Using a USB NiC on Pi 3
Posted: Mon May 13, 2019 11:21 pm
by Chewie316
Hello my pi SD card died so I am trying to set up a new instance of Raspbian.
I can't believe how fast it is now that I am running fresh but I am not able to use my USB Gigabyte NIC that I have always used.
Before I added info for eth1 in the /etc/network/interfaces file but now it seems that no longer applies and I need to edit dhcpcd.conf I am just not sure what I need to ad as I don't care if it is static IP. I will set that on my router.
Sorry if this has been asked before but I can't find a resolution for my issue. I know I should just use the regular NIC but using this one does seem to add a tiny bit of speed and for transferring files I liked having the little boost.
Any help would be very much appreciated
Here is what I am trying to do before they updated it to dhcpcd.conf
https://www.jeffgeerling.com/blogs/jeff ... networking
Re: Using a USB NiC on Pi 3
Posted: Tue May 14, 2019 9:40 am
by pcmanbob
If you simply open the dhcpcd.cong file for editing with
sudo nano /etc/dhcpcd.conf
you will find there are examples of how to set a static IP
here's a copy from one of my pi's
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# static IP configuration:
interface eth0
static ip_address=192.168.1.16/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
So you can see I have a static IP set for eth0
interface eth0
So if you wanted to set a static IP for eth1 you would just enter the same information but use eth1 in place of eth0.
Posted: Tue May 14, 2019 10:54 am
by LTolledo
That's odd, on my RPi3B and RPi2B v1.2 with Raspbian Stretch Desktop, I just plugged the USB GbE adaptor, transferred the CAT6 cable from the on-board RJ-45 port to the USB GbE RJ-45 port... and it got connected to my home network immediately.
After that I set the router to reserve an IP address for USB GbE adapters so I wont have to guess the IP address every time I connect via ssh or RealVNC to it.
