rpmosca
[Solved] Help attempting to watch live tv on kodi
Tue Jan 08, 2019 11:07 am
Hi, I have kodi 18 working on the raspberry with raspbian
I can't get my Avermedia Volar Green HD to work. (It's a835 / AFATECH AF9035 )
I have it working on Manjaro 4.19 on my desktop PC but I wanted to use it on the raspberry with kodi. (I have the 3B+ with raspbian 4.14.79-v7+ )
I already tried this tutorial with no success to compile the driver: https://debian-facile.org/doc:materiel:dvb:af9035
I copied the firmware to /lib/firmware/ from here: https://www.linuxtv.org/wiki/index.php/AVerMedia
As it didn't work, I deleted files and folders that were created when compiling the above mentioned.
I also noticed some warnings and errors on dmesg when I plug it in (with and without drivers compiled):
[  186.102736] usb 1-1.1.3: new high-speed USB device number 7 using dwc_otg
[  186.248209] usb 1-1.1.3: New USB device found, idVendor=07ca, idProduct=a835
[  186.248227] usb 1-1.1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  186.248236] usb 1-1.1.3: Product: A835
[  186.248245] usb 1-1.1.3: Manufacturer: AVerMedia TECHNOLOGIES, Inc
[  186.248253] usb 1-1.1.3: SerialNumber: 3031582017170
[  186.326454] media: loading out-of-tree module taints kernel.
[  186.331533] media: Linux media interface: v0.10
[  186.364969] videodev: Linux video capture interface: v2.00
[  186.364987] WARNING: You are using an experimental version of the media stack.
               	As the driver is backported to an older kernel, it doesn't offer
               	enough quality for its usage in production.
               	Use it with care.
               Latest git patches (needed if you report a bug to linux-media@vger.kernel.org):
               	4bd46aa0353e022c2401a258e93b107880a66533 media: cx23885: only reset DMA on problematic CPUs
               	bbb55cd708901dedbeeeb929c7012f35afea7882 media: ddbridge: Move asm includes after linux ones
               	daad52c8aa4fcf27d2e8b69daf851d82c141fd2f media: drxk_hard: check if parameter is not NULL
[  186.387104] dvb_core: disagrees about version of symbol vb2_vmalloc_memops
[  186.387115] dvb_core: Unknown symbol vb2_vmalloc_memops (err -22)
Any ideas on how to get it work?
Thank you!
default_user8
Re: Help attempting to watch live tv on kodi
Tue Jan 08, 2019 1:43 pm
My suggestion is to do your research and use a tuner that is known to work with kodi and a raspberry pi. I used a Hauppauge WinTV HVR-950Q, and a Hauppauge WinTV HVR-950 with libreelec without any issues. From your post getting that tuner to work will require a bit more effort than it would take to get a tried and true tuner off EBAY. Good luck.
Two heads are better than one, unless one's a goat head.
Rascas
Tue Jan 08, 2019 5:49 pm
I have done that for a similar if not the same tuner some time ago. I believe that you only need the correct firmware file. You can copy it/them from https://github.com/LibreELEC/dvb-firmwa ... r/firmware to /lib/firmware/
rpmosca
Tue Jan 08, 2019 7:41 pm
default_user8 wrote: My suggestion is to do your research and use a tuner that is known to work with kodi and a raspberry pi. I used a Hauppauge WinTV HVR-950Q, and a Hauppauge WinTV HVR-950 with libreelec without any issues. From your post getting that tuner to work will require a bit more effort than it would take to get a tried and true tuner off EBAY. Good luck.
I have thought about it but I'll try to find a solution and leave that as a last option.
Rascas wrote: I have done that for a similar if not the same tuner some time ago. I believe that you only need the correct firmware file. You can copy it/them from https://github.com/LibreELEC/dvb-firmwa ... r/firmware to /lib/firmware/
I copied and rebooted, but I'm getting same error with the dmesg command.
Rascas
Tue Jan 08, 2019 7:59 pm
If you still get the same messages on dmesg, it is because you are still using your own compiled module. Remove it, or start fresh, you just need the firmware which I linked above.
rpmosca
Tue Jan 08, 2019 8:20 pm
I was able to solve that error!
[    5.152467] usb 1-1.3: dvb_usb_v2: 'AVerMedia AVerTV Volar HD/PRO (A835)' successfully initialized and connected
The only thing I did was updating the firmware of the raspberry with this:
sudo rpi-update
Rascas wrote: If you still get the same messages on dmesg, it is because you are still using your own compiled module. Remove it, or start fresh, you just need the firmware which I linked above.
I had removed it before just when I saw that compilation didn't work, but I copied your files too. And the error was gone. (I also copied some files from my Arch linux firmware just in case, but I think it was the same firmware you provided in the link)
Edit: Live TV works perfectly with Kodi + Tvheadend.
Return to “Media centres”
