m0g
Re: Minecraft server - How To
Tue Jun 18, 2013 3:35 pm
AlexOlney wrote:I'm having terrible difficulty getting the server to be at a playable level, it can take nearly three seconds for a destroyed block to actually vanish and yield its item. I've run a few Minecraft servers before, but never on a Pi, so this is all very new to me.
I'm running 1.5.2 on a model B without using the GUI. I don't know if it makes a difference at all, but I'm using BerryBoot to launch Raspbian (latest version).
Any tips of help anyone could give would be enormously appreciated.
Thanks.
How long have you left your server running while seeing these results? When I first start up the world and try mining, I get the same results, however over about 3 minutes at the start of logging onto the server, this behavior went away. Try playing for a bit!
It also sounds like other people have had similar experiences (poor block behavior on initial login/server boot), so this is worth a try if you haven't tried waiting a bit yet!
Cowang4
Sat Jun 22, 2013 3:12 pm
m0g wrote: Is it at all possible for me to start the server in an SSH session and disconnect that session while the server still runs? I am aware that this likely would be tricky due to the way terminal sessions are run on linux, but I would prefer to be able to start the server and leave it running without ever needing to remote desktop into the raspberry pi or leaving an SSH session connected. I was hoping there would be a CLI option to run the process as detached and that that would work, but I couldn't find any information on it.
Yeah, look above a few posts for the link to a thread that describes how to use Screen. Its a terminal multiplexer, which basically means it does exactly what you want it to "disconnect the ssh session and still have the server run"
heres that link: http://www.raspberrypi.org/phpBB3/viewt ... 86#p329986
noob
Mon Jul 01, 2013 1:15 pm
i just downloaded java with apt-get, but now i don't know how to open it
bretth
Sun Jul 07, 2013 11:22 pm
I have tried this tutorial countless times and troubleshooted in every way I can think, but every time I get caught when I execute the command:
sudo /opt/jdk1.8.0/bin/java -version
I receive the error:
sudo: unable to execute /opt/jdk1.8.0/bin/java: No such file or directory
I would really appreciate if someone could help me with this.
Anon10W1z
Wed Jul 17, 2013 12:21 am
11) Unfortunately, we can't wget the official Java VM package from Oracle, so you will need to download the package to your computer and send it via SSH (use WinSCP for Windows) to /home/pi. Download link: http://jdk8.java.net/fxarmpreview/index.html
Actually, you can use the following command on the Pi without an SFTP client:
wget http://download.java.net/jdk8/archive/b98/binaries/jdk-8-ea-b98-linux-arm-vfp-hflt-10_jul_2013.tar.gz?q=download/jdk8/archive/b98/binaries/jdk-8-ea-b98-linux-arm-vfp-hflt-10_jul_2013.tar.gz -O jdk-8-ea-b98-linux-arm-vfp-hflt-10_jul_2013.tar.gz
You can change the name of the downloaded archive by changing the text after the -O option
Anon10W1z
Wed Jul 17, 2013 4:45 pm
bretth wrote:I have tried this tutorial countless times and troubleshooted in every way I can think, but every time I get caught when I execute the command:
Are you sure you followed the steps correctly? Let me simplify them a little.
1. ssh into the pi (optional)
2. type in
sudo raspi-config
set overclock to 900 mhz (for performance)
3. go to advanced options -> memory split and set it to 16
4. select finish, restart the pi
5. set up the static ip
6. open port 25565 on the router
7. type in the following commands (copy and paste them if using ssh)
sudo su
cd /home/pi
wget http://download.java.net/jdk8/archive/b98/binaries/jdk-8-ea-b98-linux-arm-vfp-hflt-10_jul_2013.tar.gz?q=download/jdk8/archive/b98/binaries/jdk-8-ea-b98-linux-arm-vfp-hflt-10_jul_2013.tar.gz -O java.tar.gz
mkdir -p /opt
tar zxvf java.tar.gz -C /opt
rm java.tar.gz
update-alternatives --install "/usr/bin/java" "java" "/opt/jdk1.8.0/bin/java" 1
update-alternatives --set java /opt/jdk1.8.0/bin/java
java -version
8. Go here to get the download link for your minecraft server version: http://www.mod-minecraft.org/minecraft-jar-download/
9. Download it via the following command
wget -O minecraft_server.jar linkToJAR
10. Run it via the following command:
sudo java -Xms128M -Xmx256M -jar /home/pi/minecraft_server.jar nogui
Long but simple.
jamesmd95
Thu Aug 15, 2013 4:27 pm
Looks like all our hard work has been borrowed and used here: http://www.raspberrypi.org/archives/4621 wouldn't care if it hadn't ended up here blahh :(
rapidwhois.uk | jmdawson.co.uk
EdwinJ85
Thu Aug 15, 2013 7:26 pm
I used a guide from the forums I quite clearly referenced....
Hello!
techis
Mon Aug 19, 2013 6:15 pm
Has anyone tried to use a usb wifi dongle to make a mobile minecraft server?
Thanks,
Techis
Dawn Wolf
Mon Aug 19, 2013 10:42 pm
I followed these instructions to the letter and only once got it to start the server. I wasn't happy with the amount of lag I was getting, so I tried Craftbukkit. That didn't seem to work, so I wiped the SD card (using SDFormatter) and reinstalled everything and followed the steps on page 1 as I did before.
After it's done starting the server, I get:
[WARNING] Can't keep up! Did the system time change, or is the server overloaded?
I noticed in the forum that it suggested ignoring this and just going right on ahead and trying to log in and I get the following:
java.net.SocketTimeoutException: Read timed out
        at java.net.SocketInputStream.socketRead0(Native Method)
        at java.net.SocketInputStream.read(SocketInputStream.java:150)
        at java.net.SocketInputStream.read(SocketInputStream.java:121)
        at java.io.FilterInputStream.read(FilterInputStream.java:133)
        at org.bouncycastle.crypto.io.CipherInputStream.nextChunk(Unknown Source)
        at org.bouncycastle.crypto.io.CipherInputStream.read(Unknown Source)
        at java.io.DataInputStream.readUnsignedByte(DataInputStream.java:288)
        at ex.a(SourceFile:178)
        at cn.i(SourceFile:249)
        at cn.c(SourceFile:17)
        at co.run(SourceFile:94)
If I don't attempt to log in immediately, after about a minute I get the following:
 [INFO] Stopping server
java.net.SocketException: Socket closed
        at java.net.PlainSocketImpl.socketAccept(Native Method)
        at java.net.AbstractPlainSocketImpl.accept(AbstractPlainSocketImpl.java:404)
        at java.net.ServerSocket.implAccept(ServerSocket.java:545)
        at java.net.ServerSocket.accept(ServerSocket.java:513)
        at ix.run(SourceFile:61)
I wiped the SD card and tried again, but got similar results. Anyone have any suggestions on how to fix this?
I'm using a Raspberry Pi Model B and a 16GB SD card with Raspbian wheezy.
omonster
mcserver
Tue Aug 20, 2013 9:36 am
EdwinJ85 do you have the compiled version of mcserver for download i want to know to have a simple creative server to run on the pi :D
please reply asap
lazarus78
Wed Aug 21, 2013 5:27 pm
randrade wrote:I also get lots of warnings, but I find the server runs fine when I'm on it. Very occasionally, when I go to a place very distant from the spawn area, I get read time out errors and lose connection ( problem downloading map chunks), but this usually goes away after trying again.
In regards to your first post, that means I might have to restart the server. I'll get on it!
This issue can be mitigated if you load the world up in single player and just go around generating chunks. This way the pi won't have to spend time generating which is the bulk of the processing time.
I think there may be applications out there to force generate chunks without you having to be in game.
This is all good news, I was wondering how well the Pi would handle this type of server because i want to run a Starmade server from it myself (Minecraft in space clone, in case you don't know) which isn't as intensive as Minecraft.
Bonestoo3995
Wed Aug 28, 2013 2:36 am
Whenever I do the last line to installing java:
I get: sudo: /opt/jdk1.8.0/bin/java: command not found :evil:
is there any reason that this is happening?
I am new, so any help would be appreciated.
PS. I am writing this on my PI :D
geohei
Fri Aug 30, 2013 3:41 pm
Hi.
Installed Minecraft server as shown on first page.
Hardware: RaspberryPi Bv2
Disto: 2013-07-26-wheezy-raspbian.zip
When starting server and waiting #3 minutes, top still shows 75-80% Java CPU load. As soon as son logs in (so, 1 user) Java goes up to #99%. The world builds up only very slowly on client side. After playing 1 minute or so, server crashes with segmentation fault.
What did I do wrong?
What do you need as additional info from my system/config to help?
Thanks,
lxbatty
Sun Sep 08, 2013 10:30 pm
r00x wrote:Nice one! I am preoccupied, alas. Experimenting with GPIO - going to see if I can't convince work to use Raspberry Pi's as nifty little demo boards for our displays :D
I want to pipe some server info (CPU, disk, mem usage - possibly graphs and text) to a small graphic display as a working example. :)
I too would love to see this if/when done. Just finished building my Minecraft Pi server, still working on tweaks to improve performance, but it's working.
flametail
Sun Sep 22, 2013 1:41 am
This thread has helped me so much for setting up my server, but I'm having an issue with lag and the game not loading. I am running a Spigot server with NoSpawnChunks, 800mHz overclock, 8gB class 10 SD, and java set to -Xms128M -Xmx400M. The error I eventually get is "Connection Lost Internal exception: Java.net.SocketTimeoutException: Read timed out"
I can post screens of settings if needed.
Lastly, I'm a noob when it comes to Linux (never messed with it until now but thankfully I have Google and awesome forums like this).
Hiradur
Sat Oct 12, 2013 5:33 pm
That is an error I encountered when I tried to run it on a Synology DS213j NAS. I spent many hours to find out what the problem is but never found a solution...
Hiradur
Wed Nov 06, 2013 1:30 pm
If anybody wondered if an Odroid-U2 would be a significant upgrade to a Raspberry Pi as a Minecraft server these videos might help you. I do the same benchmark in Minecraft on both of them.
Raspberry Pi: http://www.youtube.com/watch?v=miSRi_HwJxo
Odroid-U2: http://www.youtube.com/watch?v=Xt9izHoiVT4
acra
Sun Nov 10, 2013 4:27 pm
Is the class of SD Card important?
I've tried almost every Pi Minecraft Server tutorial out there, most recently the guide on HTG (here: www.howtogeek.com) but no matter what I try my server is unplayably laggy and in many cases corrupt.
Problems I'm experiencing include: crazy amounts of latency, blocks coming back, things flashing in/out of existance and frequent kicks.
I know a lot of people are able to run a server with a couple of people, so it seems strange I can't even host a server locally for one person to be stable on!
I'm running the Pi exactly per the article I linked, running in Turbo overclock.
RAM usage seems to rarely get above 50% and CPU bounces between 90% and 2%, with the average 'general running' of around 25%.
Because of this, I wonder if the SD card is my bottleneck? I'm using a Duracell Class 6, but no idea what read/write speed it is.
Any ideas?
Hiradur
Sun Nov 17, 2013 9:59 pm
SD card performance matters but in your case I think it might be the Pi generating new terrain or doing other CPU-intesive tasks. Use /timings in Minecraft to see what eats up your CPU.
Kahouse
Fri Nov 29, 2013 3:07 am
Hi I have set up my server on my pi, and i can connect to it with my internal ip. I have port forward 25565 on my router but i do not know how to find my external ip for my pi and i do not know if i need to open up any more ports. PLEASE HELP!!!
maarten2001
Tue Dec 10, 2013 9:37 am
Go to whatsmyip.org to see your external ip.
DejectedSyrup8
Wed Dec 11, 2013 2:41 am
Having a bit of trouble. I can get on my server using the 192.168 internal IP address from my pc. I have port forwarded my raspberry pi with 25565 but the only address that works is the internal. I have tried the external IP many different times and variations. I even tried using hamachi with no luck at all. Please help.
sajochi
Wed Dec 11, 2013 9:38 am
Hi Guys,
Im new to this sort of stuff.
Anyway... I can't open the tutorial page; http://kraftyhosting.eu/tutorial-raspbe ... er-update/
Or anything on that domain.
My internet browser (safari) tells me the server is not responding.
Wed Dec 11, 2013 9:49 am
sajochi wrote:Hi Guys,
it appears that the website is broken - You'll have to find instructions elsewhere.
