ECE19.4
problem with GSM module called “SIM800L EBV” in zambia
Fri Nov 16, 2018 10:27 pm
I am working with a team to send data from Raspberry Pi over 2G network to a server using a GSM module called “SIM800L EBV”. We encountered an AT+CIPSEND error that has only occurred in Zambia, Africa while having been working correctly in the US (Arkansas, Colorado, and Washington state) for two years.
Below is a picture of our SIM log. We noticed from our log that the AT+CIFSR to request an IP address is working. And when AT+CIPSTART is run to start the TCP connection to the server “obfuscated.org” at port 11002, the response is OK and CONNECT OK indicating that the TCP connection to the server has been established. However, when AT+CIPSEND is run, we received an “+CME ERROR: operation not allowed”.
Has anyone encountered this problem before? Does anyone know about any supporting information that might help solve the problem? Is there any suggestion on how to get around this CME error? Is there any other command to replace this AT+CIPSEND command? Why does it work fine in America but not in Zambia?
Many thanks!
Wrote to sim: AT+CIFSR
Bytes to read: 26
Sim response: AT+CIFSR
172.50.216.113
Wrote to sim: AT+CIPSTART="TCP","redacted.org","11002"
Bytes to read: 58
Sim response: AT+CIPSTART="TCP","redacted.org","11002"
OK
CONNECT OK
Wrote to sim: AT+CIPSEND
Bytes to read: 47
SIM response: AT+CIPSEND
drgeoff
Re: Why does SIM respond to AT+CIPSEND with “+CME ERROR: operation not allowed” when the IP address and the TCP connecti
Fri Dec 07, 2018 9:24 pm
You might do better by asking on a more relevant forum as your problem appears to be with the GSM side of things, not the RPi.
mahjongg
Re: problem with GSM module called “SIM800L EBV” in zambia
Sat Dec 08, 2018 3:51 pm
moved to networking and servers, as this seems to be a networking problem, and here is where experts lurk.
also changed the subject line. to one that might attract attention instead of scaring off interest.
also its somewhat off topic for this RPF forum, but i will let that slip.
sbcdave
Mon Jan 21, 2019 6:09 am
You could try updating the firmware on the SIM card. Beyond that the only other suggestion I can provide is to look through the open source code for sakis3g (google it), they're able to establish an internet connection over sim through a ppp interface and their code might be helpful.
