Ale28
[Help needed] bluealsa with apt-x Support
Wed Jul 03, 2019 8:56 pm
Hello dear Raspberry Community
I just bought a Pi 3B+ and firstly was satisfied of the possibilities but now I'm not comming further.
(OS is installed thorugh noobs)
I want to create an audio receiver for an old but qualitative hifi Device I am repairing right now.
Sadly I tried a lot and read a lot in the Internet but did not achieve what I want.
These are some of my sources:
https://github.com/Samt43/BluetoothAPTXForLinux
https://news.ycombinator.com/item?id=16889003
https://github.com/pali/libopenaptx
https://github.com/Arkq/bluez-alsa/issues/92
So theres somehow a way to use the aptx codec on Raspberry with the internal bluetooth module...
I installed pulseaudio first for an other application, then bluealsa and some libs.
After that I had no sound at all. So I removed these two and installed again. Now I had normal sound.
But bluetooth did not work anyway. I was able to connect sometimes but mostly there was a bluez.org error.
But even if I was able to connect I was not able to play any sound over it, but it identified itself as an audio receiver on my phone.
So I didnt even get an SBC receiver, I also never saw the apt-x option.
after trying everything I found on the Internet I thought I'll try it here.
I'm not bad with technics but just rarely used Linux yet. So if you know what's my problem or how to solve it I
would be happy if you could explain it detailled.
Thank you anyway!
Have a good day!
Greetings from Switzerland
-Ale
Douglas6
Re: [Help needed] bluealsa with apt-x Support
Wed Jul 03, 2019 10:04 pm
You'll need to decide on BlueALSA or PulseAudio; they WILL conflict with one another. BlueALSA is easiest, but I don't think it supports an AptX sink (https://github.com/Arkq/bluez-alsa/issues/142). I don't know about later versions of PulseAudio, but you'll need to uninstall BlueALSA first.
Return to “Media centres”
