Page 1 of 2
How to install XBMC on Wheezy Raspbian
Posted: Sun Dec 02, 2012 9:55 pm
by liquidfire
I have just set-up the 2012-10-28-wheezy-raspbian and works fine. Now that I need XBMC to be installed on top of raspbian.
I followed the steps mentioned in the posting - http://www.raspberrypi.org/phpBB3/viewtopic.php?t=12455 and failed to launch successfully.
Please provide step-by-step procedure to install XBMC.
Thanks.
LF
Re: How to install XBMC on Wheezy Raspbian
Posted: Tue Dec 04, 2012 4:45 am
by jacroe
You'll probably be better off using something like RaspBMC, OpenElec, or Xbian.
Posted: Tue Dec 04, 2012 10:03 pm
by north3221
Hey
Why do you need it on Raspbian? I assume for desktop, browsing etc.. I had issues with the post you mentioned too..
See my post for step by step to get a desktop & browser and xbmc:
http://www.raspberrypi.org/phpBB3/viewt ... 35&t=23051
Posted: Fri Dec 07, 2012 1:43 pm
by alias_neo
I really wanted to stick with Raspbian myself, but I've had nothing but issues trying to get a functional build of XBMC that doesn't idle at stupid high CPU usage.
After weeks of building, rebuilding, installing various pre-built packages I've got a build that idles as low as 40% but that's just no good. I can't have my Pi idling at 40% CPU 24/7.
Worst part is, before my previous Pi died and got RMA I had compiled a build that idles at about 16-20% but can't get there any more.
I'm all but ready to give up.
Posted: Sun Mar 17, 2013 7:31 pm
by apoth
   sudo echo "deb http://archive.mene.za.net/raspbian wheezy contrib" > /etc/apt/sources.list.d/mene.list
   sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-key 5243CDED
   sudo apt-get update
   sudo apt-get install xbmc
Posted: Fri Mar 29, 2013 7:47 pm
by smshiera
   sudo apt-get update
follow this guide,i installed xbmc,but my ipad3 cant airplay,(it can work on raspbmc and xbian)
why and what can i do?
Posted: Fri Mar 29, 2013 8:45 pm
by TheQuestor
Easiest way?
go to http://www.sshcs.com/xbmc/ and download my Raspi build.
open a cmd prompt and go to where you downloaded it.
type:
sudo apt-get install libmicrohttpd10 libtinyxml2.6.2 libmysqlclient18 liblzo2-2 libpcrecpp0 \
libsdl1.2debian libhal1 libhal-storage1 libva1 libva-glx1
then tar -zxf XBMC_Raspi_be6d3a7.tgz
then sudo dpkg -i xbmc_84-1_armhf.deb
then run it via /usr/lib/xbmc/xbmc.bin
and you're set to go.
Posted: Fri Mar 29, 2013 9:24 pm
by xaviv
It is also needed packages libssh-4 libyajl2 libfribidi0, but when I launch xbmc.bin ends up with a segment violation
Posted: Fri Mar 29, 2013 9:33 pm
by xaviv
This is the backtrace:
gdb) run
Starting program: /usr/lib/xbmc/xbmc.bin /usr/lib/xbmc/xbmc.bin
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Program received signal SIGILL, Illegal instruction.
0xb65e74c0 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
(gdb) backtrace
#0 0xb65e74c0 in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
Cannot access memory at address 0x0
#1 0xb65e3ee4 in OPENSSL_cpuid_setup () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.0.0
#2 0xb6fe8250 in ?? () from /lib/ld-linux-armhf.so.3
#3 0x00000000 in ?? ()
Posted: Fri Mar 29, 2013 9:45 pm
by TheQuestor
xaviv wrote:This is the backtrace:
gdb) run
(gdb) backtrace
ok that's weird, lemme fire up my pi again and see if I can replicate it.
Posted: Fri Mar 29, 2013 9:49 pm
by xaviv
I've seen that package libcurl-gnutls is also required. Now it's not crashing, but xbmc UI is not starting and there are these lines continously repeating at xbmc.log:
22:42:13 T:2924475456 NOTICE: Previous line repeats 1 times.
22:42:13 T:2924475456 NOTICE: Thread Jobworker start, auto delete: true
22:42:16 T:2913989696 NOTICE: Thread CFileCache start, auto delete: false
Posted: Fri Mar 29, 2013 9:50 pm
by smshiera
TheQuestor wrote: then sudo dpkg -i xbmc_84-1_armhf.deb
ldconfig: Can't link //usr/lib/xbmc/system/players/dvdplayer//devel/xbmc/system/players/dvdplayer/libdvdcss-arm.so to libdvdcss-arm.so
ldconfig: Can't link //usr/lib/xbmc/system/players/dvdplayer//devel/xbmc/system/players/dvdplayer/libdvdnav-arm.so to libdvdnav-arm.so
why?
Posted: Sat Mar 30, 2013 12:43 am
by TheQuestor
I just did a fresh install of 2013-02-09-wheezy-raspbian.img and did an
sudo apt-get update && sudo apt-get dist-upgrade && sudo apt-get install git-core libmicrohttpd10 libtinyxml2.6.2 libmysqlclient18 liblzo2-2 libpcrecpp0 libsdl1.2debian libhal1 libhal-storage1 libva1 libva-glx1 libyajl-dev libssh-dev libfribidi-dev && sudo wget http://goo.gl/1BOfJ -O /usr/bin/rpi-update && sudo chmod +x /usr/bin/rpi-update && sudo rpi-update and then rebooted
then downloaded XBMC_Raspi_be6d3a7.tgz
you probably will see
but it doesn't effect the usage, seems to be an artifact from the makepackage
but I will work on resolving THAT as soon as I can track down people having problems just launching it.
It was compiled with hard float and I haven't tested it on older versions of the wheezy img
http://www.sshcs.com/xbmc/img/rpi-xbmc.JPG
I had no issues running it
Posted: Sat Mar 30, 2013 3:28 am
by smshiera
TheQuestor wrote:I just did a fresh install of 2013-02-09-wheezy-raspbian.img and did an
after reboot,,,i get a black window,cant enter 'startX'
Posted: Sat Mar 30, 2013 3:33 am
by TheQuestor
nothing there should cause that issue. You "are" running wheezy right?
Posted: Sat Mar 30, 2013 3:56 am
by smshiera
TheQuestor wrote: nothing there should cause that issue. You "are" running wheezy right?
yes,wheezy20130209,i'll try it again after lunch
Posted: Sun Mar 31, 2013 12:04 am
by TheQuestor
any luck?
Posted: Sun Mar 31, 2013 9:13 am
by smshiera
TheQuestor wrote: any luck?
I just copy and paste your steps ,this time it showed the desktop ,
then crash,after reboot ,black window again,
i dont know whats wrong,
Posted: Thu Apr 11, 2013 5:57 am
by heiNey
   sudo apt-get update
got xbmc installed using this, but it doesn't respond to any keyboard presses. i've tried two different keyboards already and makes no difference.
any ideas?
Posted: Thu Apr 11, 2013 7:07 am
by TheQuestor
   sudo apt-get update
any ideas?
Sorry no. That's Team XBMC's build, you would need to ask them :(
http://forum.xbmc.org/
Posted: Sat Apr 13, 2013 10:06 am
by aht961
Try this:
"...setup some udev rules to grant it ownership of input devices (otherwise the keyboard won't work in XBMC), by placing the following in /etc/udev/rules.d/99-input.rules:
SUBSYSTEM=="input", GROUP="input", MODE="0660"
More here: http://michael.gorven.za.net/raspberrypi/xbmc
Posted: Wed May 01, 2013 7:42 pm
by TheRealLoon
Just tried with:
sudo apt-get update
But fails at:
With:
The following packages have unmet dependencies:
xbmc : Depends: xbmc-bin (>= 2:11.0~git20120510.82388d5-1) but it is not installable
Depends: xbmc-bin (< 2:11.0~git20120510.82388d5-1.1~) but it is not installable
Recommends: python-qt3 but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
Odd thing is that it worked 2 days ago. Any help would be appreciated.
Posted: Wed May 01, 2013 10:23 pm
by TheQuestor
TheRealLoon wrote:Just tried with:
sudo apt-get update
But fails at:
With:
I can't tell you for sure on his builds but on mine [http://www.sshcs.com/xbmc] I would just do a apt-get remove xbmc xbmc-bin [enter] then do an apt-get install xbmc. But mine are deb packages.
Posted: Thu May 02, 2013 12:22 am
by TheRealLoon
Tried your deb and all went fine on install but when I launch it I get:
XBMC needs hardware accelerated OpenGL rendering.
Install an appropriate graphics driver.
Please consult XBMC Wiki for supported hardware
bla bla bla .......
Note: the download offered for raspberry pi was a4130c1, I did edit appropriately.
Posted: Thu May 02, 2013 12:34 am
by TheQuestor
TheRealLoon wrote:Tried your deb and all went fine on install but when I launch it I get:
bla bla bla .......
It does that because it's launching xbmc which looks for a GL wrapper. if you press any key when it says to press any key it will load anyway, or change the link to launch xbmc-bin which doesn't look for the GL wrapper.
