Martin Frezman
Timeout functionality in "vncviewer" ?
Sun Oct 01, 2017 11:03 pm
I'm running Real VNC viewer and server under Raspbian Jessie.
I've noticed that if I launch the viewer and leave it idle, after some time, it disappears (process is gone as seen in a "ps" listing).
Is there some parameter in the viewer settings that needs to be adjusted to prevent this timeout from happening?
If this post appears in the wrong forums category, my apologies.
pcmanbob
Re: Timeout functionality in "vncviewer" ?
Mon Oct 02, 2017 9:43 am
There is a connection time out set by default to 60 min.
but you can change this .
see here : https://www.realvnc.com/en/connect/docs ... ssion-last
klricks
Mon Oct 02, 2017 12:15 pm
Unless specified otherwise my response is based on the latest and fully updated Raspbian Buster w/ Desktop OS.
