Sticky: Kodi [guide] on Raspbian Stretch (brought back from deleted thread)
Posted: Sun Aug 18, 2019 7:35 pm
by mahjongg
written by Rascas
[Guide] Kodi on Raspbian Stretch
Tue Sep 05, 2017 2:55 am
For a temporary install for Buster see https://www.raspberrypi.org/forums/view ... 0#p1506904. Not compatible with RPi 4 though.
INTRO:
After so many posts about people getting problems on installing Kodi on Raspbian, specially on the new Raspbian Stretch, this is a complete guide on how to do it, and an attempt to keep things together in the same place. You will see that after all, it is not so hard.
In the time of the first Raspbian Stretch image released by the RPi Foundation, there was only available the generic Debian Kodi version (17.1) which is compiled against OpenGL, so not optimal to run on the RPi (at least by this time), it runs very slow. But now, the latest stable version is available on the repos, compiled against OpenGLES, optimized for the RPi.
Latest stable version available on Raspbian:
Kodi 18.2 Leia
INSTALLATION:
To install it you first need to update/refresh packages, and then install the main package. This can be done in a virtual terminal by running the respective commands:
sudo apt-get update
sudo apt-get install kodi
Take note that Kodi on Raspbian, like most Debian based OSs, is divided into many packages, so you can install only what you really need. Besides the main package, you will find many "binary addons" packages which provide additional features to Kodi. For example, PVRs, Joystick support, Inputstreams, Visualizations, etc. You can easily search for aditional packages by running:
apt-cache search kodi
And install what you want.
For example in this case, we will install the joystick support, IPTV Simple PVR and the inputstream addons:
sudo apt-get install kodi-peripheral-joystick kodi-pvr-iptvsimple kodi-inputstream-adaptive kodi-inputstream-rtmp
After that, restart Kodi and check if the binary addons are enabled in Kodi interface, if not, enable them.
Here are some more recommend binary addons to install (only for Kodi 18 and above):
-kodi-vfs-libarchive - compressed files support
-kodi-vfs-nfs - NFS support
-kodi-vfs-sftp - SFTP support
Alternatively and easier, if you are running Raspbian with Desktop, you can just open the graphical package manager "Dont know the name of it" on the upper left corner menu, search for "Kodi" and install the packages you want.
TWEAKS:
This is very important!
-Kodi on Raspbian requires a minimum of 160 MB of RAM dedicated to the GPU to function properly! This can be done by running "raspi-config" -> "Advanced Options" -> "Memory Split" -> 160.
-If you have a RPi 2/3, the recommended is 256 MB of RAM for the GPU.
-Kodi 18 on the Raspberry Pi now supports 10bit video files (at least h264 and h265) but they are software decoded. The Pi 3B / 3B+ may do 720p 10bit and 1080p 10bit low bitrate only! For that you need at least 300MB of RAM for the GPU.
-Raspbian by default, doesn't play some video codecs like VP6, VP8, MJPEG, Theora, etc, so to be able to play this codecs, you need to go to "raspi-config" -> "Interfacing Options" -> "Camera" -> Enable,
or just add a new line in /boot/config.txt with:
start_x=1
-If you have a RPi 0/1/2 and want to play h264 50 or 60fps videos, depending on the kernel/firmware version you are using, you may need to also add a new line in /boot/config.txt with:
disable_auto_turbo=0
ADDITIONAL INFO:
This is very important also!
Kodi will only function if you are using the Broadcom drivers! This is the "Original non-GL desktop driver" on raspi-config, which is currently the default on the Raspbian images. If you select the open-source OpenGL driver, it won't work!
Kodi package includes both an ARMv6 and ARMv7 binary, which is autoselected accordindly to which version of the Raspberry Pi you have for best performance. Optimizations available in Open/LibreELEC like H265/HEVC NEON acceleration are also included and enabled automatically if you have a RPi 2/3. There is no visible performance improvement in compiling Kodi for ARMv8 currently (like native compile for the PI 3).
EXTRA INFO (not required for proper function):
RUNNING KODI WITH ANOTHER USER DIFFERENT FROM THE DEFAUL "PI":
If you want to run Kodi with a user different from the default "pi", that user needs to be part of the following groups, for everything to work fine:
audio, video, input, dialout, plugdev, netdev (needs confirmation), users, cdrom (only if you have cd/dvd drives) and tty (needs confirmation).
For that, run the following command:
sudo usermod -a -G audio,video,input,dialout,plugdev,netdev,users,cdrom,tty "username"
Replace "username" by the desired user name. Depending on the use case of Kodi, not all this groups may be needed.
AUTO-STARTING KODI AT BOOT:
Option 1 (without desktop):
If you want to auto-start Kodi automatically at boot, go to rc-gui on Raspbian desktop or raspi-config on a virtual terminal, and choose the option to boot to CLI/console.
Then copy/paste the following to a virtual termianl to create a systemd service for auto start:
sudo tee -a /lib/systemd/system/kodi.service <<_EOF_
[Unit]
Description = Kodi Media Center
After = remote-fs.target network-online.target
Wants = network-online.target
[Service]
User = pi
Group = pi
Type = simple
ExecStart = /usr/bin/kodi-standalone
Restart = on-abort
RestartSec = 5
[Install]
WantedBy = multi-user.target
_EOF_
Press Enter after paste. Then enable the service:
sudo systemctl enable kodi.service
Then reboot. If you want to auto start Kodi at boot with a different user change the "User" and "Group" fields above accordingly.
In this case If you are unable to mount/access disks and also have the options to reboot and shutdown missing, check this:
https://www.raspberrypi.org/forums/view ... 0#p1240007
Option 2 (with desktop):
If you want autostart Kodi at boot but also keep the Desktop Environment on the background, just edit the file (with sudo) /etc/xdg/lxsession/LXDE-pi/autostart and add a line, preferably at the beginning of the file with:
@kodi
This option is a bit more resource intensive because the DE is loaded on the background.
SOURCE CODE:
The source code of this packages/binaries are available here:
https://github.com/PIPplware/xbmc
Krypton (Kodi 17) branch used is "krypton_stable", for Leia (Kodi 18) it is "leia_stable", etc.
Each of this branches are the original Kodi respective branch + popcornmix Raspberry pi patches/fixes/tweaks + some litle patches/fixes/tweaks for Raspbian.
If you have any problem, please include your Kodi log. Information on how to do it here: http://kodi.wiki/view/Log_file
p.s. the google cache I used is here: http://webcache.googleusercontent.com/s ... p?t=192499
Re: Sticky: Kodi [guide] on Raspbian Stretch (brought back from deleted thread)
Posted: Sun Aug 18, 2019 9:01 pm
by Rascas
And where is the original one?
Posted: Sun Aug 18, 2019 9:14 pm
by mahjongg
Unfortunately the whole thread has been deleted, instead of just a single post from it, I tried to remove. I got confused and agitated because I had to delete several duplicate posts from someone who posted a list of kodi extensions, which I later found out were illegal.
Human error, clicked on delete thread instead of delete post.
I myself cannot bring deleted threads (or posts) back, I don't t have the privilege to do so. :(
I warned forum managers, hopefully they can bring it back from backups.
Sigh... I'm really very sorry :cry:
my apologies.
maybe you can take the opportunity to finalize the Stretch version, and start a new version for Buster.
discussion about the deletion error is here: https://www.raspberrypi.org/forums/view ... 7#p1521437
Posted: Sun Aug 18, 2019 9:28 pm
by Rascas
Ok, mistakes happen, I can understand that. What I can not understand is not having a backup of the forum. If it was a more important thread or even the hole forum, by mistake or an attack, bye bye Raspberry Pi forum...
Posted: Sun Aug 18, 2019 9:54 pm
by mahjongg
there IS a backup, only I'm not authorized to make use of it, as i'm just a volunteer, who does moderating work.
I have begged forum managers to restore the backup through a moderator only section of this forum, but they typically are slow to react, especially in the weekend, its just a job for them, not a hobby.
I am well aware the guide is important for many PI users, so I took the trouble to try to bring back the original (first) post, which I hope has most of the pertinent info, from a google cache. But I could only copy paste the plain text from it, not the source.
I saw you did 33 updates to that post, so I hope its still relevant.
Posted: Sun Aug 18, 2019 11:01 pm
by hippy
I have recovered 249 of the posts up to 9th of August 2019.
Posted: Mon Aug 19, 2019 10:52 pm
by kaminsky9444
PPA Kodi (18.3) for Raspbian Buster (RPI 3B+) by @Rascas
sudo -i
echo "deb http://pipplware.pplware.pt/pipplware/dists/buster/main/binary /" > /etc/apt/sources.list.d/pipplware.list
wget -q -O- http://pipplware.pplware.pt/pipplware/key.asc | apt-key add -
exit
sudo apt update ; sudo apt install kodi
pi@raspberrypi:~ $ dpkg -l kodi*
Souhait=inconnU/Installé/suppRimé/Purgé/H=à garder
| État=Non/Installé/fichier-Config/dépaqUeté/échec-conFig/H=semi-installé/W=attend-traitement-déclenchements
|/ Err?=(aucune)/besoin Réinstallation (État,Err: majuscule=mauvais)
||/ Nom                           Version         Architecture Description
ii  kodi                          2:18.3-2~buster all          Kodi Media Center (arch-independent data package)
un  kodi-audioencoder-flac        <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-audioencoder-lame        <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-audioencoder-vorbis      <aucune>        <aucune>     (aucune description n'est disponible)
ii  kodi-bin                      2:18.3-2~buster armhf        Kodi Media Center (binary data package)
un  kodi-common                   <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-data                     <aucune>        <aucune>     (aucune description n'est disponible)
ii  kodi-inputstream-adaptive     2.3.22-1~buster armhf        adaptive inputstream addon for Kodi
un  kodi-inputstream-mpd          <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-inputstream-smoothstream <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-pvr-argustv              <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-pvr-dvbviewer            <aucune>        <aucune>     (aucune description n'est disponible)
ii  kodi-pvr-iptvsimple           3.5.8-1~buster  armhf        Simple IPTV PVR for Kodi
un  kodi-pvr-mediaportal-tvserver <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-pvr-mythtv               <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-pvr-nextpvr              <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-pvr-njoy                 <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-pvr-tvheadend-hts        <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-pvr-vdr-vnsi             <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-pvr-vuplus               <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-skin-estuary             <aucune>        <aucune>     (aucune description n'est disponible)
un  kodi-standalone               <aucune>        <aucune>     (aucune description n'est disponible)
Kodi (18.3) for Raspbian Buster (RPI 4)
https://www.raspberrypi.org/forums/viewtopic.php?f=38&t=246837&hilit=kodi+raspberry+4
:ugeek:
Posted: Tue Aug 20, 2019 5:14 pm
by Rascas
sudo -i
exit
:ugeek:
This is a thread about Kodi on Raspbian Stretch as the topic says, why did you posted of topic information?
At the forum administrators: Any news about the recovery of the old thread? Is it possible or not?
Posted: Tue Aug 20, 2019 6:14 pm
by mahjongg
No news yet, no reply to my urgent request for help, perhaps they are on holiday.
I can't say if recovery is possible.. I only assume it is, JamesH should know as he actually can speak to the people responsible, and ask them, but he isn't reacting either.
The previous poster probably assumed you are working on a version for Buster, because it is the current version now, stretch has now gone obsolete, which is why only a final set of instructions for it are needed, the whole thread IMHO is only worth full because of its historical nature.
Posted: Tue Aug 20, 2019 6:47 pm
by rpdom
I'm pretty certain I saw JamesH say he is on holiday this week, in an earlier post.
Posted: Tue Aug 20, 2019 7:32 pm
by hippy
Jamesh posted earlier this evening but could have posted from home or holiday resort.
Posted: Tue Aug 20, 2019 7:53 pm
by rpdom
Probably posting from holiday destination. He's not posting as much as usual.
Here's the (brief) post https://www.raspberrypi.org/forums/view ... 1#p1522281
I hope he's having a good time :)
Posted: Thu Aug 22, 2019 11:26 am
by kaminsky9444
:D
Posted: Thu Aug 22, 2019 1:02 pm
by Rascas
Has I posted on my deleted thread, I am currently on vacations. I made available Kodi 18.3 packages for RPi 3 and below only because I still don't have a RPi 4, so no more work on it until I arrive from vacations and get one.
Then I will create another thread like "[Guide] Kodi on Raspbian Buster"
Historical or not, nobody likes to see his thread in which I spent alot of work in it deleted. And there is still alot of people running Stretch or Stretch based (RetroPie for example), me included.
Posted: Thu Aug 22, 2019 2:41 pm
by kaminsky9444
You won't find your thread, I think we might understand that removing your thread is annoying... but the error is human.
:roll:
Posted: Mon Sep 02, 2019 8:29 pm
by gkreidl
Did anyone really care about it?
Posted: Tue Sep 03, 2019 10:33 am
by Rascas
Unfortunately, it looks like no one from the administration really cares. This lowers my confidence in the project and my willingness to continue contributing to it... Some explanation like "it is not possible" or "it would take to much work" would be enough.
Posted: Tue Sep 03, 2019 11:13 am
by ShiftPlusOne
The issue is that nobody who's actually involved on the forum can do anything about it. The moderators and admins don't have that level of access. I don't even know who does. The forum is not run or hosted by Raspberry Pi Trading.
Posted: Tue Sep 03, 2019 3:34 pm
by gkreidl
If it is not run by RP Trading, it is run by the Raspberry Pi Foundation. Is nobody of the RPF here on the Forum any more? Is the RPF not interested in the Community any more?
Suggestion: Talk to Eben. Eben should talk to his wife. That should work. Liz has always cared about the forum community.
Posted: Wed Sep 04, 2019 2:46 pm
by Rascas
Ok, my hopes for a recover are pretty much lost. Lets hope things get more professional in the future and anything like that or worse doesn't happen anymore.
The link on the first posted is not working anymore, so here is a replacement:
https://web.archive.org/web/20190722103 ... 6&t=192499
I will create another topic with the original info, even if it is only for the record.
Posted: Thu Sep 05, 2019 9:04 pm
by kaminsky9444
https://kodi.tv/article/kodi-leia-184-release
kodi 18.4 is out, it would be possible to have the update?.
Thanks :geek:.
Posted: Fri Sep 06, 2019 8:41 pm
by Rascas
Thanks :geek:.
Yes, I will try to do it this weekend. Then I will make an update here:
https://www.raspberrypi.org/forums/view ... 6&t=250796
