thejrcrafter
System stats on a website?
Sat Feb 16, 2013 2:59 pm
ive got a basic lamp server with lighttpd. i would like a /admin page that shows the amount of free ram on the pi, etc. how would i do this? would i need to somehow run a python script on the site?
thanks
Keschy
Re: System stats on a website?
Sat Feb 16, 2013 3:44 pm
you could try this:
http://derkev.in/rpisysinfoscript/
simply extract the zip file in your lighttpd-www-directory
My Webpage: http://derkev.in
adream
Tue Feb 19, 2013 5:23 pm
the one i'm using here http://93.97.163.97:81/livestatus/status.php is quite good although the temp reading isn't working at the moment
http://212.159.76.122:81/serendipity/
65coupei6
Wed Feb 20, 2013 2:36 am
adream: Care to share the source of your live stats?
tonyhughes
Wed Feb 20, 2013 3:44 am
The Server Utils section of Baked Raspberry Pi Mod will install phpsysinfo for you, which is shows a heap of detail.
I just used it to install phpsysinfo as a demo for you here:
http://www.tall.co.nz/phpsysinfo/index.php?disp=dynamic
I did note that there is no option but to install to /var/www/ so if you need it in a different directory, you will need to move it, or install it manually (just drag and drop the whole phpsysinfo dir if needed).
This will be fixed in the next release.
tonyhughes
Wed Feb 20, 2013 4:41 am
And the most simple way I can think of to display the free ram is this:
Create a script:
nano ~/freeram.sh
then paste in:
#! /bin/bash
RAM=$(free -m)
echo $RAM > /var/www/freeram.txt
and save it (CTRL+X)
then type:
chmod +x ~/freeram.sh
then run:
~/./freeram.sh
Then you can just browse to http://www.domain.com/freeram.txt to see it.
There are a million ways to improve on this, and get the output looking good, or piped into another page somewhere.
sim_tcr
Sat Feb 23, 2013 2:31 am
65coupei6 wrote:adream: Care to share the source of your live stats?
Here is it http://raspisimon.no-ip.org/livestatushelp.php
Raspberry Pi Model B x 2, Raspberry Pi 2 x 2, Transcend 32GB Class 10, Transcend 16GB Class 10, Transcend 8GB Class 4, Custom 12V 1.5A (stepped down to 5.5V)
