System stats on a website?
Posted: Sat Feb 16, 2013 2:59 pm
by thejrcrafter
ive got a basic lamp server with lighttpd. i would like a /admin page that shows the amount of free ram on the pi, etc. how would i do this? would i need to somehow run a python script on the site?
thanks
Re: System stats on a website?
Posted: Sat Feb 16, 2013 3:39 pm
by randrade
Posted: Sat Feb 16, 2013 3:44 pm
by Keschy
you could try this:
http://derkev.in/rpisysinfoscript/
simply extract the zip file in your lighttpd-www-directory
Posted: Tue Feb 19, 2013 5:23 pm
by adream
the one i'm using here http://93.97.163.97:81/livestatus/status.php is quite good although the temp reading isn't working at the moment
Posted: Wed Feb 20, 2013 2:36 am
by 65coupei6
adream: Care to share the source of your live stats?
Posted: Wed Feb 20, 2013 3:44 am
by tonyhughes
The Server Utils section of Baked Raspberry Pi Mod will install phpsysinfo for you, which is shows a heap of detail.
I just used it to install phpsysinfo as a demo for you here:
http://www.tall.co.nz/phpsysinfo/index.php?disp=dynamic
I did note that there is no option but to install to /var/www/ so if you need it in a different directory, you will need to move it, or install it manually (just drag and drop the whole phpsysinfo dir if needed).
This will be fixed in the next release.
Posted: Wed Feb 20, 2013 4:41 am
by tonyhughes
And the most simple way I can think of to display the free ram is this:
Create a script:
nano ~/freeram.sh
then paste in:
#! /bin/bash
RAM=$(free -m)
echo $RAM > /var/www/freeram.txt
and save it (CTRL+X)
then type:
chmod +x ~/freeram.sh
then run:
~/./freeram.sh
Then you can just browse to http://www.domain.com/freeram.txt to see it.
There are a million ways to improve on this, and get the output looking good, or piped into another page somewhere.
Posted: Sat Feb 23, 2013 2:31 am
by sim_tcr
65coupei6 wrote:adream: Care to share the source of your live stats?
Here is it http://raspisimon.no-ip.org/livestatushelp.php
