Re: [Tutorial] Using the RasPi as a WiFi hostspot (8 Nov 12)
Mon Dec 23, 2013 6:53 pm
Running ISC Bind9 isn't that difficult, it's coding all of the zone files that adds the layer of complexity.
I've got zone files for my IPv4 network (with some IPv6 AAAA records) but I've not done the reverse lookup for IPv6 (need to read up on doing that).
This is a doctor free zone.
labtom
Fri Jan 03, 2014 11:37 am
Hi I'm having some trouble with using the raspi as a WiFi hotspot. I have raspbian running on the pi. I followed the tutorial on http://elinux.org/RPI-Wireless-Hotspot . The wireless device is: http://thepihut.com/products/usb-wifi-a ... spberry-pi
After installing everything I can dial in to my access point with my laptop. But I have no acces to the Internet. But I have access to the pi through the wifi. The pi has a working internet connection through cable.
the ifconfig output of my pi after reboot is:
  eth0      Link encap:Ethernet  Hardware Adresse b8:27:eb:0d:e1:7f
          inet Adresse:192.168.0.11  Bcast:192.168.0.255  Maske:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metrik:1
          RX packets:159 errors:0 dropped:0 overruns:0 frame:0
          TX packets:176 errors:0 dropped:0 overruns:0 carrier:0
          Kollisionen:0 Sendewarteschlangenlänge:1000
          RX bytes:14323 (13.9 KiB)  TX bytes:22659 (22.1 KiB)
lo        Link encap:Lokale Schleife
          inet Adresse:127.0.0.1  Maske:255.0.0.0
          UP LOOPBACK RUNNING  MTU:65536  Metrik:1
          RX packets:2 errors:0 dropped:0 overruns:0 frame:0
          TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
          Kollisionen:0 Sendewarteschlangenlänge:0
          RX bytes:100 (100.0 B)  TX bytes:100 (100.0 B)
mon.wlan0 Link encap:UNSPEC  Hardware Adresse 00-0F-55-A6-64-66-00-00-00-00-00-00-00-00-00-00
          RX packets:52 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:6180 (6.0 KiB)  TX bytes:0 (0.0 B)
tun0      Link encap:UNSPEC  Hardware Adresse 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
          inet Adresse:10.8.0.1  P-z-P:10.8.0.2  Maske:255.255.255.255
          UP PUNKTZUPUNKT RUNNING NOARP MULTICAST  MTU:1500  Metrik:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wlan0     Link encap:Ethernet  Hardware Adresse 00:0f:55:a6:64:66
          inet Adresse:192.168.1.1  Bcast:192.168.1.255  Maske:255.255.255.0
          TX packets:45 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:7468 (7.2 KiB)
That means my wlan0 has an ip-address. Don't worry about tun0. That is a vpn server (openvpn) running on the pi.
ok so far so good. When I run: hostapd /etc/hostapd/hostapd.conf
the output is
    Configuration file: /etc/hostapd/hostapd.conf
Failed to create interface mon.wlan0: -23 (Too many open files in system)
Try to remove and re-create mon.wlan0
Failed to update rate sets in kernel module
Using interface wlan0 with hwaddr 00:0f:55:a6:64:66 and ssid 'torb'
when I run again ifconfig, the output is:
    [eth0      Link encap:Ethernet  Hardware Adresse b8:27:eb:0d:e1:7f
          RX packets:313 errors:0 dropped:0 overruns:0 frame:0
          TX packets:292 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:25275 (24.6 KiB)  TX bytes:38913 (38.0 KiB)
          RX packets:4 errors:0 dropped:0 overruns:0 frame:0
          TX packets:4 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:200 (200.0 B)  TX bytes:200 (200.0 B)
          UP BROADCAST MULTICAST  MTU:1500  Metrik:1
          TX packets:47 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:8019 (7.8 KiB)
As you see the mon0.wlan0 entry disapeared! Why?
By doing again: hostapd /etc/hostapd/hostapd.conf
the output changes to
I have no clue where the misstake is. I've gone through this thread, but I couldn't find the same problem:
Here are my settings:
/etc/hostapd/hostapd.conf:
   interface=wlan0
driver=nl80211
ssid=torb
hw_mode=g
channel=4
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=saveandsecure
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pairwise=CCMP
/etc/network/interfaces:
  auto lo
iface lo inet loopback
iface eth0 inet static
  address 192.168.0.11
    netmask 255.255.255.0
    gateway 192.168.0.1
    dns-nameservers 192.168.0.1
    broadcast 192.168.0.255
iface wlan0 inet static
  address 192.168.1.1
up iptables-restore < /etc/iptables.ipv4.nat
I played around for several days but I can't get it to work.
For any help I would be very thankfull.
thanks
hunternet93
Fri Jan 03, 2014 5:15 pm
It sounds like hostapd might already be running in the background as a service. Reboot your Pi and run the command:
ps ax | grep -v grep | grep hostapd
If it returns a line of text, then hostapd is already running as a service, and you should be able to connect.
labtom
Fri Jan 03, 2014 5:26 pm
That's the output of ps ax | grep -v grep | grep hostapd:
2063 ?        Ss     0:00 /usr/sbin/hostapd -B -P /var/run/hostapd.pid /etc/hostapd/hostapd.conf
I can connect (my laptop is getting an ip), but I can't browse the internet. (I can also ping the pi through wifi after I'm connected).
Any ideas?
thanks
hunternet93
Fri Jan 03, 2014 6:04 pm
labtom wrote:That's the output of ps ax | grep -v grep | grep hostapd:
Any ideas?
thanks
Your router (AKA default gateway) might be set incorrectly in /etc/udhcpd.conf. Open the file check the line:
option router a.b.c.d
Make sure a.b.c.d is set to your Pi's wlan0 interface's IP address. In the tutorial I used 192.168.42.1, but according to your /etc/network/interfaces file it should be set to 192.168.1.1.
If the above doesn't fix the issue, then make sure IP forwarding is set up correctly. Post the output of the command:
iptables --list
labtom
Fri Jan 03, 2014 6:19 pm
I checked the router IP (raspberry pi). It's correct.
#Examles
opt     dns     8.8.8.8 4.2.2.2
option  subnet  255.255.255.0
opt     router  192.168.1.1
opt     wins    192.168.10.10
option  dns     129.219.13.81   # appened to above DNS servers for a total of 3
option  domain  local
option  lease   864000          # 10 days of seconds
The output of "iptables --list" is:
 Chain INPUT (policy ACCEPT)
target     prot opt source               destination
Chain FORWARD (policy ACCEPT)
ACCEPT     all  --  anywhere             anywhere             state RELATED,ESTABLISHED
ACCEPT     all  --  10.8.0.0/24          anywhere
REJECT     all  --  anywhere             anywhere             reject-with icmp-port-unreachable
Chain OUTPUT (policy ACCEPT)
looks a bit messy, right :)? But I have no idea. Maybe it's so messy because 2 weeks ago I messed around with openvpn?
further suggestions?
thank you so much so far
hunternet93
Fri Jan 03, 2014 11:01 pm
Looks like something went wrong when setting up the firewall/NAT rules. Run the command:
sudo iptables --flush
This will delete all existing IPTables rules. Then re-run the NAT section of the tutorial and reboot.
labtom
Fri Jan 03, 2014 11:44 pm
thousand thanks, I can't believe it's working :lol:
thank you very much!!!!
the output of iptables --list is now:
thx again for the fast help
ecolban
Sun Jan 05, 2014 5:27 am
If I run:
udhcpd -f
I get:
udhcpd (v1.20.2) started
udhcpd: max_leases=235 is too big, setting to 19
udhcpd: can't open '/var/lib/misc/udhcpd.leases': No such file or directory
udhcpd: socket: Operation not permitted
However max_leases is commented out in /etc/udhcpd.conf and so is lease_file. Where is udhcpd looking for the conf file?
hunternet93
Sun Jan 05, 2014 1:50 pm
ecolban wrote:If I run:
udhcpd -f
I get:
Max_leases defaults to 254 leases, but will adjust itself automatically based on how many IPs are in the range specified in the "start" and "end" range in the config file, in your case 19. The message is just a notice and not an error, if you want to get rid of it set max_leases to 19.
ecolban
Sun Jan 05, 2014 2:50 pm
Thanks for the answer, but the problem is that I cannot get udhcpd to run. What do I do about the two next messages? "Socket: Operation not permitted"
hunternet93
Sun Jan 05, 2014 7:02 pm
ecolban wrote:Thanks for the answer, but the problem is that I cannot get udhcpd to run. What do I do about the two next messages? "Socket: Operation not permitted"
Try running:
sudo udhcpd -f
The "sudo" command runs commands with root (AKA admin) privileges, which will likely clear up the operation not permitted error.
G0Ku5
Tue Jan 21, 2014 9:41 pm
I have a problem on my hotspot, sometimes, but more often lately, let have access to internet and pi, through the wifi, I try to connect with my windows pc and windows detects the error that says that this related to the ip
then the only solution I have is to restart the pi by turning off the electricity and reconnect
anyone have any idea which can help me?
seldenr
Fri Feb 07, 2014 4:43 am
Hi!
I just followed this tutorial and am having some trouble. I am using a RevB2 Pi with Raspbian Wheezy with a Ralink 5370 WiFi adapter which this tutorial says is supported.
When I run "sudo service hostapd start" - I get the following error:
"[FAIL] Starting advanced IEEE 802.11 management: hostapd failed!"
When I run "sudo service udhcpd start" - I get
"Starting very small Busybox based DHCP server: Starting /usr/sbin/udhcpd... udhcpd."
But nothing happens. Any idea what I should do here?
Thanks for your help.
hunternet93
Fri Feb 07, 2014 3:33 pm
seldenr wrote:When I run "sudo service hostapd start" - I get the following error:
Try the command:
sudo hostapd -d /etc/hostapd/hostapd.conf
This should output the error message telling you why hostapd isn't starting, please post the output here.
seldenr
Fri Feb 07, 2014 8:30 pm
Try the command:
Ok, I ran that. Here's what I get:
random: Trying to read entropy from /dev/random
Line 2: unknown configuration item '    ssid'
Line 3: unknown configuration item '    hw_mode'
Line 4: unknown configuration item '    channel'
Line 5: unknown configuration item '    auth_algs'
Line 6: unknown configuration item '    wmm_enabled'
5 errors found in configuration file '/etc/hostapd/hostapd.conf'
hunternet93
Fri Feb 07, 2014 9:29 pm
seldenr wrote: Ok, I ran that. Here's what I get:
It looks like there are some tabs and/or spaces in front of the lines of your /etc/hostapd/hostapd.conf, try editing the file and removing them and then restarting hostapd.
seldenr
Fri Feb 07, 2014 9:47 pm
Ooh! Awesome! That worked! So now I have my network, but it's not giving any internet. It did give a connected device an ip address inside it's range. Interestingly when I run
sudo iptables-save > /etc/iptables.ipv4.nat
as it says to do so in the tutorial, I get
-bash: /etc/iptables.ipv4.nat: Permission denied
Do you know why this is? I assume that NAT isn't running which is probably the reason that there is no internet.
I did check that I can ping from my pi. I also notice that there is no file /etc/iptables.ipv4.nat but I would have assumed the system could create one as I ran the command as sudo.
hunternet93
Sun Feb 09, 2014 3:18 am
The tutorial in the forum post has a couple of errors which I can't edit, the version on the eLinux wiki has an updated, working version of that command. Try re-running all of step 4 from the wiki to make sure all the settings are set correctly.
poing
Sun Feb 09, 2014 9:28 am
hunternet93 wrote:The tutorial in the forum post has a couple of errors which I can't edit,
That policy changed a while back, you can now edit even very old posts.
hunternet93
Sun Feb 09, 2014 8:24 pm
Cool, I removed the outdated tutorial and only left the link to the wiki.
Gerrelt
Sun Feb 09, 2014 8:52 pm
The link isn't clickable, you should put
[url]....[/url]
around it.
my Raspberry Pi page: http://raspberry.gerrelt.nl
hunternet93
Sun Feb 09, 2014 8:54 pm
Gerrelt wrote:The link isn't clickable, you should put
[url]....[/url]
around it.
Fixed! Thanks.
Gerrelt
Sun Feb 09, 2014 9:05 pm
And thank you for the tutorial! 8-)
thak
Mon Feb 10, 2014 9:10 pm
Hi all!
I followed your tuto (and the one for edimax dongle) everything is fine except that i can't start hostapd and/or udhcpd on boot...
each time i try tu run the followind command :
sudo update-rc.d hostapd enable
sudo update-rc.d udhcpd enable
i have this warning :
update-rc.d: using dependency based boot sequencing
update-rc.d: error: no runlevel symlinks to modify, aborting
Any idea what i'm doing wrong?
