How can I set a VPN up?
Posted: Sat Feb 02, 2013 2:48 pm
by randrade
I tried PPTP but it wouldn't work - my iPod touch said it couldn't connect to my Raspberry Pi.
What's the easiest way of setting a VPN up?
I have a Model B rev 2 Pi running Raspbian. It's running as DMZ host, so port forwarding isn't a problem.
Re: How can I set a VPN up?
Posted: Sat Feb 02, 2013 8:59 pm
by Spid
You need a Server and Client VNC solution.
On Apple iOS use VNC Viewer http://www.realvnc.com/products/ios/
If you have a fully updated Raspbian "Wheezy" Linux installed then you need the VNC Server installed, Tight VNC Server is available from the repository.
Posted: Sat Feb 02, 2013 9:58 pm
by randrade
Spid wrote:You need a Server and Client VNC solution.
Er... VPN, not VNC server.
Posted: Sun Feb 03, 2013 8:08 am
by Spid
Posted: Sun Feb 03, 2013 11:25 am
by randrade
That's for connecting to already existing VPNs. I want to create a VPN myself and connect to it.
Posted: Sun Feb 03, 2013 12:14 pm
by Thijxx
I always use this as a guide:
http://wellsb.com/post/29412820494/rasp ... vpn-server
Posted: Sun Feb 03, 2013 1:26 pm
by randrade
My pptpd-options file is never created when I install pptpd. Any ideas why?
Posted: Sun Feb 03, 2013 1:39 pm
by Spid
Posted: Sun Feb 03, 2013 4:26 pm
by randrade
*sigh* Do you know the difference between VPN and VNC?
Posted: Sun Feb 03, 2013 4:58 pm
by Cloudcentric
Posted: Sun Feb 03, 2013 5:15 pm
by Thijxx
randrade wrote:
Thijxx wrote:
Without any error during installation? And are you sure it isn't somewhere else or hidden?
