burtav
rpi2 with 3 ethernet
Sat Jun 22, 2019 10:52 am
Hello Guys
can you point me towards how can I add 2 more ethernet ports to RPI 2 board?
USB nics are not an option
and we need an enclosure for this solution
any help will be appreciated
pcmanbob
Re: rpi2 with 3 ethernet
Sat Jun 22, 2019 11:25 am
If you don't want to use USB adapters then you could use a ENC28J60 Ethernet LAN Network Module it will only work a 10mbit/s but it will connect to the gpio pins
see this thread https://www.raspberrypi.org/forums/view ... p?t=131145
you might also want to look at this web site http://raspi.tv/2015/ethernet-on-pi-zer ... on-your-pi
as for an enclosure you will probably have to make your own or repurpose and existing enclosure of some type, as a very much doubt you will find and existing enclosure that caters for the extra LAN ports you want.
ejolson
Sat Jun 22, 2019 9:52 pm
Hello Guys
Since the built-in Ethernet port is connected through USB, I'm not sure why USB is not good for the other two. Is it about wires flopping around?
gtoal
Sun Jun 23, 2019 7:56 pm
Is the reason for that because you've tried some and they're completely unreliable, causing repeated crashes of your pi?
If so, I had the same problem with those cheap chinese USB-hub+nic units. But I eventually found a couple of USB ether devices that *are* reliable and indeed I've had one online for over a year now in my Pi that I use as my main router/firewall/NAT device.
Post if that is the reason and I'll look in my records and find the specific product for you.
Graham
