rasbeer
Apache2/PHP problem
Fri Apr 26, 2013 5:40 pm
I've been trying to follow along with the LAMP tutorial in "Learn Raspberry Pi with Linux".
It works & produces the "PHP credits" page with
<?php phpinfo(); ?>
in index.php.
But at the next stage (logging in to the PHP database, code highlighted in the link above) there's HTTP error 500. (The mySQL username, pw, database name etc are as given, and I think the HTTP error implies Apache/PHP isn't even getting as far as logging in to the database. I've also tried with 127.0.0.1, the Hostname given in the 'PHP credits' page mentioned above.)
Any ideas what might be causing this? :?
SimonSmall
Re: Apache2/PHP problem
Sat Apr 27, 2013 9:21 pm
The 500 error is a general error - i.e. something went wrong, but not the usual expected errors.
It could be an error in the PHP script or accessing the database. Whatever it is, it is happening on the server, and you need to fix it on the server, not the browser
The Apache logs should contain more details about the error
rasbeer
Sun Apr 28, 2013 8:03 am
Ah - thanks. So that would be the PHP Fatal error then :oops:
pi@rp1 /var/www $ tail -n 2 /var/log/apache2/error.log
[Sun Apr 28 07:30:43 2013] [error] [client 192.168.2.106] PHP Fatal error:  Class 'mysqli' not found in /var/www/index.php on line 10
[Sun Apr 28 07:30:44 2013] [error] [client 192.168.2.106] File does not exist: /var/www/favicon.ico
This is index.php, (line 10 starts with $mysqli) which I think is identical the the code from the book:
<html>
<head>
<title>Much Todo!</title>
</head>
<body>
<hr/>
<h1>Todo List</h1>
<hr/>
<?php
$mysqli = new mysqli('localhost', 'pi', 'raspberry', 'pi');
if ($mysqli->connect_error) {
    die('Connect Error (' . $mysqli->connect_errorno . ') '
        . $mysqli->connect_error);
<table>
<tr>
<th>Description</th>
<th>Owner</th>
<th>Due Date</th>
<th>Location</th>
<th>Importance</th>
<th>Creator</th>
</tr>
<?php
$result = $mysqli->query("SELECT * FROM todolist");
while($row = $result->fetch_assoc()){
    print "<tr>";
    print "<td>".$row["description"]."</td>";
    print "<td>".$row["owner"]."</td>";
    print "<td>".$row["date"]."</td>";
    print "<td>".$row["location"]."</td>";
    print "<td>".$row["importance"]."</td>";
    print "<td>".$row["creator"]."</td>";
    print "</tr>";
$mysqli->close();
</table>
</body>
</html>
I don't think it's a connection error, but I logged in to mysql manually to check:
pi@rp1 /var/www $ mysql -upi -p
Enter password: <raspberry>[
Welcome to the MySQL monitor.  Commands end with ; or \g.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> SHOW databases;
| Database           |
| information_schema |
| [b]pi[/b]                 |
| test               |
3 rows in set (0.07 sec)
