cooka
Updating Pis
Fri Jan 17, 2020 4:26 pm
:geek: Hi guys,
I have been using raspberry pis for a while but new to the forum. I was wondering if such a thing exists, I currently have 50+ rpis deployed at different sites, all they run is a chrome page in kiosk mode mainly. I would like to keep them all up to date etc without having to manually ssl/vnc into each one. Is there a way I can put them in one place, have them check in on my network and update them automatically?
Can i do anything with linux server?
Any suggestions welcome.
Maze_fr
Re: Updating Pis
Fri Jan 17, 2020 4:41 pm
Maybe you could put all your command line in one script and launch it in a cron ?
"Don't believe in forum signature quotations, they may be fakes" - Victor Hugo
jahboater
Re: Updating Pis
:geek: Hi guys,
You could have a simple script.
Something like:
ssh -t pi@host1 'sudo apt update && sudo apt upgrade -y'
ssh -t pi@host2 'sudo apt update && sudo apt upgrade -y'
ssh -t pi@host3 'sudo apt update && sudo apt upgrade -y'
ssh -t pi@host4 'sudo apt update && sudo apt upgrade -y'
DarrenHill
Re: Updating Pis
Sat Jan 18, 2020 8:31 am
You could also look at the unattended-upgrades apt module (via an apt-get install).
https://github.com/voxpupuli/puppet-unattended_upgrades
iznobe
Re: Updating Pis
Sat Jan 18, 2020 12:51 pm
Hi , it seems to me that it is the simplest way ;)
bensimmo
Re: Updating Pis
Sat Jan 18, 2020 1:41 pm
:geek: Hi guys,
Something like:
ssh pi@host1 'sudo apt-get update && sudo apt-get upgrade -y'
ssh pi@host2 'sudo apt-get update && sudo apt-get upgrade -y'
ssh pi@host3 'sudo apt-get update && sudo apt-get upgrade -y'
ssh pi@host4 'sudo apt-get update && sudo apt-get upgrade -y'
Great in theory, let down by some updates giving you information and waiting on your input.
(At which point I think you need the unattended thing posted ?)
DarkElvenAngel
Re: Updating Pis
Sat Jan 18, 2020 3:38 pm
I would suggest that if you have a server have each device check in and report some status and your server can instruct the kiosk to start a remote update if updates are available.
I'm presuming that these units are not somewhere you want to travel to and check on all the time and with this method you can test the update on a location close by and then have your field units update in blocks so if something doesn't work you can figure it out before it gets out of hand.
Having them check in would also let you know if a remote unit has gone down or there is some other technical issues on site that would need to be addressed.
The nature of how this works is up to you and it affords you greater control and knowledge of remote units without having to check on them. I would strongly recommend against having units update them selves when they want. You need to have control so if something goes wrong you know how to fix it before you have 50+ units all down because they have updated and broken something.
jahboater
Re: Updating Pis
Sat Jan 18, 2020 6:17 pm
bensimmo,
That's why I gave the -y option.
The man page says:
-y, --yes, --assume-yes
    Automatic yes to prompts; assume "yes" as answer to all prompts and run
    non-interactively. If an undesirable situation, such as changing a held package,
    trying to install a unauthenticated package or removing an essential package occurs
    then apt-get will abort. Configuration Item: APT::Get::Assume-Yes.
it is explicitly for non-interactive runs.
"We are in the beginning of a mass extinction, and all you can talk
about is money and fairy tales of eternal economic growth."
- Greta Thunberg
bensimmo
Re: Updating Pis
Sat Jan 18, 2020 8:24 pm
I think the -y only refer to, continue at the start, when it tells you there are so many updates etc and asks.do you really want to do this.
It does not 'yes' to blocking info screens*, which has happened a lot with some of the updates. I think SSH was one and another were a default whatsitsmejig is now different.
At least that's how it works for me. Though I use apt not apt-get more often now, unless I have to use apt-get.
*I think these come up and you have to q-quit out of them.
jahboater
Re: Updating Pis
Sat Jan 18, 2020 11:52 pm
I think its when a config file has been altered by the user.
So do I, apt is much nicer. But when I use it remotely over ssh I get this message:
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
I found the old apt-get worked fine.
I just tried the -t option for ssh and apt now works without the message.
ssh -t pi@host 'sudo apt update && sudo apt full-upgrade -y'
- Greta Thunberg
