Doda
Connect raspberry pi with laptop via USB Ethernet Adapter
Thu Jul 18, 2019 2:20 am
Hello Folks!
I have not display for raspberry, just trying to use laptop for control and as a monitor for Raspberry pi.
My laptop connected to the Internet by Ethernet cable, and when I am going to connect raspberry pi (3 B+) to laptop, I should to disconnect Internet. I tried to use mobile internet for raspberry pi, but i had a connection errors, so I thought about another ways to use both: Internet and connect raspberry pi.
Thank you in advance!
https://www.amazon.com/dp/B0095EFXMC?aa ... USB31000S)
Something like this...
epoch1970
Re: Connect raspberry pi with laptop via USB Ethernet Adapter
Thu Jul 18, 2019 5:26 pm
Mhh. That device works on Pi.
Where do you want to connect the USB side? On the Pi, or on the PC?
Thu Jul 18, 2019 7:47 pm
Hello Folks!
Why can you not create a WiFi Hotspot on your Laptop ??
adieu
Doda
Fri Jul 19, 2019 1:03 am
Thank You for Reply!
I am using my Laptop`s Ethernet jack to connect to the internet. So I need another one to connect with raspberry pi)
Doda
Fri Jul 19, 2019 1:08 am
Hello Folks!
Thank You for reply!
It is hard to explain..) It`s a little strange situation.
I thought about it, but now i can not to use wi fi.
Also I tried to use mobile internet, but it I get some errors.
It was not so useful.
Doda
Fri Jul 19, 2019 1:17 am
Hello Folks!
I am sorry, I forgot.
It`s not raspberry pi zero. I am trying to use it for raspberry pi 3 B +.
I read that it`s compatible with raspberry pi zero.
Doda
Fri Jul 19, 2019 3:57 am
My purpose is to have an internet access for raspberry pi.
Fri Jul 19, 2019 6:05 am
Can't you just plug the Pi into your router?
Doda
Fri Jul 19, 2019 8:09 am
rpdom wrote:Can't you just plug the Pi into your router?
No, I can`t.
It is used in the company, I can use only for my laptop.
It`s not working with raspberry pi 3 +?
Or it`s better to buy pocket wifi?
Zanstel
Fri Jul 19, 2019 11:38 am
So ... are you asking us which ethernet dongle could you use in your laptop to connect to the raspberry?
At least you aren't using PoE, anyone which works with your laptop. Laptop/SO (Windows, Linux, MacOS...) problem, no for Raspberry.
Almost anyone.
epoch1970
Fri Jul 19, 2019 12:01 pm
Stop that nonsense. This thread deserves to be locked if not deleted outright.
A) If your company locks wifi and ethernet connections, ASK THEM before connecting any computer to the network.
B) If allowed to.
B.1) The obvious solution to daisy-chain via network a Pi to a laptop is to go wireless since 99% (please don't correct me) of laptops have both ethernet and wifi adapters built-in. Start ICS (Internet Connection Sharing), configure the Pi with the wifi details of the hotspot started by the laptop, and the laptop will take care of connecting the Pi.
B.2) If for some strange reason you can't use wifi, you need 2 ethernet adapters ON THE PC. Look for an adapter that will work with your PC, connect an ethernet cable between this adapter and the Pi, then start ICS as above.
End of message. And of thread, hopefully.
Fri Jul 19, 2019 12:39 pm
Hello Folks!
Yes, though you will need to set up Internet Connection in Windows.
adieu
pister
Sat Jul 20, 2019 12:57 pm
You can connect to ssh via usb straight into the pi zero.
On a mac you can literally use the following command
ssh pi@raspberrypi.local
You could then set up a network on your laptop and connect the pi. Once this is done you then would just install VNC and connect. https://www.raspberrypi.org/documentati ... ccess/vnc/
Doda
Sun Jul 21, 2019 11:57 pm
Almost anyone.
[/quote]
I am asking to know, is it working way to connect raspberry with laptop to use internet.
Thank you for your reply, have a nice day!
Doda
Sun Jul 21, 2019 11:58 pm
[/quote]
Thank you for reply, have a nice day!
Doda
Mon Jul 22, 2019 12:00 am
[/quote]
HawaiianPi
Mon Jul 22, 2019 1:59 am
No, I can`t.
If you are on a company network with security restrictions, don't mess with it! Connecting an unauthorised computer to their network without permission could compromise security and get you fired.
Either get permission and assistance from the company IT department, or use your Pi at home.
