Dogga85
Connection refused when trying to SSH
Sat Jun 22, 2019 7:42 am
Hi all,
I'm trying to SSH with Putty to my Raspberry Pi 3 B+ but get the error Connection Refused. I'm using Windows 10 and AVG Internet Security. I'm using the correct IP, I have enabled SSH on the RPi through the config interface. My PC and RPi are both connected to the router via Ethernet. I've tried opening port 22 in windows and AVG. What am I doing wrong?
pcmanbob
Re: Connection refused when trying to SSH
Sat Jun 22, 2019 10:12 am
You should not be opening port 22 on your windows PC that would be for incoming connections.
did you use
sudo raspi-config
to enable SSH ?
To be sure you could just create a file called ssh or ssh.txt by putting the SD card back in your windows PC.
once you reboot your pi you should see the ssh file disappear which would mean ssh is enabled.
may I ask how you know you have the correct IP do you have a screen connected to the pi ?
can you ping the pi from your windows PC ?
HawaiianPi
Sat Jun 22, 2019 10:38 am
Try SSH into pi@raspberrypi.local.
Or ping raspberrypi.local to double check the IP address (assuming you don't have other Pi computers with the default hostname).
Dogga85
Sat Jun 22, 2019 7:02 pm
Thanks I'll try creating the file. I used the GUI to enable SSH. I do have a monitor connected to the Pi. I can ping it, and also created a DHCP reservation for it on my router so it's IP never changes.
