Doogals
Dual Screen In-Car Setup (Pi 3)
Fri Mar 09, 2018 12:49 am
Currently setting up a Pi 3 being used in a dual screen in-car entertainment system running Kodi.
I purchased two 10.1” (1024x600) portable car DVD players than can share the same HDMI video source via a composite video cable connecting the two screens:
https://www.amazon.ca/Super-Thin-Headre ... B01GRKBUPU
I’m trying to decide between using the composite video cable to split the source between the screens, or using a HDMI splitter so both screens get a digital signal directly from the Pi 3.
Also, if I’m not mistaken the Pi 3 can not output to two HDMI displays at the same time? So a HDMI splitter would be required to achieve this.
Any thoughts or suggestions would be greatly appreciated, thanks.
Imperf3kt
Re: Dual Screen In-Car Setup (Pi 3)
Fri Mar 09, 2018 4:18 am
I've seen plenty of splitters that convert multiple sources into one output so they can share one monitor, but alas, the reverse is not so straightforward.
I don't think such a product actually exists for HDMI.
55:55:44:44:4C
52:4C:52:42:41
Mortimer
Fri Mar 09, 2018 6:53 am
https://www.commsandsound.com/avlink-hd ... r-1x2.html
AVLINK HDS12 - 4K HDMI SPLITTER 1X2
4K HDMI splitter to connect a single HDMI source to multiple displays at the same time. Use with HDMI cables of a combined 25m per output for HD resolution, or a combined 16m per output for 4K resolution, without signal loss.
Looks to be about £25.
The purpose of a little toe is to ensure you keep your furniture in the right place.
Doogals
Fri Mar 09, 2018 1:13 pm
HDMI video splitters definitely do exist, as pointed out by Mortimer, but I’m wondering if a digital vs analong signal would even make a difference at 1024x600?
Return to “Media centres”
