SSH and directory access on rpi access point
Posted: Mon Sep 16, 2019 11:03 am
by tomcat25
Good afternoon,
I currently set up a RPI 3 as access point following various online procedure (standalone connection, no internet access). That works but , I would like to keep ability to remotely access command line and directory on this RPI and nothing I tried worked so far.
Would you have a proper link to share ?
Thank you for your help
Re: SSH and directory access on rpi access point
Posted: Tue Sep 17, 2019 5:42 am
by B.Goode
Welcome to the Raspberry Pi forums.
Good afternoon,
Raspberry Pi documentation concludes with:
If SSH is enabled on the Raspberry Pi access point, it should be possible to connect to it from another Linux box (or a system with SSH connectivity present) as follows, assuming the pi account is present:
Ref: https://www.raspberrypi.org/documentati ... s-point.md
