Colman4
Playing movies
Tue Feb 10, 2015 8:09 am
Hi very new to the Pi,
I want to use the Pi2 to play movies and music etc but i want to be able to play the stuff off my 1TB hard drive, whats the best way to do this? Preferably id like to be able to use my tv remote.
ghans
Re: Playing movies
Tue Feb 10, 2015 8:40 am
Install OSMC or OpenELEC. Both are uncomplicated yet powerful mediacentres based on Kodi.
ghans
Colman4
Re: Playing movies
Tue Feb 10, 2015 8:54 am
Will that work on Pi2, i forgot to mention that i was using that version
Colman4
Re: Playing movies
Tue Feb 10, 2015 9:11 am
also i should mention my main plan at the moment is i want to be able to plug my hard drive into the Pi2 and then watch movies straight from there
ghans
Re: Playing movies
Tue Feb 10, 2015 9:13 am
Yes to both questions.
ghans
Ant232
Re: Playing movies
Tue Feb 10, 2015 9:24 am
Just make sure you get a recent release of Openelec. Go to their site to download it as I think the one on the Pi site is an older version (4.0.5)..
I put Openelec 5.0.1 on my Pi 2 and it worked brilliantly. You should be fine plugging your hard drive directly into the Pi. I have my media on a NAS so never used a drive directly plugged in.
When you add your movie folder to the library in Openelec, have a look at movie scrapers. I used the TMDB scraper and it will get information and pics (movie posters) for all your movies and organise them so you can search by year, movie type, actors etc..
A
Colman4
Re: Playing movies
Tue Feb 10, 2015 9:27 am
I cant find my hard drive, any tips?
Ant232
Re: Playing movies
Tue Feb 10, 2015 9:33 am
Video - files - add videos - browse
You should be able to see you drive in there.
Colman4
Re: Playing movies
Tue Feb 10, 2015 9:37 am
It wont show up for my 1TB hard drive but it does show up for a smaller usb, would the hard drive size be an issue
Colman4
Re: Playing movies
Tue Feb 10, 2015 9:39 am
Id honestly have no idea how to do the scrapers, i know next to nothing about this stuff, just trying to learn and start easy
Ant232
Re: Playing movies
Tue Feb 10, 2015 9:41 am
I haven't had to do this myself but you could try
system - file manager - add source
see if it appears there..
topguy
Re: Playing movies
Tue Feb 10, 2015 9:42 am
> It wont show up for my 1TB hard drive but it does show up for a smaller usb, would the hard drive size be an issue.
No but the file-system used on the drive might be. Is it formatted with NTFS ?
Does the drive have its own power by the way ?
Ant232
Re: Playing movies
Tue Feb 10, 2015 9:44 am
Found this on another forum..
1 - system > settings > Add-ons - > Install from zip file - > Root filesystem - > mnt - > sda1
2 - system > file manager > Add source > Browse > Root filesystem - > mnt - > sda1
/mnt/sda1
Enter a name for this media Source
Might work..
Colman4
Re: Playing movies
Tue Feb 10, 2015 9:46 am
No extra power supply and yes to NTFS
Colman4
Re: Playing movies
Tue Feb 10, 2015 9:49 am
Couldnt find it either of those places
Ant232
Re: Playing movies
Tue Feb 10, 2015 9:53 am
Topguy might be onto something. Maybe the Pi is not able to power the drive. Have you got a powered USB hub to could stick in between the Pi and the hard drive?
Colman4
Re: Playing movies
Tue Feb 10, 2015 9:58 am
No i dont
Ant232
Re: Playing movies
Tue Feb 10, 2015 10:03 am
Sorry, don't really have enough experience with USB drives. Maybe some else has an idea?
Colman4
Re: Playing movies
Tue Feb 10, 2015 10:04 am
Thanks appreciate all your help
RaTTuS
Re: Playing movies
Tue Feb 10, 2015 10:09 am
post links to
your PSU
your HD drive and adapter
how are you powering it
can you run raspbain and see what it says
are you able to use the command line or enable config options for the RPI ?
Covfefe
Colman4
Re: Playing movies
Tue Feb 10, 2015 10:14 am
PSU - output 5Vdc 2000mA
Hard Drive - WD Elements 1TB dunno what else, it only has the one cable coming out of it which is usb 3.0. In file system it said NTFS
I can run raspbain but i have no idea about the other stuff
procount
Re: Playing movies
Tue Feb 10, 2015 10:35 am
You probably need to configure your Pi2 USB ports to output more current, as you are powering your 1TB USB drive directly from it. By default it is only 600mA.
To increase the total maximum current output to 1.2A, you need to edit /boot/config.txt and add the line:
max_usb_current=1
Re: Playing movies
Tue Feb 10, 2015 11:46 am
As above, use
sudo nano /boot/config.txt
and add the line shown in the previous post. Ctrl-X to save and exit, then reboot.
RaTTuS
Re: Playing movies
Tue Feb 10, 2015 11:52 am
I dont use openelc however
you will need to edit the the config file that openelect uses
http://wiki.openelec.tv/index.php/Raspberry_Pi_FAQ
may help you in your quest
Covfefe
Colman4
Re: Playing movies
Wed Feb 11, 2015 6:48 am
Thanks guys adding the code to increase the usb worked. Appreciate all the help
Return to “Media centres”
