carled
RTL8188CUS and AP/hotspot mode
Wed Mar 20, 2013 3:04 pm
I'm baffled. I specifically went out and bought a nano wifi dongle with the RTL8188CUS chipset after seeing the forum posts on configuring and getting this working. lsusb says:
Bus 001 Device 003: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
I've gone through all the steps in there (using "make" and "make install") and yet as soon as I try debug mode for hostapd I get "l2_packet_init: socket(PF_PACKET): Operation not permitted" and "rtl871xdrv driver initialization failed". I even tried the supposedly working esrlabs image that is meant to work with the RTL8188CUS chipset and that yields exactly the same error messages.
The dongle works perfectly in client mode and connects to my wifi network without any problem whatsoever. Googling seems to return few results. Have I found a wifi dongle with the RTL8188CUS chipset that doesn't work?
It's this one: ebay usb dongle
carled
Re: RTL8188CUS and AP/hotspot mode
Wed Mar 20, 2013 11:22 pm
Hopeful bump - anyone got any idea please?
timmoore46
Thu Mar 21, 2013 7:46 am
The latest version of Raspbian ? with full updates, might help.
I've read somewhere it just works.
Tim
carled
Thu Mar 21, 2013 7:56 am
I already have 2013-02-09. :-(
Is there a more recent one?
Jessie
Thu Mar 21, 2013 3:24 pm
I tried to setup a hotspot with a belkin adapter based on a Realtek chipset, not exactly the same chipset you are using but Realtek none the less. Anyway I was unable to find drivers that supported the proper mode to host a hotspot. Unfortunately setting up a hotspot with a R Pi is still a PITA because most if not all of the dongles out there don't list their chipset on the box.
Jessie
Thu Mar 21, 2013 3:28 pm
If you type "iw list" what does it say?
carled
Thu Mar 21, 2013 3:33 pm
Jessie wrote:If you type "iw list" what does it say?
nl80211 not found
Jessie
Thu Mar 21, 2013 3:45 pm
Your adapter will not act as a hotspot. It's best to find another wireless adapter. Trying to make that one work will drive you nuts.
carled
Thu Mar 21, 2013 4:04 pm
Already got another one on the way with RALINK RT5370 chipset in it!
SirLagz
Fri Mar 22, 2013 2:17 am
Have you tried whats in this thread ? - http://www.raspberrypi.org/phpBB3/viewt ... 46&t=25921
My Blog - http://www.sirlagz.net
Visit my blog for Tips, Tricks, Guides and More !
WiFi Issues ? Have a look at this post ! http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=44044
Jessie
Fri Mar 22, 2013 4:56 am
SirLagz wrote:Have you tried whats in this thread ? - http://www.raspberrypi.org/phpBB3/viewt ... 46&t=25921
I don't know if the OP did, but I did. I spent some time fiddling around to try and make it work and only managed to get errors and segfaults. I just took my adapter back to the store and got another. I knew going into the build that it was going to be a pain so I made sure to buy from some place I didn't like that had a good return policy.
carled
Fri Mar 22, 2013 8:49 am
Yeah. Absolutely step by step. Twice in case I messed up! As it says in original post, just comes up with those errors. Also the esrlabs image that supposedly kicked it all off just results in the same thing too so it has to be that I've found a dongle that has the RTL8188CUS chipset and still doesn't work for whatever reason.
SirLagz
Fri Mar 22, 2013 1:53 pm
Ah well, that sucks.
The RT5370 works perfectly though so at least that will be easy for you :D
carled
Fri Mar 22, 2013 2:11 pm
SirLagz wrote:Ah well, that sucks.
Unless I've found one that also has an as-yet-unknown problem... :shock: Fingers crossed...
timmoore46
Fri Mar 22, 2013 6:08 pm
The Belkin F5D7050 is less than GBP 5.00 on UK Ebay and works a Dream on Ubuntu 12.04 out of the box. (It is possible to annoy the network settings so it won't play any more.) I've not tried it on RPi ot as a Hotspot.
:D
Tim
woodpecker
Sat Mar 23, 2013 5:05 pm
The Realtek 8188CUS chipset works fine as an AP but you need to use a modified hostapd, git clone then compile it from here:-
https://github.com/segersjens/RTL8188-hostapd
I have working config files if anyone needs them.
The Ralink RT5370 works fine with the standard hostapd and the nl80211 driver.
One chip I haven't got to work is the 8188SU
I'm also on the lookout for an 8188CUS chipset dongle with an SMA connector on it, anyone found one?
smshiera
Sun Mar 31, 2013 6:06 pm
woodpecker wrote:The Realtek 8188CUS chipset works fine as an AP but you need to use a modified hostapd, git clone then compile it from here:-
I'm a newbie to linux,I have this8188cus~chipset,,how can i make it work?
Can you give me a detailed installation ?
mattpitts74
Wed Apr 17, 2013 9:13 pm
Hi woodpecker
Could you post your working config files for the RTL8188CUS as I'm still struggling to get this working after swapping the hostapd
Cheers
sprintr
Fri Apr 19, 2013 9:36 pm
I got this to work but then switched to a different chipset...
Download the Unix (Linux) driver here: http://www.realtek.com.tw/downloads/dow ... loads=true
Go to /<wherever you uncompredd>/RTL8188C_8192C_USB_linux_v3.4.4_4749.20121105/wpa_supplicant_hostapd/
Unzip wpa_supplicant_hostapd-0.8_rtw_20120803.zip and go into directory wpa_supplicant_hostapd-08/ it creates
go to hostapd/ in that directory
$ make
$ sudo make install
then search for some on line manuals and how-to's for hostapd. Good number out there.
Have fun!
nsayer
Mon Mar 30, 2015 3:22 am
None of that seems to work anymore. With any of the thousands of precompiled special Realtek hostapd binaries available for download, all I get is
ioctl[SIOCSIWMODE]: Operation not permitted
Could not set interface to mode(3)!
Could not set interface to master mode!
rtl871xdrv driver initialization failed.
I think something changed in 3.18.7+ that screwed the pooch.
Check out my store! http://store.geppettoelectronics.com/
