Real-Flashman
Raspberry Pi connect's to more distantly WiFi-AP
Wed Nov 06, 2013 1:48 pm
How do I get the Raspberry to only connect to one access point with a specific "BSSID" (MAC address) [?] , as there are multiple access points with the same SSID, but I want to prevent that it simply connects to a weaker signal than the one to which he really should only ever connect.
Thx in advance.
Jens
SirLagz
Re: Raspberry Pi connect's to more distantly WiFi-AP
Thu Nov 07, 2013 8:29 am
Knowing what distribution you're using would help, but I'm going to guess you're using Raspbian.
How are you currently configuring your WiFi ?
Real-Flashman
Thu Nov 07, 2013 4:20 pm
Hi, yes im using Raspbian, version 3.6.11+
Wifi is configured via /etc/network/interfaces-File:
auto lo
iface lo inet loopback
iface eth0 inet dhcp
allow-hotplug wlan0
auto wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa.config
iface default inet dhcp
/etc/wpa.config-File has this content:
network={
ssid="SSIDofServeralAccessPoints"
proto=RSN WPA
key_mgmt=WPA-PSK
pairwise=CCMP
group=CCMP
psk="GlobalPasswordOfTheSSIDNetwork"
More isn't configured up to the present.
SirLagz
Fri Nov 08, 2013 1:46 am
just add this line into wpa.conf after ssid
bssid=00:11:22:33:44:55
So end result should look like this
network={
proto=RSN WPA
key_mgmt=WPA-PSK
pairwise=CCMP
group=CCMP
Real-Flashman
Fri Nov 08, 2013 8:10 am
Superb!! ..it works :-D
plentiful thanks
