mcgyver83
Music media center with wireless speaker
Mon Jun 05, 2017 7:56 am
Hi all, I'm using a raspberry pi2 with OpenMediaVault to have a personal nas.
I have a LG wireless speaker http://www.expertreviews.co.uk/tvs-ente ... -h7-review and I want to use the raspberry to stream audio from an attached usb hdd to my wireless speaker?
Is it possibile? I red about Volumio but I cannot flash a full image, I need to install manually some software.
Any suggestion?
flatmax
Re: Music media center with wireless speaker
Mon Jun 05, 2017 12:23 pm
Does your speaker support DLNA ?
If it does, then here is one scenario :
1] Setup a dlna server on your pi (such as minidlna - if it will work for you then sudo apt-get install minidlna) and configure the server as required.
2] Use an app on your phone - a dlna controller - to ask the Pi to send audio to the speaker. You should see both pop up in your dlna application.
Matt
Discuss hearing, acoustics, audio injector products, - https://lists.audioinjector.net/mailman/listinfo/people
Sound card for the Raspberry Pi with inbuilt microphone : www.audioinjector.net
Audio Inector Octo multitrack GPIO sound card
mcgyver83
Mon Jun 05, 2017 2:06 pm
I'm running minidlna for video share, so no problem to setup also music dlna share ;)
The speaker is DLNA compliant.
Do you now an android app I could use to control the DLNA server running on raspberry and use the speaker to play music?
flatmax
Tue Jun 06, 2017 9:30 am
There are lots !
Allconnect is ok, I like it.
Matt
mcgyver83
Tue Jun 06, 2017 12:59 pm
Many thanks.
I checked and also LG MusicFlow app is able to handle music from a remote DLNA server.
I'm still looking for something more dedicated like Volumio to handle my music but miniDlna is still fine (maybe I could try Plex also for music stuff).
Return to “Media centres”
