BFG
5.1 sound over optical, from Netflix and Prime
Wed Dec 05, 2018 7:35 pm
Sorry if this is a question that's too specific. I have a Raspberry that I bough for one project and now it's surplus to requirements, so I might try and build it as a media player.
A problem I have is that my 10yr old AV receiver only has an optical input, so it can handle DTS and Dolby Digital, but not Dolby Digital Plus.
I've just returned a Nvidia Shield, which I believe is based on Kodi, because Netflix and Prime have been built to not support any 5.1 standard earlier than Dolby Digital Plus. I know the rig is set up right because Plex from the Nvidia Shield gives DTS 5.1 in full.
But, netflix and prime come through in PCM 2.0.
Before I start a long path of learning, does anyone know of a platform I can use on the Pi where netflix + prime apps have licenced Dolby Digital?
Edit: I should mention that I have a hardware HDMI switch that can extract optical audio.
Re: 5.1 sound over optical, from Netflix and Prime
Wed Dec 05, 2018 7:50 pm
The nVidia Shield TV Box runs Android TV OS, whilst the Shield Tablet runs Android OS.
Netflix and Amazon Prime require DRM and the Raspberry Pi SBC is not a "Trusted Platform"
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
BFG
Wed Dec 05, 2018 8:07 pm
Thank you fruitoftheloom, you've saved me a lot of heartache and possibly others will find this thread useful too.
I'll think of a different project for my pi. Maybe home automation.
noggin
Sun Dec 09, 2018 10:17 am
Off topic - but to answer the OP's question - I'd check both the Apple TV and the Amazon Fire TV for Dolby Digital (not DD+) compatibility with Netflix and Amazon.
I'm pretty certain the Apple TV will output legacy Dolby Digital and I have a feeling the Fire TV may do too. The new Fire TV Stick 4K and the Pendant both support frame rate switching in some apps. The Apple TV 4 and 4K both support frame rate switching too (which is important to avoid judder when playing content shot at different frame rates)
Return to “Media centres”
