypted connections. By default both SSL and non SSL versions are activated.
Hope this helps!
Posted: Mon Sep 17, 2012 9:35 pm
by nicknml
Is there an easy way to get sasl to work? I've tried to get it to work, but no luck. Are there any special packages that need to be installed?
Posted: Tue Sep 18, 2012 10:57 am
by nicknml
I got it working, turns out it was a stupid simple mistake that I was making.
Posted: Mon Apr 22, 2013 9:03 am
by gondman
@Lirex or @All:
I run Postfix Dovecot and Fetchmail on Ubuntu. I wanted to install it on a PI but i have some problems. On Ubuntu i installed the package "dovecot-postfix" which integrated dovecot sasl in postfix. On the pi these package are not available. Do you configured sasl for Dovecot and Postfix manually? How does it works?
Posted: Mon May 27, 2013 1:23 pm
by linuxcampaign
This tutorial should help setting up an IMAP mail server with dovecot, postfix and fetchmail on Raspberry Pi:
http://linuxcampaign.com/imap-mail-server.html
Posted: Mon Aug 12, 2013 5:14 pm
by dylantje
Sorry, for the off topic
Is there anyone who has a web interface for Postfix.
http://www.postfix.org/addon.html
There are several, but I can not get working.
I hope someone can help me. Further
Thank you.
Dylan
