cjan
Re: Kodi on Ubuntu MATE 15.10
Tue Aug 16, 2016 7:05 am
Kratos wrote:I wasn't sure what it was in the end, but, I fixed the library issue by not upgrading a stock install of Ubuntu MATE. Kodi is now updated to 17 Beta 1. I included the startkodi script in the build, so manually patching will be easier.
Kratos
does this build start with VC4 & window mode?
Kratos
Tue Aug 16, 2016 12:39 pm
Unfortunately, windowed mode does not work. It would require using the somewhat unstable GL driver. I messed around with windowed mode a while back just for fun, and I could not get it to work. Does this build start with VC4? I am not sure what VC4 is, so I have no idea :D .
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
cjan
Tue Aug 16, 2016 1:13 pm
Kratos wrote:Unfortunately, windowed mode does not work. It would require using the somewhat unstable GL driver. I messed around with windowed mode a while back just for fun, and I could not get it to work. Does this build start with VC4? I am not sure what VC4 is, so I have no idea :D .
Kratos
make sure mesa-11.2.2 updated
https://www.youtube.com/watch?v=7GjyfJgaDTs
mandril420
Tue Aug 30, 2016 11:21 am
**FIXED** on video playback settings turned off MMAL hardware acceleration and turned on OWXplayer hardware acceleration. Works like a charm!!
Hi Kratos. Can you give me a hand with this? I am almost there. I have Ubuntu Mate 16.04 on my Raspberry Pi 3 and I have followed your instructions and installed kodi 17.0 beta 1. I can run Kodi get into the Kodi homescreen, select a movie but when I try to play a movie it crashes to a black screen. Then I can "repaint" the desktop with my mouse. I am almost there!! Please help me fix it.
Here is my kodi crashlog
https://www.dropbox.com/s/939frfb3t1qeq ... 7.log?dl=0
Thanks so much!
Kratos
Wed Aug 31, 2016 1:43 pm
Great! Glad you were able to fix it.
Kratos
Meidhy
Re: Kodi on Ubuntu MATE 16
Sat Sep 10, 2016 1:59 pm
hi,
i followed your guide on page 1, kodi works a moment, then i imported my films etc, during import kodi bug, and i never success to open it again..kodi start i have the picture with logo and after that the app crash, black screen and come back on the desktop..
see follow the crashlog..please Help me
############## Kodi CRASH LOG ###############
################ SYSTEM INFO ################
Date: samedi 10 septembre 2016, 15:46:47 (UTC+0200)
Kodi Options:
Arch: armv7l
Kernel: Linux 4.4.19-v7+ #906 SMP Tue Aug 23 15:53:06 BST 2016
Release: Ubuntu 16.04.1 LTS (Xenial Xerus)
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/meidhy/core (2016-09-10 15:46:46.950998882 +0200)
[New LWP 3388]
[New LWP 3380]
[New LWP 3390]
[New LWP 3389]
[New LWP 3391]
[New LWP 3379]
[New LWP 3392]
[New LWP 3394]
[New LWP 3398]
[New LWP 3403]
[New LWP 3393]
[New LWP 3399]
[New LWP 3402]
[New LWP 3396]
[New LWP 3400]
[New LWP 3405]
[New LWP 3395]
[New LWP 3406]
[New LWP 3397]
[New LWP 3408]
[New LWP 3401]
[New LWP 3409]
[New LWP 3410]
[New LWP 3378]
[New LWP 3404]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/arm-linux-gnueabihf/libthread_db.so.1".
Core was generated by `/usr/local/lib/kodi/kodi.bin'.
Program terminated with signal SIGSEGV, Segmentation fault.
#0 0x00434722 in std::_Rb_tree_iterator<std::pair<Field const, CVariant> > std::_Rb_tree<Field, std::pair<Field const, CVariant>, std::_Select1st<std::pair<Field const, CVariant> >, std::less<Field>, std::allocator<std::pair<Field const, CVariant> > >::_M_emplace_hint_unique<std::piecewise_construct_t const&, std::tuple<Field&&>, std::tuple<> >(std::_Rb_tree_const_iterator<std::pair<Field const, CVariant> >, std::piecewise_construct_t const&, std::tuple<Field&&>&&, std::tuple<>&&) ()
[Current thread is 1 (Thread 0x6d96f3f0 (LWP 3388))]
Thread 25 (Thread 0x67eff3f0 (LWP 3404)):
#0 0x76b72456 in __libc_do_syscall () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0x76b70ee8 in open64 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0x769e30ae in ?? () from /usr/lib/arm-linux-gnueabihf/libpython2.7.so.1.0
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Thread 24 (Thread 0x72ee6000 (LWP 3378)):
#0 0x75f84c08 in socketpair () from /lib/arm-linux-gnueabihf/libc.so.6
#1 0x0097ac90 in NPT_BsdSocket::NPT_BsdSocket(int, unsigned int) ()
#2 0x0097af48 in NPT_BsdUdpSocket::NPT_BsdUdpSocket(unsigned int) ()
#3 0x0097affe in NPT_BsdUdpMulticastSocket::NPT_BsdUdpMulticastSocket(unsigned int) ()
#4 0x0097b080 in NPT_UdpMulticastSocket::NPT_UdpMulticastSocket(unsigned int) ()
#5 0x011f196c in PLT_CtrlPoint::CreateSearchTask(NPT_HttpUrl const&, char const*, unsigned int, NPT_TimeStamp, NPT_IpAddress const&) ()
#6 0x011f1dee in PLT_CtrlPoint::Search(NPT_HttpUrl const&, char const*, unsigned int, NPT_TimeStamp, NPT_TimeStamp) ()
#7 0x011f162e in PLT_CtrlPoint::Start(PLT_SsdpListenTask*) ()
#8 0x01205018 in PLT_UPnP::AddCtrlPoint(NPT_Reference<PLT_CtrlPoint>&) ()
#9 0x009b7516 in UPNP::CUPnP::StartClient() ()
#10 0x009ea8ee in CNetworkServices::StartUPnPClient() ()
#11 0x009eaa76 in CNetworkServices::StartUPnP() ()
#12 0x009ead3c in CNetworkServices::Start() ()
#13 0x008fa6a0 in CApplication::OnApplicationMessage(KODI::MESSAGING::ThreadMessage*) ()
#14 0x007a25d8 in KODI::MESSAGING::CApplicationMessenger::ProcessMessage(KODI::MESSAGING::ThreadMessage*) ()
#15 0x007a297e in KODI::MESSAGING::CApplicationMessenger::ProcessMessages() ()
#16 0x008fbff0 in CApplication::Process() ()
#17 0x0095dddc in CXBApplicationEx::Run() ()
#18 0x007a122e in XBMC_Run ()
#19 0x0036beb6 in main ()
Thread 23 (Thread 0x64eff3f0 (LWP 3410)):
#0 0x76b72454 in __libc_do_syscall () from /lib/arm-linux-gnueabihf/libpthread.so.0
#1 0x76b6e02a in pthread_cond_timedwait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0x0097c974 in NPT_PosixSharedVariable::WaitUntilEquals(int, int) ()
#3 0x011f5070 in PLT_CtrlPointHouseKeepingTask::DoRun() ()
#4 0x0098dc82 in PLT_ThreadTask::Run() ()
#5 0x0097cb10 in NPT_PosixThread::EntryPoint(void*) ()
#6 0x76b695a4 in start_thread () from /lib/arm-linux-gnueabihf/libpthread.so.0
#7 0x75f83cec in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
Thread 22 (Thread 0x656ff3f0 (LWP 3409)):
#0 0x75f7f572 in select () from /lib/arm-linux-gnueabihf/libc.so.6
#1 0x00000000 in ?? ()
Thread 21 (Thread 0x6a70e3f0 (LWP 3401)):
#2 0x00806658 in PERIPHERALS::CPeripheralBus::Process() ()
#3 0x01233a30 in CThread::Action() ()
#4 0x01233c14 in CThread::staticThread(void*) ()
#5 0x76b695a4 in start_thread () from /lib/arm-linux-gnueabihf/libpthread.so.0
#6 0x75f83cec in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
Thread 20 (Thread 0x65eff3f0 (LWP 3408)):
Thread 19 (Thread 0x6c7ff3f0 (LWP 3397)):
#1 0x76b6ddaa in pthread_cond_wait@@GLIBC_2.4 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0x009d8342 in COMXImage::Process() ()
Thread 18 (Thread 0x66eff3f0 (LWP 3406)):
#0 0x75f234b2 in vfprintf () from /lib/arm-linux-gnueabihf/libc.so.6
#1 0x75f8daf6 in __vsnprintf_chk () from /lib/arm-linux-gnueabihf/libc.so.6
#2 0x003be4f8 in StringUtils::FormatV[abi:cxx11](char const*, std::__va_list) ()
#3 0x003be5c0 in StringUtils::Format[abi:cxx11](char const*, ...) ()
#4 0x009528ca in CURL::Encode(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#5 0x00a6031a in CUrlOptions::GetOptionsString[abi:cxx11](bool) const ()
#6 0x0090ad58 in CDbUrl::updateOptions() ()
#7 0x0090b0f4 in CDbUrl::AddOption(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#8 0x00a60034 in CUrlOptions::AddOptions(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#9 0x0090b3a4 in CDbUrl::AddOptions(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#10 0x00422062 in CVideoDbUrl::parse() ()
#11 0x0090ae54 in CDbUrl::FromString(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) ()
#12 0x00672982 in CDatabase::BuildSQL(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, CDatabase::Filter&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >&, CDbUrl&, SortDescription&) ()
#13 0x004123e6 in CVideoDatabase::GetTvShowsByWhere(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, CDatabase::Filter const&, CFileItemList&, SortDescription const&, int) ()
#14 0x004192b6 in CVideoDatabase::GetItems(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, CFileItemList&, CDatabase::Filter const&, SortDescription const&) ()
#15 0x00709eaa in XFILE::CSmartPlaylistDirectory::GetDirectory(CSmartPlaylist const&, CFileItemList&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool) ()
#16 0x0070b0f0 in XFILE::CSmartPlaylistDirectory::GetDirectory(CURL const&, CFileItemList&) ()
#17 0x006da69c in XFILE::CDirectory::GetDirectory(CURL const&, CFileItemList&, XFILE::CDirectory::CHints const&, bool) ()
#18 0x006dba48 in XFILE::CDirectory::GetDirectory(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, CFileItemList&, XFILE::CDirectory::CHints const&, bool) ()
#19 0x006dbb48 in XFILE::CDirectory::GetDirectory(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, CFileItemList&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int, bool) ()
#20 0x007a01f4 in CDirectoryJob::DoWork() ()
#21 0x00a23098 in CJobWorker::Process() ()
#22 0x01233a30 in CThread::Action() ()
#23 0x01233c14 in CThread::staticThread(void*) ()
#24 0x76b695a4 in start_thread () from /lib/arm-linux-gnueabihf/libpthread.so.0
#25 0x75f83cec in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
Thread 17 (Thread 0x6e58b3f0 (LWP 3395)):
#2 0x75e1dda8 in _timer_thread (arg=0x70602d58) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:722
#3 0x76b695a4 in start_thread () from /lib/arm-linux-gnueabihf/libpthread.so.0
#4 0x75f83cec in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
Thread 16 (Thread 0x676ff3f0 (LWP 3405)):
#1 0x76b7020c in __lll_lock_wait () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0x76b6b3b4 in pthread_mutex_lock () from /lib/arm-linux-gnueabihf/libpthread.so.0
#3 0x76571dbe in sqlite3_free () from /usr/lib/arm-linux-gnueabihf/libsqlite3.so.0
Thread 15 (Thread 0x6af0e3f0 (LWP 3400)):
#0 0x75f7dc90 in poll () from /lib/arm-linux-gnueabihf/libc.so.6
Thread 14 (Thread 0x6cfff3f0 (LWP 3396)):
#1 0x76b6f824 in do_futex_wait.constprop () from /lib/arm-linux-gnueabihf/libpthread.so.0
#2 0x76b6f906 in __new_sem_wait_slow.constprop.0 () from /lib/arm-linux-gnueabihf/libpthread.so.0
#3 0x75e39b60 in vchiu_queue_pop () from /opt/vc/lib/libvchiq_arm.so
#4 0x6e5ecd70 in ilcs_task () from /opt/vc/lib/libopenmaxil.so
#5 0x75e1dcc4 in vcos_thread_entry (arg=0x70602dc8) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
Thread 13 (Thread 0x69f0e3f0 (LWP 3402)):
Thread 12 (Thread 0x6b70e3f0 (LWP 3399)):
#2 0x6d9af990 in CEC::CCECClient::Process() () from /usr/lib/arm-linux-gnueabihf/libcec.so.3
#3 0x6d9b245c in PLATFORM::CThread::ThreadHandler(void*) () from /usr/lib/arm-linux-gnueabihf/libcec.so.3
#4 0x76b695a4 in start_thread () from /lib/arm-linux-gnueabihf/libpthread.so.0
#5 0x75f83cec in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
Thread 11 (Thread 0x6f5ff3f0 (LWP 3393)):
#3 0x7684dac4 in tvservice_notify_func () from /opt/vc/lib/libbcm_host.so
#4 0x75e1dcc4 in vcos_thread_entry (arg=0x76866d80 <tvservice_notify_task>) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
Thread 10 (Thread 0x6970e3f0 (LWP 3403)):
#2 0x0081051a in PERIPHERALS::CEventScanner::Process() ()
Thread 9 (Thread 0x6bfff3f0 (LWP 3398)):
#2 0x012326be in XbmcThreads::CEventGroup::wait(unsigned int) ()
#3 0x009d4b3e in CRemoteControl::Process() ()
#4 0x01233a30 in CThread::Action() ()
#5 0x01233c14 in CThread::staticThread(void*) ()
Thread 8 (Thread 0x6edff3f0 (LWP 3394)):
#3 0x7684e674 in cecservice_notify_func () from /opt/vc/lib/libbcm_host.so
#4 0x75e1dcc4 in vcos_thread_entry (arg=0x76867b08 <cecservice_notify_task>) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
Thread 7 (Thread 0x6fdff3f0 (LWP 3392)):
#3 0x76851c38 in dispmanx_notify_func () from /opt/vc/lib/libbcm_host.so
#4 0x75e1dcc4 in vcos_thread_entry (arg=0x76868930 <dispmanx_notify_task>) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
Thread 6 (Thread 0x72ee43f0 (LWP 3379)):
#2 0x0075a63c in ANNOUNCEMENT::CAnnouncementManager::Process() ()
Thread 5 (Thread 0x705ff3f0 (LWP 3391)):
#0 0x75f7eea6 in ioctl () from /lib/arm-linux-gnueabihf/libc.so.6
#1 0x75e37010 in completion_thread () from /opt/vc/lib/libvchiq_arm.so
#2 0x75e1dcc4 in vcos_thread_entry (arg=0x75e4a318 <vchiq_instance+16>) at /home/dc4/projects/staging/userland/interface/vcos/pthreads/vcos_pthreads.c:144
Thread 4 (Thread 0x719113f0 (LWP 3389)):
#2 0x0063afbe in ActiveAE::CActiveAE::Process() ()
Thread 3 (Thread 0x70fff3f0 (LWP 3390)):
#0 0x75f60e20 in nanosleep () from /lib/arm-linux-gnueabihf/libc.so.6
Thread 2 (Thread 0x724ff3f0 (LWP 3380)):
Thread 1 (Thread 0x6d96f3f0 (LWP 3388)):
#1 0x00a193f8 in DatabaseUtils::GetDatabaseResults(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::vector<Field, std::allocator<Field> > const&, std::unique_ptr<dbiplus::Dataset, std::default_delete<dbiplus::Dataset> > const&, std::vector<std::map<Field, CVariant, std::less<Field>, std::allocator<std::pair<Field const, CVariant> > >, std::allocator<std::map<Field, CVariant, std::less<Field>, std::allocator<std::pair<Field const, CVariant> > > > >&) ()
#2 0x00a4d302 in SortUtils::SortFromDataset(SortDescription const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::unique_ptr<dbiplus::Dataset, std::default_delete<dbiplus::Dataset> > const&, std::vector<std::map<Field, CVariant, std::less<Field>, std::allocator<std::pair<Field const, CVariant> > >, std::allocator<std::map<Field, CVariant, std::less<Field>, std::allocator<std::pair<Field const, CVariant> > > > >&) ()
#3 0x00416ca0 in CVideoDatabase::GetEpisodesByWhere(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, CDatabase::Filter const&, CFileItemList&, bool, SortDescription const&, int) ()
#4 0x00417804 in CVideoDatabase::GetRecentlyAddedEpisodesNav(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, CFileItemList&, unsigned int, int) ()
#5 0x01155e58 in XFILE::VIDEODATABASEDIRECTORY::CDirectoryNodeRecentlyAddedEpisodes::GetContent(CFileItemList&) const ()
#6 0x01153874 in XFILE::VIDEODATABASEDIRECTORY::CDirectoryNode::GetChilds(CFileItemList&) ()
#7 0x00710794 in XFILE::CVideoDatabaseDirectory::GetDirectory(CURL const&, CFileItemList&) ()
#8 0x006da69c in XFILE::CDirectory::GetDirectory(CURL const&, CFileItemList&, XFILE::CDirectory::CHints const&, bool) ()
#9 0x006dba48 in XFILE::CDirectory::GetDirectory(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, CFileItemList&, XFILE::CDirectory::CHints const&, bool) ()
#10 0x006dbb48 in XFILE::CDirectory::GetDirectory(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, CFileItemList&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, int, bool) ()
#11 0x007a01f4 in CDirectoryJob::DoWork() ()
#12 0x00a23098 in CJobWorker::Process() ()
#13 0x01233a30 in CThread::Action() ()
#14 0x01233c14 in CThread::staticThread(void*) ()
#15 0x76b695a4 in start_thread () from /lib/arm-linux-gnueabihf/libpthread.so.0
#16 0x75f83cec in ?? () from /lib/arm-linux-gnueabihf/libc.so.6
############# END STACK TRACE ###############
################# LOG FILE ##################
15:46:19 T:1928224768 NOTICE: special://profile/ is mapped to: special://masterprofile/
15:46:19 T:1928224768 NOTICE: -----------------------------------------------------------------------
15:46:19 T:1928224768 NOTICE: Starting Kodi (17.0-BETA1 Git:2016-08-15-961d012-dirty). Platform: Linux ARM (Thumb) 32-bit
15:46:19 T:1928224768 NOTICE: Using Debug Kodi x32 build (version for Raspberry Pi)
15:46:19 T:1928224768 NOTICE: Kodi compiled Aug 14 2016 by GCC 5.3.1 for Linux ARM (Thumb) 32-bit version 4.4.6 (263174)
15:46:19 T:1928224768 NOTICE: Running on Ubuntu 16.04.1 LTS, kernel: Linux ARM 32-bit version 4.4.19-v7+
15:46:19 T:1928224768 NOTICE: FFmpeg statically linked, version: 3.1.2-kodi-3.1.2-Krypton-Beta1
15:46:19 T:1928224768 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
15:46:19 T:1928224768 NOTICE: ARM Features: Neon enabled
15:46:19 T:1928224768 NOTICE: special://xbmc/ is mapped to: /usr/local/share/kodi
15:46:19 T:1928224768 NOTICE: special://xbmcbin/ is mapped to: /usr/local/lib/kodi
15:46:19 T:1928224768 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/local/lib/kodi/addons
15:46:19 T:1928224768 NOTICE: special://masterprofile/ is mapped to: /home/meidhy/.kodi/userdata
15:46:19 T:1928224768 NOTICE: special://envhome/ is mapped to: /home/meidhy
15:46:19 T:1928224768 NOTICE: special://home/ is mapped to: /home/meidhy/.kodi
15:46:19 T:1928224768 NOTICE: special://temp/ is mapped to: /home/meidhy/.kodi/temp
15:46:19 T:1928224768 NOTICE: special://logpath/ is mapped to: /home/meidhy/.kodi/temp
15:46:19 T:1928224768 NOTICE: The executable running is: /usr/local/lib/kodi/kodi.bin
15:46:19 T:1928224768 NOTICE: Local hostname: meidhy-desktop
15:46:19 T:1928224768 NOTICE: Log File is located: /home/meidhy/.kodi/temp//kodi.log
15:46:19 T:1928224768 NOTICE: load settings...
15:46:19 T:1928224768 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
15:46:19 T:1928224768 WARNING: CSettingInt: unknown options filler "audiocdactions" of "audiocds.autoaction"
15:46:19 T:1928224768 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/rbp.xml
15:46:19 T:1928224768 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/rbp2.xml
15:46:19 T:1917842416 DEBUG: Thread FDEventMonitor start, auto delete: false
15:46:19 T:1928224768 NOTICE: Found 2 Lists of Devices
15:46:19 T:1928224768 NOTICE: Enumerated PI devices:
15:46:19 T:1928224768 NOTICE: Device 1
15:46:19 T:1928224768 NOTICE: m_deviceName : HDMI
15:46:19 T:1928224768 NOTICE: m_displayName : HDMI
15:46:19 T:1928224768 NOTICE: m_displayNameExtra:
15:46:19 T:1928224768 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
15:46:19 T:1928224768 NOTICE: m_channels : FL,FR
15:46:19 T:1928224768 NOTICE: m_sampleRates : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
15:46:19 T:1928224768 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
15:46:19 T:1928224768 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
15:46:19 T:1928224768 NOTICE: Device 2
15:46:19 T:1928224768 NOTICE: m_deviceName : Analogue
15:46:19 T:1928224768 NOTICE: m_displayName : Analogue
15:46:19 T:1928224768 NOTICE: m_deviceType : AE_DEVTYPE_PCM
15:46:19 T:1928224768 NOTICE: m_sampleRates : 48000
15:46:19 T:1928224768 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
15:46:19 T:1928224768 NOTICE: m_streamTypes : No passthrough capabilities
15:46:19 T:1928224768 NOTICE: Device 3
15:46:19 T:1928224768 NOTICE: m_deviceName : Both
15:46:19 T:1928224768 NOTICE: m_displayName : HDMI and Analogue
15:46:19 T:1928224768 NOTICE: Enumerated ALSA devices:
15:46:19 T:1928224768 NOTICE: m_deviceName : default
15:46:19 T:1928224768 NOTICE: m_displayName : Playback/recording through the PulseAudio sound server
15:46:19 T:1928224768 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
15:46:19 T:1928224768 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
15:46:19 T:1928224768 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
15:46:19 T:1928224768 NOTICE: m_deviceName : pulse
15:46:19 T:1928224768 NOTICE: m_displayName : PulseAudio Sound Server
15:46:19 T:1928224768 DEBUG: CSkinSettings: no <skinsettings> tag found
15:46:19 T:1928224768 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
15:46:19 T:1928224768 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
<?xml version="1.0" encoding="UTF-8" ?>
<advancedsettings>
<video>
<defaultplayer>VideoPlayer</defaultplayer>
<defaultVideoPlayer>VideoPlayer</defaultVideoPlayer>
</video>
</advancedsettings>
15:46:19 T:1928224768 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
15:46:19 T:1928224768 NOTICE: Default Video Player: VideoPlayer
15:46:19 T:1928224768 NOTICE: Default Audio Player: paplayer
15:46:19 T:1928224768 NOTICE: Disabled debug logging due to GUI setting. Level 0.
15:46:19 T:1928224768 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
15:46:19 T:1928224768 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
15:46:19 T:1928224768 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
15:46:19 T:1928224768 DEBUG: CPlayerCoreConfig::<ctor>: created player VideoPlayer
15:46:19 T:1928224768 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mms/udp
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
15:46:19 T:1928224768 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
15:46:19 T:1928224768 NOTICE: Loaded playercorefactory configuration
15:46:19 T:1928224768 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
15:46:19 T:1928224768 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
15:46:19 T:1928224768 INFO: creating subdirectories
15:46:19 T:1928224768 INFO: userdata folder: special://masterprofile/
15:46:19 T:1928224768 INFO: recording folder:
15:46:19 T:1928224768 INFO: screenshots folder:
15:46:19 T:1928224768 NOTICE: Running database version Addons26
15:46:19 T:1928224768 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libcpluff-arm.so)
15:46:19 T:1928224768 DEBUG: Loading: /usr/local/lib/kodi/system/libcpluff-arm.so
15:46:19 T:1928224768 INFO: ADDON: cpluff: 'Could not read plug-in directory /usr/local/lib/kodi/addons: No such file or directory'
15:46:26 T:1838609392 DEBUG: Thread JobWorker start, auto delete: true
15:46:26 T:1928224768 NOTICE: ADDONS: Using repository repository.xbmc.org
15:46:26 T:1905333232 DEBUG: Thread ActiveAE start, auto delete: false
15:46:26 T:1895822320 DEBUG: Thread AESink start, auto delete: false
15:46:26 T:1895822320 INFO: CActiveAESink::OpenSink - initialize sink
15:46:26 T:1895822320 DEBUG: CActiveAESink::OpenSink - trying to open device PI:HDMI
15:46:26 T:1895822320 DEBUG: DllBcm: Using omx system library
15:46:26 T:1895822320 DEBUG: SECTION:LoadDLL(libopenmaxil.so)
15:46:26 T:1895822320 DEBUG: Loading: libopenmaxil.so
15:46:26 T:1820324848 DEBUG: Thread CRBPWorker start, auto delete: false
15:46:26 T:1895822320 DEBUG: CAESinkPi:SetAudioProps hdmi_stream_channels 0 hdmi_channel_map 00000008
15:46:26 T:1895822320 DEBUG: CAESinkPi:Initialize Format:15 Channels:2 Samplerate:44100 framesize:8 bufsize:17640 bytes/s=352800.00 dest=PI:HDMI
15:46:26 T:1895822320 DEBUG: COMXCoreComponent::Initialize OMX.broadcom.audio_render input port 100 output port 100 m_handle 0x7060c660
15:46:26 T:1895822320 DEBUG: COMXCoreComponent::AllocInputBuffers component(OMX.broadcom.audio_render) - port(100), nBufferCountMin(1), nBufferCountActual(2), nBufferSize(17648), nBufferAlignmen(16)
15:46:26 T:1895822320 DEBUG: CActiveAESink::OpenSink - SinkPi Initialized:
15:46:26 T:1895822320 DEBUG: Output Device : HDMI
15:46:26 T:1895822320 DEBUG: Sample Rate : 44100
15:46:26 T:1895822320 DEBUG: Sample Format : AE_FMT_FLOAT
15:46:26 T:1895822320 DEBUG: Channel Count : 2
15:46:26 T:1895822320 DEBUG: Channel Layout: FL,FR
15:46:26 T:1895822320 DEBUG: Frames : 2205
15:46:26 T:1895822320 DEBUG: Frame Size : 8
15:46:26 T:1811936240 DEBUG: Thread RemoteControl start, auto delete: false
15:46:26 T:1811936240 INFO: LIRC Process: using: /dev/lircd
15:46:26 T:1811936240 INFO: LIRC Connect: connect failed: No such file or directory
15:46:26 T:1811936240 INFO: CRemoteControl::Process - failed to connect to LIRC, will keep retrying every 5 seconds
15:46:26 T:1928224768 INFO: CKeyboardLayoutManager: loading keyboard layouts from special://xbmc/system/keyboardlayouts...
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BasePY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Chinese BaiduPY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian ЙЦУКЕН" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Ukrainian АБВ" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Korean ㄱㄴㄷ" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Danish QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Portuguese (Portugal) QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Slovak QWERTZ" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Slovak QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Slovak ABC" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Turkish QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian AZERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Lithuanian QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Arabic QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian ЯВЕРТЪ" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Bulgarian АБВ" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Czech QWERTZ" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Hebrew ABC" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "German QWERTZ" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Hungarian QWERTZ" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Spanish QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Polish QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Greek QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Norwegian QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Swedish QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "French AZERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "English QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "English AZERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "English ABC" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Romanian QWERTY" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian ЙЦУКЕН" successfully loaded
15:46:26 T:1928224768 DEBUG: CKeyboardLayoutManager: keyboard layout "Russian АБВ" successfully loaded
15:46:26 T:1928224768 DEBUG: Selected UDev as storage provider
15:46:26 T:1928224768 NOTICE: Raspberry PI firmware version: Sep 2 2016 11:49:43
Copyright (c) 2012 Broadcom
version 0706e45eb49a02aadefa58183d474791df2a81fb (clean) (release)
15:46:26 T:1928224768 NOTICE: ARM mem: 944MB GPU mem: 64MB MPG2:0 WVC1:0
15:46:26 T:1928224768 NOTICE: Config:
arm_freq=1200
audio_pwm_mode=1
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x36ee80
disable_commandline_tags=2
disable_l2cache=1
force_eeprom_read=1
force_pwm_open=1
framebuffer_depth=32
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_channel_map=8
hdmi_force_cec_address=65535
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=0x2932e
overscan_bottom=48
overscan_left=48
overscan_right=48
overscan_top=48
pause_burst_frames=1
program_serial_random=1
sdram_freq=450
temp_limit=85
device_tree=-
15:46:26 T:1928224768 DEBUG: DllBcm: Using omx system library
15:46:26 T:1928224768 NOTICE: InitWindowSystem: Using EGL Implementation: raspberrypi
15:46:26 T:1928224768 DEBUG: EGL initial desktop resolution 1920x1080 (1280x720) @ 60.00 - Full Screen (1.00)
15:46:26 T:1928224768 DEBUG: EGL get supported modes (2) = 18, prefer_group=1, prefer_mode=10
15:46:26 T:1928224768 DEBUG: EGL mode 0: 640x480 (640x480) @ 60.00 - Full Screen (1.00) :4
15:46:26 T:1928224768 DEBUG: EGL mode 1: 640x480 (640x480) @ 72.00 - Full Screen (1.00) :5
15:46:26 T:1928224768 DEBUG: EGL mode 2: 640x480 (640x480) @ 75.00 - Full Screen (1.00) :6
15:46:26 T:1928224768 DEBUG: EGL mode 3: 800x600 (800x600) @ 60.00 - Full Screen (1.00) :9
15:46:26 T:1928224768 DEBUG: EGL mode 4: 800x600 (800x600) @ 72.00 - Full Screen (1.00) :a
15:46:26 T:1928224768 DEBUG: EGL mode 5: 800x600 (800x600) @ 75.00 - Full Screen (1.00) :b
15:46:26 T:1928224768 DEBUG: EGL mode 6: 1024x768 (960x720) @ 60.00 - Full Screen (1.00)
Using Raspb Pi 3 with Ubuntu mate 16.04 LTS
Meidhy
Sat Sep 10, 2016 3:14 pm
I try to put all but the website accept onlu 60000 words.. So I cut it.. If u want the other part I can copy it there.. ( on the log u can see gpu mem at 64..in fact it was 128MB as required, I tried to remove the line from the config.Txt for see if it changes something but no )
My config is Raspberry PI 3 with Ubuntu Mate 16.04LTS installed+HDD USB for storage film series etc..
If u have an idea about my trouble,thanks in advance.
Meidhy
Kratos
Sat Sep 10, 2016 7:02 pm
Hmm. Could you copy just the last few lines? Like, the last 10 or so? Thanks!
Kratos
Meidhy
Sat Sep 10, 2016 7:08 pm
Hi, Of course.. see follow a little more line :
15:46:27 T:1928224768 DEBUG: JSONRPC: JSON schema type definition references an unknown type Setting.Details.Setting
15:46:27 T:1928224768 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
15:46:27 T:1928224768 INFO: JSONRPC: Adding type "Setting.Details.SettingList" to list of incomplete definitions (waiting for "Setting.Details.Setting")
15:46:27 T:1928224768 INFO: JSONRPC: Resolving incomplete types/methods referencing Setting.Details.Setting
15:46:27 T:1928224768 ERROR: JSONRPC: Unable to parse JSON Schema definition for ""
15:46:27 T:1928224768 ERROR: JSONRPC: Invalid JSON Schema definition for method ""
15:46:27 T:1928224768 INFO: JSONRPC v7.21.0: Successfully initialized
15:46:27 T:1928224768 DEBUG: ADDON: Starting service addons.
15:46:27 T:1743778800 DEBUG: Thread LanguageInvoker start, auto delete: false
15:46:27 T:1928224768 DEBUG: Activating window ID: 12999
15:46:27 T:1743778800 INFO: initializing python engine.
15:46:27 T:1928224768 DEBUG: ------ Window Init (Startup.xml) ------
15:46:27 T:1928224768 INFO: Loading skin file: Startup.xml, load type: LOAD_EVERY_TIME
15:46:27 T:1928224768 DEBUG: Load Startup.xml: 0.37ms
15:46:27 T:1928224768 DEBUG: Alloc resources: 0.43ms (0.43 ms skin load)
15:46:27 T:1928224768 DEBUG: Activating window ID: 10000
15:46:27 T:1928224768 DEBUG: ------ Window Deinit (Startup.xml) ------
15:46:27 T:1928224768 DEBUG: ------ Window Init (Home.xml) ------
15:46:27 T:1928224768 INFO: Loading skin file: Home.xml, load type: KEEP_IN_MEMORY
15:46:28 T:1928224768 DEBUG: Load Home.xml: 229.84ms
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[special://skin/playlists/inprogress_movies.xsp]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[videodb://recentlyaddedmovies/]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[special://skin/playlists/unwatched_movies.xsp]: refreshing..
15:46:28 T:1735390192 DEBUG: Thread JobWorker start, auto delete: true
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[special://skin/playlists/random_movies.xsp]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[videodb://inprogresstvshows]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[videodb://recentlyaddedepisodes/]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[special://skin/playlists/unwatched_tvshows.xsp]: refreshing..
15:46:28 T:1727001584 DEBUG: Thread JobWorker start, auto delete: true
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[musicdb://recentlyplayedalbums]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[musicdb://recentlyaddedalbums/]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[special://skin/playlists/random_albums.xsp]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[special://skin/playlists/random_artists.xsp]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[special://skin/playlists/unplayed_albums.xsp]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[special://skin/playlists/mostplayed_albums.xsp]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[addons://sources/video/]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[addons://sources/audio/]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[addons://sources/executable/]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[-]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[addons://sources/image/]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[sources://video/]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[special://videoplaylists/]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[pvr://channels/tv/All channels/]: refreshing..
15:46:28 T:1928224768 DEBUG: CDirectoryProvider[pvr://channels/radio/All channels/]: refreshing..
15:46:28 T:1928224768 DEBUG: Alloc resources: 252.34ms (230.08 ms skin load)
15:46:28 T:1838609392 DEBUG: RunQuery took 9 ms for 0 items query: select * from movie_view WHERE (movie_view.idFile IN (SELECT DISTINCT idFile FROM bookmark WHERE type = 1))
15:46:28 T:1735390192 DEBUG: RunQuery took 16 ms for 0 items query: select * from movie_view ORDER BY dateAdded desc, idMovie desc LIMIT 25
15:46:28 T:1743778800 DEBUG: CPythonInvoker(0, /home/meidhy/.kodi/addons/service.xbmc.versioncheck/service.py): start processing
15:46:28 T:1838609392 DEBUG: RunQuery took 13 ms for 0 items query: select * from movie_view
15:46:28 T:1727001584 DEBUG: RunQuery took 21 ms for 0 items query: select * from movie_view WHERE ((movie_view.playCount IS NULL OR movie_view.playCount = 0))
15:46:28 T:1928224768 INFO: removing tempfiles
15:46:28 T:1928224768 NOTICE: UpdateLibraries: Starting video library startup scan
15:46:28 T:1928224768 DEBUG: ADDON: Starting service addons.
15:46:28 T:1928224768 DEBUG: CRepositoryUpdater: previous update at 08/09/2016 14:24:12, next at 10/09/2016 15:46:28
15:46:28 T:1928224768 NOTICE: initialize done
15:46:28 T:1928224768 NOTICE: Running the application...
15:46:28 T:1928224768 DEBUG: no profile autoexec.py (/home/meidhy/.kodi/userdata/autoexec.py) found, skipping
15:46:28 T:1928224768 DEBUG: NetworkMessage - Starting network services
15:46:28 T:1928224768 NOTICE: starting upnp client
15:46:28 T:1718612976 DEBUG: Thread Timer start, auto delete: false
15:46:28 T:1735390192 DEBUG: RunQuery took 20 ms for 0 items query: SELECT * FROM tvshow_view WHERE watchedCount != 0 AND totalCount != watchedCount ORDER BY c00
15:46:28 T:1718612976 DEBUG: CRepositoryUpdater: running scheduled update
15:46:28 T:1718612976 DEBUG: Thread Timer 1718612976 terminating
15:46:28 T:1838609392 DEBUG: RunQuery took 19 ms for 25 items query: select * from episode_view ORDER BY dateAdded desc, idEpisode desc LIMIT 25
############### END LOG FILE ################
############ END Kodi CRASH LOG #############
Kratos
Sat Sep 10, 2016 7:12 pm
You could try removing Kodi from your system like this:
sudo apt-get remove kodi -y
And then reinstall using these instructions (the very first post):
viewtopic.php?f=35&t=124572
You will need 160 MB in the config.txt file for Kodi to work properly.
Kratos
Meidhy
Sat Sep 10, 2016 7:59 pm
ok, i will try and let u know
How to check this :
Kodi Configuration:
etc...
thanks
Kratos
Sat Sep 10, 2016 10:04 pm
Go to System > System Information and tell me what it says in Version Info. Or:
grep Kodi .kodi/temp/kodi.log | head -3
Kratos
Hollywoodpete
Mon Sep 12, 2016 11:13 am
I followed the directions on page 1 and installed Kodi on my Raspberry Pi3. Everything looked good until I tried to add content. It initially appeared to scrape and add shows but now simply crashes. pastebin.com/mzdMTStn
Kratos
Mon Sep 12, 2016 8:39 pm
It appears that this is an issue I will have to look into. I will see what I can do. I'll compile a new version and see if it has the same problems.
Kratos
Kratos
Wed Sep 14, 2016 7:49 pm
Hollywoodpete wrote:I followed the directions on page 1 and installed Kodi on my Raspberry Pi3. Everything looked good until I tried to add content. It initially appeared to scrape and add shows but now simply crashes. pastebin.com/mzdMTStn
I compiled a new version today. Would you mind giving it a shot and seeing if it works on your system? Download link:
https://drive.google.com/file/d/0B2vdsV ... sp=sharing
Install it the same way you did with the other package. Thanks!
Kratos
Meidhy
Thu Sep 15, 2016 5:03 pm
Hi Kratos,
Still the same , black screen and nothing..(don't come back on the desktop ) always the black screen..i have the log attached.
kodi_crashlog-20160915_184307.log.zip
(10.65 KiB) Downloaded 133 times
Best regards,
Kratos
Fri Sep 16, 2016 6:09 pm
Thanks for testing! Could you try Wimpy's build? It is available here.
https://launchpad.net/~ubuntu-pi-flavou ... tu/kodi-pi
Kratos
Meidhy
Fri Sep 16, 2016 7:19 pm
hello,
Yes thanks for the link i will try now
Best regards
EDIT : Its working, Version of this link works fined, start and everything, but this version seems to be blocked. impossible to change the Skin..some parameters are not available, also update ...
When i leave Kodi , black screen again , impossible to come back on the desktop...
EDIT II : I change the skin to NEON, and now i had access to all parameters..so it's working, playing video too etc... just always the black screen when i made ''EXIT'' solution for that i found is to do reboot, and you come back after the reboot of the Pi on your desktop...
cheers
Kratos
Sat Sep 17, 2016 12:16 am
Hmm, I'll try and see how Wimpy built his, and try to do the same thing for my build. Thanks for testing!
Kratos
Meidhy
Sun Sep 18, 2016 10:36 am
Update : Soon i imported library, during the scan of some series of films, Kodi Crashed!! Reboot Pi, re start Kodi and here go never open again, boot screen with logo appears 2 or 3 seconds, and black screen ! nothing after !
i'm tired with this installation, but much better than just install openelec or libreelec...
Waiting for your version Kratos ^^
See you
Kratos
Sun Sep 18, 2016 12:55 pm
OK, cool. It will definitely take me some time to iron all this out. About Kodi never opening again, that is because you needed to delete the .kodi folder in your home folder.
Kratos
Manny-
Wed Oct 05, 2016 8:25 am
I have also tried the Kodi package on the original post on my Raspberry Pi 3 and can also confirm when trying to play a video from youtube etc, the Kodi crashes and displays a black screen.. I would try Wimpy`s build but Im not sure how to install the package as I`ve never used the website before, but if you have a package I could install along with some instructions, I am willing to test it out
Regards,
Manny
Kratos
Wed Oct 05, 2016 8:21 pm
I figured it out! I successfully added a movie to the library with no issues! It was an issue with optimizations. Kodi is now packing into a .deb file for you guys to download. Will post again when it finishes.
Kratos
Kratos
Thu Oct 06, 2016 3:52 pm
Updated the original guide on the very first post of this topic. Everything should work.
Kratos
Manny-
Thu Oct 06, 2016 6:13 pm
Hi
I got a crash and then error in the CMD after trying to load up a YouTube video:
usrvcsm: [vcsm_malloc_cache]: [11302] [mmal_vc_port buffer]: NULL size or invalid device!
usrvcsm: [vcsm_vc_hdl_from_hdl]: [11302]: invalid device or handle!
usrvcsm: [vcsm_lock]: [11302]: invalid device or invalid handle!
mmal: mmal_vc_shm_alloc: could not allocate 1048576 bytes of shared memory (handle 0)
mmal: mmal_vc_port_payload_alloc: vc.ril.video_decode:in:0(MVC ): failed to allocate 1048576 bytes of shared memory
mmal: mmal_pool_initialise_buffer_headers: failed to allocate payload 0/2
usrvcsm: [vcsm_malloc_cache]: [11302] [CGPUMEM]: NULL size or invalid device!
kodi.bin: RBP.cpp:335: CGPUMEM::CGPUMEM(unsigned int, bool): Assertion `m_vcsm_handle' failed.
Aborted (core dumped)
Crash report available at /home
Return to “Media centres”
