Sc0ut
Re: OpenELEC Testbuilds
Sat Jul 14, 2012 7:07 pm
Sc0ut wrote:Has anyone problems with the internet connection?
Had forgot to say it's the never releases, the first were fine, but 11514 and two before and all after are not.
Doktor-X
Mon Jul 16, 2012 5:05 pm
developers need's to check build 10902 and all new builds build from that becouse only this release works for me i'm talking about 1080p DTS statter free
b0x
Tue Jul 17, 2012 7:09 am
Doktor-X wrote:developers need's to check build 10902 and all new builds build from that becouse only this release works for me i'm talking about 1080p DTS statter free
with the right receiver and the pi running through it...
dts 1080p works fine on r11540 and has for many many many versions
once I had the right hardware setup in place.
Doktor-X
Tue Jul 17, 2012 1:33 pm
but lot of people (me included) do not have reciver to be able to passthrough dts on to it
jasjeet
Tue Jul 17, 2012 5:05 pm
Doktor-X wrote:but lot of people (me included) do not have reciver to be able to passthrough dts on to it
Well the Pi doesnt have Hardware Decode for DD/DTS due to licensing costs. Because of this devs have only one option to software decode on the CPU. This is resource intensive and the Pi doesnt have enough grunt to get it done. Sure optimisation may make it a bit better, but i think its a lot to ask.
b0x
Tue Jul 17, 2012 7:31 pm
audio decoder via gpio?
sebus
Tue Jul 17, 2012 8:57 pm
keenan wrote: Anyone know how easy/hard it would be to use a 5.1 external sound card with openelec?
It should be possible with pulseaudio, just what guys at raspbmc done (and it works fine!)
It would be really nice to have it included in OE
sebus
podly
Wed Jul 18, 2012 10:36 am
I was able to compile latest OpenElec with PulseAudio support using this patch:
http://www.mail-archive.com/pulseaudio- ... 03384.html
and it looks, that it works and can see my usb sndcard:
root ~ # ps auxwww | grep pulseaudio
 1100 root       0:04 pulseaudio --system --daemonize --log-target=file:/var/log/pulseaudio.log --log-level=debug
root ~ # pactl list sinks
Sink #0
        State: SUSPENDED
        Description: TP6911 Audio Headset Analog Stereo
        Driver: module-alsa-card.c
        Sample Specification: s16le 2ch 48000Hz
        Channel Map: front-left,front-right
        Owner Module: 0
        Mute: no
        Volume: 0:  29% 1:  29%
                0: -32.00 dB 1: -32.00 dB
                balance 0.00
        Base Volume:   9%
                     -63.00 dB
        Monitor Source: alsa_output.usb-1130_USB_AUDIO-00-AUDIO.analog-stereo.monitor
        Latency: 0 usec, configured 0 usec
        Flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
        Properties:
                alsa.resolution_bits = "16"
                device.api = "alsa"
                device.class = "sound"
                alsa.class = "generic"
                alsa.subclass = "generic-mix"
                alsa.name = "USB Audio"
                alsa.id = "USB Audio"
                alsa.subdevice = "0"
                alsa.subdevice_name = "subdevice #0"
                alsa.device = "0"
                alsa.card = "1"
                alsa.card_name = "USB  AUDIO"
                alsa.long_card_name = "USB  AUDIO at usb-bcm2708_usb-1.3, full speed"
                alsa.driver_name = "snd_usb_audio"
                device.bus_path = "platform-bcm2708_usb-usb-0:1.3:1.0"
                sysfs.path = "/devices/platform/bcm2708_usb/usb1/1-1/1-1.3/1-1.3:1.0/sound/card1"
                udev.id = "usb-1130_USB_AUDIO-00-AUDIO"
                device.bus = "usb"
                device.vendor.id = "1130"
                device.vendor.name = "Tenx Technology, Inc."
                device.product.id = "f211"
                device.product.name = "TP6911 Audio Headset"
                device.serial = "1130_USB_AUDIO"
                device.form_factor = "headset"
                device.string = "front:1"
                device.buffering.buffer_size = "384000"
                device.buffering.fragment_size = "192000"
                device.access_mode = "mmap+timer"
                device.profile.name = "analog-stereo"
                device.profile.description = "Analog Stereo"
                device.description = "TP6911 Audio Headset Analog Stereo"
                alsa.mixer_name = "USB Mixer"
                alsa.components = "USB1130:f211"
                module-udev-detect.discovered = "1"
                device.icon_name = "audio-headset-usb"
                device.intended_roles = "phone"
        Ports:
                analog-output: Analog Output (priority: 9900)
        Active Port: analog-output
        Formats:
                pcm
but I don't know how to get XBMC to use it :( Any ideas?
a-spence7
Wed Jul 18, 2012 10:41 am
Is there a user guide for beginners to get all of this up and running without having to trawl through 18 pages of discussion? It would be very helpful for a beginner.
podly
Wed Jul 18, 2012 11:15 am
a-spence7 wrote:Is there a user guide for beginners to get all of this up and running without having to trawl through 18 pages of discussion? It would be very helpful for a beginner.
sure:
http://wiki.openelec.tv/index.php?title ... spberry_Pi
and If you don't want to compile yourself, use http://openelec.thestateofme.com/ (you still need to read wiki). Or go to http://sparky0815.de/ and use google translator.
cpswan
Wed Jul 18, 2012 12:00 pm
I wrote up a guide on Designspark a little while ago.
Josh.43
Wed Jul 18, 2012 2:44 pm
Does anyone know how to stop the XBMC process from running until the next reboot?
I'm working on some ideas for the library, and want to rsync the thumbnails. All the speed I get get is appreciated :)
(Note: kill <pid> simply causes it to start xbmc again)
podly
Wed Jul 18, 2012 9:46 pm
You have to do from ssh:
root ~ # touch /var/lock/xbmc.disabled
root ~ # killall -9 xbmc.bin
When you want xbmc back just delete /var/lock/xbmc.disabled - xbmc will respawn and you don't need to restart system.
daveg
Thu Jul 19, 2012 10:08 am
Using r11493, all seems ok except for the mute not muting.
Anyone else have this on this release?
b0x
Thu Jul 19, 2012 6:13 pm
daveg wrote:Using r11493, all seems ok except for the mute not muting.
i've never found the mute to work. haven't tested it the last couple versions however. tested it using both analog and hdmi audio.
Josh.43
Thu Jul 19, 2012 9:52 pm
podly wrote:You have to do from ssh:
Thank you; this is a more elegant solution than I assumed there would be :)
eltechno
Fri Jul 20, 2012 5:57 am
i found a website with the openelec updated with the latest raspberry firmware and other stuff the youtube videos runs awesome !! and super fast &smooth :P
http://www.raspberrypilabs.com/openelec ... r-youtube/
check this if you need something like that :D
podly
Fri Jul 20, 2012 8:06 am
eltechno wrote:i found a website with the openelec updated with the latest raspberry firmware and other stuff the youtube videos runs awesome !! and super fast &smooth :P
All OpenElec compilations made after 3rd Jul should play all youtube videos without problems.
And r11493 is quite old release, this morning release is r11591. If you don't want to compile yourself, I think, that http://openelec.thestateofme.com/ is good place for actual compilation. Also http://sparky0815.de/openelec-download- ... fat-files/ is good place if you are lookin for sd card images.
cpswan
Fri Jul 20, 2012 10:39 am
podly wrote:I think, that http://openelec.thestateofme.com/ is good place for actual compilation. Also http://sparky0815.de/openelec-download- ... fat-files/ is good place if you are lookin for sd card images.
There are 900M SD card images (intended to fit onto any SD card with a nominal capacity >1G) on thestateofme build server too - it's just that there are so many release bundles there now that you have to scroll down a bit to see them. In retrospect I should have created subdirectories for release bundles and images, but since I've set up a notification mousetrap to let me know when new stuff arrives (and others might have too) I'm not too keen on changing things now.
tbar
Sat Jul 21, 2012 6:37 pm
Is OpenElec on RPi build with hardfp? Raspbmc is expected to be when RC4 is released.
sraue
Sat Jul 21, 2012 9:39 pm
tbar wrote:Is OpenElec on RPi build with hardfp? Raspbmc is expected to be when RC4 is released.
we do this since 5 months:
https://github.com/OpenELEC/OpenELEC.tv ... 10ecb3f977
Nodge
Mon Jul 23, 2012 9:28 pm
The problem with TV banners not displaying and causing lockups has been fixed sometime this last week. Much happier now :) Only thing now for me is Airplay. I can display photos but not videos or music.
John
wallacebiy
Tue Jul 24, 2012 9:08 pm
just downloaded todays test build Many thanks !!!
Just have to figure out Wifi ,( by having a proper read through here )
goujam
Wed Jul 25, 2012 6:28 am
I updated yesterday to the latest build and now I dont have any menu sounds. When I play a file music or film it works fine, I checked the settings and they look fine ! Any one got any ideas what it could be, audio is over HDMI to my Av Reciever.
aTTila
Wed Jul 25, 2012 11:06 am
When flashing my SD card with the latest build (OpenELEC-RPi.arm-devel-20120725022533-r11649.tar.bz2) and all seems fine until i try and boot it in my RPi. I get the following error:
*** Error in prepare_sysroot: mount-common: could not mount /flash/SYSTEM ***
[ 19.401619] System halted.
Any ideas?
Return to “Media centres”
