getting WiFi working
Posted: Tue Jan 08, 2013 4:45 pm
by Alan Johnstone
Hope this is the correct form for this
I am trying to get my Edimax USB adapter working.
sudo iwlist scan shows the wireless networks in my area so I think that means it is working
iwconfig shows
wlan0 unassociated Nickname:"<WIFI@REALTEK>"
Mode:Managed Frequency=2.412 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
my interfaces file is
auto lo
iface lo inet loopback
iface eth0 inet static
address 192.168.0.14
netmask 255.255.255.0
gateway 192.168.0.1
auto wlan0
iface wlan0 inet dhcp
wpa-conf /etc/wpa.conf
My wpa.conf file is
network={
ssid="NETGEAR"
proto=RSN
key_mgmt=WPA-PSK
pairwise=CCMP TKIP
group=CCMP TKIP
psk="Network Password"
The network password is correct
When I do Sudo ifup wlan0 i get
pi@raspberrypi ~ $ sudo ifup wlan0
ioctl[SIOCSIWAP]: Operation not permitted
ioctl[SIOCSIWENCODEEXT]: Invalid argument
Internet Systems Consortium DHCP Client 4.2.2
Copyright 2004-2011 Internet Systems Consortium.
All rights reserved.
For info, please visit https://www.isc.org/software/dhcp/
Listening on LPF/wlan0/80:1f:02:85:0c:31
Sending on LPF/wlan0/80:1f:02:85:0c:31
Sending on Socket/fallback
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 7
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 16
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 20
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3
No DHCPOFFERS received.
Unable to obtain a lease on first try. Exiting.
Failed to bring up wlan0.
What does it not like
Alan
Re: getting WiFi working
Posted: Tue Jan 08, 2013 7:29 pm
by Chapindad
try this:
           wpa-ssid="NETGEAR"
           wpa-psk="mypasscode"
This worked for me...
Posted: Tue Jan 08, 2013 8:04 pm
by Alan Johnstone
I tried the above and initially it said
sudo ifup wlan0
/etc/network/interfaces:12: option with empty value
so I retyped with spaces around the "=" signs
This allowed it to read the file but with the same result
sudo ifup wlan0
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 15
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10
DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11
Alan
Posted: Fri Jan 18, 2013 10:26 pm
by seeyounorth
Ok, so I struggled with this same issue for a while trying many different configs in wpa_supplicant.conf.
This config solved it for me:
ctrl_interface=DIR=/var/run/wpa_supplicant
ctrl_interface_group=0
update_config=1
network={
 ssid="wirelessname"
 psk="password"
 key_mgmt=WPA-PSK
I tried many other things like the "proto" and "group" but they must have confused the adapter further. My network is both WPA and WPA2 hosted by a Dlink DIR-655. Adapter is the EdiMax EW-7811Un. Raspberry "whezzy" 2012-12-16 and no USB hub. Also am running wireless mouse and keyboard. 700ma micro USB
Hope this helps anyone else with DHCPDISCOVER issues.
Posted: Sat Jan 19, 2013 3:08 pm
by Alan Johnstone
I almost do not believe it.
IT WORKS!
Thank you very much.
For the record to help anybody else:
I had got it working by using wicd which is a GUI interface
and that worked straight out of the box.
http://dembtech.blogspot.co.uk/2012/09/ ... ry-pi.html
To make absolutely sure that wicd was not somehow bringing up wlan0 I purge removed it.
WiFi Config on the GUI still does not work.
My /etc/network/interfaces file says:
auto lo
gateway 192.168.0.1
allow-hotplug wlan0
( I was using a static network address for plugged-in networking so the last 3 lines are the important ones. I believe that the last line is saying which file wpa_supplicant should take as the config file and that is the file I put the suggested code in.)
Posted: Thu Jun 02, 2016 4:32 pm
by theamazingdrew
I tried this and still couldn't get it to work. wpa_supplicant is a pain to deal with.
This following link, on the other hand, works beautifully.
http://askubuntu.com/questions/522842/u ... mmand-line
Posted: Sun Jun 26, 2016 3:59 pm
by carioca10
I have tried both and am getting the following message when typing the command sudo ifup wlan0:
/etc/network/interfaces:9: option with empty value
Ifup: couldn't read interfaces file "/etc/network/interfaces"
The WiFi Configuration wpa_gui does not list the WiFi adapter.
Any help is welcome.
Posted: Mon Jun 27, 2016 5:35 am
by Cancelor
I would recommend starting with a new install.
Then use the GUI to connect to the WiFi by clicking on the WiFi icon in the top right of the screen.
Edit:- Link added ... https://www.raspberrypi.org/documentati ... /README.md
Posted: Mon Jun 27, 2016 10:23 am
by carioca10
Thank you.
I will try it later and then post the results.
Posted: Tue Jun 28, 2016 3:03 am
by carioca10
I have updated and upgraded 2 times with no success.
Then I installed the new Raspbian Jessie version and partially solved.
Though I was not able to access the WiFi of the Amped REC10 Extended Wireless Network, which gives the best signal at the place where I want to access my RPi. Later I discovered I was typing a password which includes a letter which I was uncorrectly typing the "l" ( "L") in tiny letters, but I needed to type the "l" ("i") in capital letters.
PROBLEM SOLVED, :D !
