gamerforever
Re: Kodi on Ubuntu MATE 15.10
Tue Apr 26, 2016 10:11 am
Kratos wrote:It works until the checkinstall part. It can't find some language packs, so it exits. Kodi works great, but I can't figure out how to make a .deb file for you guys.
Kratos
I'm gonna wait until you find out how to get a .deb as I've tried it multiple times and I don't seem to get it working :D
Maybe this helps you Kratos? https://community.linuxmint.com/tutorial/view/162
Kratos
Mon May 02, 2016 2:17 pm
I successfully built it. Updated instructions coming.
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
Kratos
Mon May 02, 2016 2:26 pm
Alright, I need some beta testers. These packages should work on both Ubuntu MATE 16 and 15. Try it yourself by downloading these packages:
https://drive.google.com/file/d/0B2vdsV ... RCcG8/view -Kodi 17 ALPHA
https://drive.google.com/file/d/0B2vdsV ... ViRlE/view -Kodi 16.1
Kodi 17 was compiled as follows:
  Kodi Configuration:
  Kodi Version:	17.0-ALPHA1
  git Rev.:	20160430-c172ddf
  Debugging:	Yes
  Profiling:	No
  Optimization:	Yes
  SWIG Available:	Yes
  JRE Available:	Yes
  Doxygen Available:	Yes
  Crosscomp.:	No
  target ARCH:	arm
  target CPU:	arm1176jzf-s
  OpenGLES:	Yes
  ALSA:		Yes
  DBUS:		No
  VDPAU:	No
  VAAPI:	No
  VTBDecoder:	No
  OpenMax:	No
  X11:		No
  Bluray:	Yes
  TexturePacker:Yes
  MID Support:	No
  ccache:	Yes
  ALSA Support:	Yes
  PulseAudio:	No
  Google Test Framework Configured:	Yes
  Google Breakpad Configured:	No
  Avahi:	No
  mDNSEmbedded:	No
  Non-free:	Yes
  MySQL:	Yes
  Webserver:	Yes
  libssh support:	Yes
  libRTMP support:	Yes
  libsmbclient support:	Yes
  libnfs client support:Yes
  AirPLay support:	No
  AirTunes support:	No
  UPnP support:		Yes
  Optical drive:	Yes
  libudev support:	Yes
  libusb support:	No
  libcec support:	Yes
  libbluetooth support:	Yes
  libcap support:	Yes
  additional players:	Yes, omxplayer
  additional codecs:	No
  prefix:	/usr/local
Kodi 16.1 was compiled as follows:
  Kodi Configuration:
  Kodi Version:	16.1
  git Rev.:	20160426-4982009
  Debugging:	No
  Profiling:	No
  Optimization:	Yes
  SWIG Available:	Yes
  JRE Available:	Yes
  Crosscomp.:	No
  target ARCH:	arm
  OpenGLES:	Yes
  ALSA:		Yes
  DBUS:		No
  VDPAU:	No
  VAAPI:	No
  VTBDecoder:	No
  OpenMax:	No
  Joystick:	No
  Touch skin:	No
  X11:		No
  Wayland:	No
  Bluray:	Yes
  TexturePacker:Yes
  MID Support:	No
  ccache:	Yes
  ALSA Support:	Yes
  PulseAudio:	No
  DVDCSS:	Yes
  Avahi:	No
  mDNSEmbedded:	No
  Non-free:	Yes
  ASAP Codec:	No
  MySQL:	Yes
  Webserver:	Yes
  libssh support:	Yes
  libgif support:	Yes
  AirPLay support:	No
  UPnP support:		Yes
  Optical drive:	Yes
  libusb support:	No
  libcec support:	Yes
  libcap support:	Yes
  prefix:	/usr/local
Install Kodi 16 with the following command after you download the file:
sudo gdebi -n xbmc_16.1-1_armhf.deb
Kodi 17:
sudo gdebi -n kodi_17.0-ALPHA1-1_armhf.deb
Tell me if it works! :ugeek:
Kratos
Kratos
Mon May 02, 2016 11:14 pm
It seems that you need these dependencies installed:
libmicrohttpd10 libmysqlclient-dev libtinyxml-dev libpcrecpp0v5
Tell me if you have issues. :D
Kratos
cjan
Tue May 03, 2016 3:55 am
does it is a problem when enable-openmax ?
Snze
Tue May 10, 2016 6:51 am
Kratos, you are a star! This is working really well! First issue I've encountered is that it freezes the pi on a black screen when trying to exit the app - is this the same for you?
Kratos
Tue May 10, 2016 2:48 pm
Yes, it does have the black screen bug. I worked on a fix, and shall show you how to fix it in a bit.
Kratos
Kratos
Tue May 10, 2016 2:49 pm
cjan wrote:does it is a problem when enable-openmax ?
What would be the benefit of doing so?
Kratos
Snze
Wed May 11, 2016 11:45 am
Kratos wrote:Yes, it does have the black screen bug. I worked on a fix, and shall show you how to fix it in a bit.
Kratos
:P. Awesome! Whenever you get a minute that would be great (you tease!)
Let me know if there's anything you'd like me to test, and I'll try to help.
Kratos
Wed May 11, 2016 2:17 pm
Black screen bug fix:
1. Create a startkodi script
sudo nano startkodi
2. Paste this into it:
#!/bin/bash
fbset_bin=`which fbset`
xset_bin=`which xset`
xrefresh_bin=`which xrefresh`
if [ ! -z $fbset_bin ]; then
  DEPTH2=`$fbset_bin | head -3 | tail -1 | cut -d " " -f 10`
fi
kodi "$@"
  if [ "$DEPTH2" == "8" ]; then
    DEPTH1=16
  else
    DEPTH1=8
  fi
  $fbset_bin -depth $DEPTH1 > /dev/null 2>&1
  $fbset_bin -depth $DEPTH2 > /dev/null 2>&1
fi
if [ ! -z $xset_bin ] && [ ! -z $xrefresh_bin ]; then
  if [ -z $DISPLAY ]; then
    DISPLAY=":0"
  fi
  $xset_bin -display $DISPLAY -q > /dev/null 2>&1
    if [ "$?" == "0" ]; then
      $xrefresh_bin -display $DISPLAY > /dev/null 2>&1
    fi
fi
VT="$(fgconsole)"
if [ "$VT" ]; then
  sudo chvt 7
  sudo chvt "$VT"
fi
3. Make it executable:
sudo chmod +x startkodi
4. Copy to /usr/local/bin
sudo cp startkodi /usr/local/bin
Create a desktop file:
1.
sudo nano Desktop/kodi.desktop
[Desktop Entry]
Version=1.0
Name=Kodi Media Center
GenericName=Media Center
Comment=Manage and view your media
Exec=startkodi %u
Icon=kodi
Terminal=false
Type=Application
Categories=AudioVideo;Video;Player;TV;
3. Copy to applications:
sudo cp kodi.desktop /usr/share/applications
If it works, tell me ;) .
Kratos
Snze
Wed May 11, 2016 4:32 pm
Nice one, Kratos! Yes, it works... only stumbling block I hit was -
should it be?
sudo cp /Desktop/kodi.desktop /usr/share/applications
Only slight downer (and it is slight) is that you have to 'repaint' the desktop back in (if you see what I mean)... screen goes black, but as you lasso areas of the screen with a held mouse button, the background and taskbar reappear. Better that than a hard reset, though - great stuff :D
Snze
Wed May 11, 2016 4:34 pm
...oh, and if I was being really fussy, I'd substitute pluma for nano in your instructions, cos noobs like me struggle with nano :oops:
Snze
Wed May 11, 2016 11:37 pm
More feedback!
I've been trying Kodi 17 and it's supersmooth, but crashed hard when I tried to scan movies to the library (only about a dozen); from that point I could only get to the splash before it crashed again. I had to delete /.kodi to get it to get it to start again. I have a crashlog, if you can advise how to get it to you? EDIT: here.
I've also found a quick way around the blank screen/paint your desktop back in problem: switching to another tty and back to tty7 (ctrl + alt + F6, then ctrl + alt + F7); I was power cycling before :?
Some problems playing certain mkv files, but I don't know if that's a pi codec issue; would mediainfo output help?
Kratos
Thu May 12, 2016 12:59 pm
Thanks a lot for all your testing! I took a look at your log file, and it seems as if it is a Kodi 17 bug. All your dependencies were installed. I think it must just be a Kodi 17 bug, but I am not sure. As far as the black screen bug lasso thing, I have had this happen on Raspbian Jessie a few times, but never on Ubuntu MATE. I shall see if I can duplicate the problem.
Kratos
Snze
Thu May 12, 2016 1:37 pm
No worries; excited to be able to help.
Fwiw, the lasso effect happens with marco with and without compositing - I've not tested compiz.
Thanks for checking the crashlog; understandable that there's still some kinks to be worked out with the kodi 17 alpha, to be fair. Subjectively though, it does seem to run a bit quicker than the Jarvis build, and I do love the new default skins, esp estouchy; nice and wife friendly :)
By the way, is there a way of installing the 16 and 17 builds at the same time? I had 16, then installed the 17 .deb, but it didn't 'take', so I uninstalled 16 to add 17.
Incidentally, did you spot that Wimpy on the mate forum was asking about working with you and setting up a ppa? That would be boss... :D
Snze
Thu May 12, 2016 5:42 pm
Strike my previous comment about certain files not playing in Kodi 17... just needed to set gpu_mem=128 in the memory settings section of /boot/.config.txt - you lose a little memory in desktop use I guess, but a fair trade off to get 1080p working!
Kratos
Thu May 12, 2016 5:47 pm
Cool! Thanks for the pm, I had not seen that link. Back to testing. :D
Kratos
Kratos
Thu May 12, 2016 5:49 pm
Will compile a new version sometime this weekend with the shairplay enabled. Hopefully I will also find a better fix for the black screen bug as well.
Kratos
Snze
Fri May 13, 2016 3:30 pm
Kratos wrote: I think it must just be a Kodi 17 bug, but I am not sure.
Sorry Kratos, I think the library creation issue runs deeper, as it does the same thing (for me, at least) on Jarvis... :(
Log here.
Don't know whether Wimpy's build has the same issue; I'll beg him for a .deb and compare...
Kratos
Fri May 13, 2016 4:15 pm
AHA! Could you install libcec on your system.
sudo apt-get install libcec
I am not sure, but it looks like that is the issue...
Kratos[/s]
Scratch that.
Your log says:
Program terminated with signal SIGSEGV, Segmentation fault.
I have no idea why though...
Kratos
Kratos
Fri May 13, 2016 4:21 pm
Potential fix lifted from Google:
- In kodi, go to Settings -> Video -> Acceleration
- Set Deconding method to Software
Kratos
Snze
Fri May 13, 2016 4:39 pm
I can't see that option? Settings (on expert level) > Video > Acceleration gives me the option to allow/disallow OMXPlayer and MMAL acceleration, limit GUI updates during playback and reset to default...
Interestingly, leaving MMAL & OMXplayer acceleration unticked made no difference to 1080p playback, but Kodi 16 still crashed when I tried to add a single film to the library...
Kratos
Fri May 13, 2016 4:51 pm
Wierd. That is all I can say. Hope fully Wimpy can save us :D . Building Kodi a bit differently this time, we shall see if it works.
Kratos
Snze
Fri May 13, 2016 5:12 pm
Yep - it's rum alright. I even tried creating the library on a windows install, exporting it then importing it into yours… no dice, unfortunately. I guess having the library enabled requires kodi to configure quite a bit to get skin integration etc. Will keep googling, though :) (but not tonight - it's my wedding anniversary, and hunching over a little box with flickering lights in the 'man-cave' is not considered romantic, for some reason!)
Kratos
Sat May 14, 2016 1:41 pm
Snze wrote:Yep - it's rum alright. I even tried creating the library on a windows install, exporting it then importing it into yours… no dice, unfortunately. I guess having the library enabled requires kodi to configure quite a bit to get skin integration etc. Will keep googling, though :) (but not tonight - it's my wedding anniversary, and hunching over a little box with flickering lights in the 'man-cave' is not considered romantic, for some reason!)
Happy anniversary!
I am currently working on organizing all the files. I will then upload them all to Google Drive for you all to try out. I successfully completed builds of Kodi 16 and 17 for both Ubuntu MATE 15 and 16. On Jarvis, I had no issues adding Music to the library.
Kratos
Return to “Media centres”
