onkarmatharu
Why is no XBMC distro working?
Sun Oct 05, 2014 4:44 pm
Hi guys. I'm not new here, but i lost old account "onkzzz".
I'm 14 now btw! Anyway:
I have 2 Pi's.
I have downloaded:
1: OpenELEC
2: DarkELEC
3: Raspbmc
4: XBian
I have used 2 SD Cards, 2 different power supplies, and both ethernet and WiFi.
But NONE of these distros seem to work for me!
ITS ANNOYING!
OpenELEC restarts about 5 seconds past the main menu of XBMC
DarkELEC fails to boot
Raspbmc gets stuck at boot with the "R" Logo
XBian works perfect but breaks as soon as i turn the pi off.
I have used OpenELEC 4 for about 7 months straight for our main media center, no issues.
Now both my Pi's are having issues using ANY of these distros.
Someone please help!
Cheers
- onkz
HiroProtagonist
Re: Why is no XBMC distro working?
Sun Oct 05, 2014 11:26 pm
onkarmatharu wrote:Hi guys. I'm not new here, but i lost old account "onkzzz".
I have 2 Pi's.
I have downloaded:
1: OpenELEC
2: DarkELEC
3: Raspbmc
4: XBian
ITS ANNOYING!
You quite likely have insufficient power. You need a power supply that can maintain a regulated 5V and supply at least 2 amps [2000ma]. You cannot guarantee you are providing adequate power without actually measuring the voltage [at TP1 & TP2] on the pi. There are a lot of substandard phone charger power supplies out there.
Mon Oct 06, 2014 7:24 am
2mA is much more than you need. I run XBMC on a Pi with a wireless dongle on a 1A supply.
But it must be a GOOD 1A.
DirkS
Mon Oct 06, 2014 2:18 pm
:shock: typo alert (I hope) :D
masterluke
Mon Oct 06, 2014 2:19 pm
I was getting instability and rather than buying a multimeter to check the levels is was cheaper to to buy a new power supply. I got one from modmypi. Rock solid ever since..
https://www.modmypi.com/raspberry-pi-accessories
HiroProtagonist
Mon Oct 06, 2014 11:24 pm
jamesh wrote:But it must be a GOOD 1A.
Sadly you can't just rely on the PSU label to tell you this. A Pi [without high consumption USB devices] will happily run on 1A, but the bottom line is PSU must be able to maintain a regulated 5V with the load you're giving it [and the load changes depending on what the Pi is doing].
If it's working unreliably, you can either swap PSU's randomly until it works, or measure the voltage & know you either have power problems, or to look for something else.
Return to “Media centres”
