jamesmd95
Re: Minecraft server - How To
Thu Feb 07, 2013 6:45 pm
This is for the guy that just sent me a nasty email claiming this is not hosted on a raspberry pi!
http://picraft.zapto.org/
rapidwhois.uk | jmdawson.co.uk
r00x
Thu Feb 07, 2013 8:34 pm
jamesmd95 wrote:This is for the guy that just sent me a nasty email claiming this is not hosted on a raspberry pi!
What? No faith! :roll:
They probably don't know about your 1.15GHz overclock... or the SD card :lol: I'm getting some fancy UHS-1 100MB/s one myself! I don't suppose the Pi can support its speed but whatever happens, I know it will be faster than my current SD card.
I'm still working on finding my Pi's absolute maximum OC with bare minimum overvoltage. :D
jamesmd95
Thu Feb 07, 2013 8:42 pm
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
arm_freq=1150
# for more options see http://elinux.org/RPi_config.txt
gpu_mem=16
core_freq=450
sdram_freq=450
over_voltage=8
force_turbo=1
current_limit_override=1
Well there's my config - WILL VOID ANY WARRANTY haha
jamesmd95
Thu Feb 07, 2013 8:44 pm
Awesome! Mines 'only' 75MB/s gets 30mb/s on a DD test. Think the pi is restricting it.
r00x
Thu Feb 07, 2013 8:56 pm
Yeah it's undoubtedly the Pi. UHS is, if I recall, slightly different in terms of communication to 'normal' SDHC cards. These cards are backwards-compatible with the old protocols though. I have heard, on the grapevine, that the Pi's kernel module for SD is being modified for better UHS support, but don't quote me on that, I have no idea what I'm on about :D
Interesting config!
Mine currently looks more like:
gpu_mem=16
arm_freq=1000
core_freq=500
sdram_freq=600
over_voltage=3
If I try anything more aggressive it gets fairly unstable! Reducing core_freq and sdram_freq doesn't improve stability either. I haven't tried anything beyond over_voltage=6 (...yet). :D
jamesmd95
Thu Feb 07, 2013 9:00 pm
looks good! Just pushing mine to the limit! Seems faster again :)
arm_freq=1180
gpu_mem=16
core_freq=550
sdram_freq=600
over_voltage=8
force_turbo=1
over_voltage_sdram=6
avoid_pwm_pll=1
Think I will play minecraft now / Test Stability!
BTW I have heatsinks!
jamesmd95
Thu Feb 07, 2013 9:18 pm
Wow, all I can say right now haha. Its lag free, like totally lag free. To a point where I can set 20 blocks of TNT off without getting [WARNING] Can't keep up! Did the system time change, or is the server overloaded?
Seems that the core freq makes a HUGE difference. As well as the ram freq.
r00x
Thu Feb 07, 2013 9:58 pm
jamesmd95 wrote:Wow, all I can say right now haha. Its lag free, like totally lag free. To a point where I can set 20 blocks of TNT off without getting [WARNING] Can't keep up! Did the system time change, or is the server overloaded?
Core freq affects the L2 cache I believe - try ARM @ 1150MHz with Core freq @ 250MHz... slow as anything :D
SDRAM @ 600MHz seems the sweet spot for me :D
jamesmd95
Thu Feb 07, 2013 10:04 pm
Think I have mine stable now! Booting back up now, fancy some minecraft?
jamesmd95
Thu Feb 07, 2013 10:21 pm
Back up now, seems to be as good as its going to get. Have to get myself a 512MB pi soon
r00x
Thu Feb 07, 2013 10:23 pm
Nice one! I am preoccupied, alas. Experimenting with GPIO - going to see if I can't convince work to use Raspberry Pi's as nifty little demo boards for our displays :D
I want to pipe some server info (CPU, disk, mem usage - possibly graphs and text) to a small graphic display as a working example. :)
jamesmd95
Thu Feb 07, 2013 10:25 pm
That would be awesome! Have to see this when its done!
r00x
Thu Feb 07, 2013 10:55 pm
It'll look like crap probably, but I'll have a cool accessory for my Pi (useful for Minecrafting, as at a glance I can tell whether the Pi is overstressed) and will hopefully be working a lot more with Pi in the future. :)
jamesmd95
Thu Feb 07, 2013 11:16 pm
yeah :D 3 players online 2 using world edit...still no lag! I love my pi now! picraft.zapto.org:25565
randrade
Fri Feb 08, 2013 4:31 pm
I just moved my server to CraftBukkit 1.4.7 R0.1 and installed NoLagg and BKCommonLib. I'm also running the server with -Xms128M -Xmx408M. Let me know how it goes! randrade18.no-ip.org
edit: I ended up moving it back to the original MC server. It's faster.
jamesmd95
Fri Feb 08, 2013 5:41 pm
Craftbukkit is MUCH faster if you use nospawnchunks :)
randrade
Fri Feb 08, 2013 11:17 pm
jamesmd95 wrote:Craftbukkit is MUCH faster if you use nospawnchunks :)
So much better than the official MC server jar. Thanks!!
Also, guys, any ideas why the Pi sometimes does this while generating maps?
jamesmd95
Fri Feb 08, 2013 11:39 pm
Map generators use to much cpu for the pi :/
jamesmd95
Sat Feb 09, 2013 12:41 pm
Making a youtube video on the setup now, sorry to the people that were online. Its going to be down for 1 hour while I do this!
jamesmd95
Sat Feb 09, 2013 3:08 pm
Ok the server is backup now, had to make the video twice :( its uploading now. This will impact the server performance as I only have 1MB upload so my internet is being killed right now. Will post the video here soon :)
jamesmd95
Sat Feb 09, 2013 4:26 pm
tzj
Sun Feb 10, 2013 5:37 am
Loving the optimizing! ;)
http://www.themagpi.com <---- Checkout the MagPi
(The MagPi - Co-Founder)
Jayjader
Sun Feb 10, 2013 2:07 pm
For the first time world generating, you could also do that on a different computer, then copy and paste the world folder onto the pi...
That way you skip the "200 sec" time spent. On my Air, for example, when I start up a new world on my server, it only takes a couple secs - less than 7 in any case-. Of course, if time isn't an issue for you, you can disregard what I'm saying!
jamesmd95
Sun Feb 10, 2013 2:22 pm
Thats going to take just as long by the time you copy the world about! Still its probably a better way of doing things. Just wanted to keep the guide as simple as possible :) and 200 seconds is only a few minutes.
qwerty95
Sun Feb 10, 2013 10:34 pm
Hey I noticed that when I start the server via ssh it works, but when I exit the session the server stops. Is there a way to keep it running even when I quit out of the session?
