Citadel email limit of 5 users??
Posted: Fri Mar 28, 2014 3:44 pm
by sttempelman
Hello all
After a successful installation of Citadel in a Raspberry Pi i was ready to use it as my main mail server at home. So i added the four names of our family. Everything works fine for these 4 users + the admin.
Now the problem: i wanted to add a sixth user for mail list-, advertising- etc. emails.
To add a 6th user wasn’t a problem.
To sent an email (within de Citadel web interface) works fine as well.
But to SENT a mail TO this 6th email address is not possible. Not even with an email address and an email client outside the home environment. Believe me, i tried and checked everything more then twice!! But i still receive 550 error messages directly after pushing the send button.
The sixth user is permitted to send internet mail and is an #4 Network user, just like the other ’normal’ users.
Is there a limitation in Citadel on an Raspberry Pi for a maximum of 5 users???
Thanks in advance for any tip, which solve this problem:
Stan
Re: Citadel email limit of 5 users??
Posted: Fri Mar 28, 2014 7:23 pm
by DougieLawson
Having taken a quick look at
http://www.ducky-pond.com/posts/2012/Ju ... el-on-rpi/
http://www.citadel.org/doku.php/doku.ph ... tion:start
there don't appear to be any restrictions.
Point your web browser at the WebCit http server running on your RPi.
Posted: Sat Mar 29, 2014 10:13 am
by sttempelman
Hello DougieLawson
Thanks for your answer. I used the site from Duckypond for the installation of Citadel. It only says 'to make any users'. But that is not a problem. I can make as much users as i want. The problem is to mail to the 6th en up.
I know the second site as well. But i couldn’t find an answer to wy problem.
Again thanks en greetings: Stan
Posted: Sat Mar 29, 2014 11:55 am
by fbutler
Perhaps a silly question but have you double checked that the spelling of the user you created is correct?
Posted: Mon Mar 31, 2014 1:02 pm
by sttempelman
Hello all
At first i added new users by: 'Administration' -> 'Add, change, delete user accounts'. This didn't work as described above.
I solved the problem to add new user via 'Log in' -> 'New user? Register now'. Users added this way are 'mailable'.
Thanks for reading: Stan
