Connecting multiple monitors to RASP Pi 3 Model B
Posted: Thu Dec 06, 2018 6:19 pm
by rmks
Hi
We have a few projects where we require to connect multiple monitors to the RASP Pi 3 Model B. We have planned to use HDMI splitters to split the HDMI output of the RASP Pi and connect to monitors using HDMI cables. In some cases where the monitor is a bit far away we plan to use HDMI over CAT 6 extenders from the splitter to the monitor.
Appreciate if we can clarify if someone has done this arrangement and whether the set up would work fine, without freeze or no signal.
Ravi
