cjan
Re: Kodi on Ubuntu MATE 15.10
Mon May 16, 2016 12:28 pm
mmal and omxplayer, which is better?
carvari
Tue May 17, 2016 6:12 am
Hi everybody.
I've been testing Kratos (thanks Kratos!) packages for Kodi Jarvis on a fresh Ubuntu Mate 16.04 installation (via berryboot, converting the official image to SquashFS following berryboot instructions).
Unfortunately, just like reported by other users, i can't add tv shows or movies to the library (once media imported to the library, Kodi crash and i must delete database to run again without crasing). Some progress on this issue?
Thanks in advance, and excuse my english.
Regards.
Snze
Tue May 17, 2016 6:50 am
Kratos wrote: Happy anniversary!
Cheers Kratos! Had a nice time ;)
Kratos wrote:I am currently working on organizing all the files. I will then upload them all to Google Drive for you all to try out. I successfully completed builds of Kodi 16 and 17 for both Ubuntu MATE 15 and 16. On Jarvis, I had no issues adding Music to the library.
Nice one! Probably moot if you've got it working, but this seems to indicate that the library issue is due to the compiler; MATE 16.04 on pi has gcc 5 it appears?
Looking forward to trying the new builds :)
Kratos
Tue May 17, 2016 2:23 pm
cjan wrote:mmal and omxplayer, which is better?
Probably omxplayer.
Kratos
I have posted mostly with a Pi 2 running either Ubuntu MATE, or Raspbian.
Kratos
Tue May 17, 2016 2:24 pm
carvari wrote:Hi everybody.
Regards.
I am working on it. I will do some more testing and builds this week.
Kratos
Kratos
Tue May 17, 2016 2:25 pm
Snze wrote: Nice one! Probably moot if you've got it working, but this seems to indicate that the library issue is due to the compiler; MATE 16.04 on pi has gcc 5 it appears?
Thanks for the link! Will check it out and see what I can do. And yes, I believe it is gcc 5.
Kratos
Kratos
Tue May 17, 2016 6:41 pm
Snze wrote:Looking forward to trying the new builds :)
Here is Kodi 17! I have not had a chance to do any others yet. Tell me if you have the same problems. Remember to remove your current Kodi version.
[deleted]
Kratos
Snze
Tue May 17, 2016 9:01 pm
The library works!! :D Congratulations! What was it, in the end?
Still messing about with it at the moment; had a few random crashes, which i didn't seem to be getting on the previous version, though... I've turned off all the eye-candy and it seems more stable.
carvari
Tue May 17, 2016 10:32 pm
Works for me too. I have imported several tv shows an movies and no issues at the moment. Thanks!!! Wondefull job. :D
In the other hand, I have a problem with CEC and my tv remote is not working, may someone can help me...
I installed cec-utils to test my tv remote (it work well with cec-client and with kodi on my Pi 3 in Raspbian Jessie). However in Ubuntu Mate 16.04 (same Pi 3) is not working. I have next error when launch cec-client:
No device type given. Using 'recording device'
CEC Parser created - libCEC version 3.0.1
no serial port given. trying autodetect: FAILED
Same problem when launching with sudo. I have watch kodi log, but can't find errors about cec and tv remote do nothing on kodi.
Anyone have problems with tv remote on Ubuntu Mate 16.04? Any ideas of what could be the problem or what can i test?
My installation for Raspbian Jessie and for Ubuntu Mate its via BerryBoot.
Thanks again.
Regards.
Kratos
Tue May 17, 2016 10:43 pm
Great! Kodi 16 is cooking in the Pi Bakery at the moment, should be done any minute now. Try install libcec like so:
sudo apt-get install libcec3
That might do the trick.
Kratos
Kratos
Snze wrote:The library works!! :D Congratulations! What was it, in the end?
The solution was in the link you provided, disabling optimizations.
Kratos
Avie02
Wed May 18, 2016 3:26 am
Kratos,
Does Npvr not come loaded in the new Kodi 17? This might seem like an odd question but I can't seem to find it anywhere. Thank you for the awesome work on this build.
Kratos
Wed May 18, 2016 2:29 pm
Latest Kodi 17 build. I tried some thing a bit different this time, which allowed me to enable optimizations. Give it a shot!
[deleted]
Kratos
Kratos
Wed May 18, 2016 2:44 pm
Avie02 wrote:Kratos,
I have not built it yet. If you want it, it will be no problem for me to build it quick. Then, you can install the pvr stuff and it should work.
Kratos
Kratos
Wed May 18, 2016 7:51 pm
Just built the PVR thing. (Not sure what it is called... :oops: )
https://drive.google.com/file/d/0B2vdsV ... sp=sharing
Enjoy!
Kratos
PS: I am almost done with mu master guide. Will post as soon as we iron out all the bugs :D
Snze
Wed May 18, 2016 8:00 pm
Kratos, this afternoon's build of 17 is absolutely spot on... no issues to report so far, except it's still a little touch-and-go exiting back to the desktop. (Meh, I can totally live with that!)
Thanks so much for your work on this, you've done loads!
Kratos
Wed May 18, 2016 9:46 pm
YAY!!! Glad I am able to help! I am currently working on a solution for the black screen bug fix. Kodi 17 appears to be a bit different, so I shall do some digging. Cheers!
Kratos
carvari
Wed May 18, 2016 9:59 pm
Hi.
Kratos, your new Kodi 17 build works great for me too!! Thanks.
The libcec3 package is alredy installed in its last version :(
The problem is neither cec-client nor kodi seems to detect nothing (trying autodetect: FAILED).
Any other ideas would be welcome.
Thanks again.
Kratos
Wed May 18, 2016 10:05 pm
What happens if you just start kodi? Correct me if I am wrong, but, it sounds like you are manually starting cec. I don't think you need to do that.
Kratos
carvari
Wed May 18, 2016 11:04 pm
Hi.
When i start kodi, the tv remote doesn't work.
But now, it's working!!! Really i don't know why :roll:
I write here what i did, just in case it's usefull for anyone.
1. Compile libcec following instructions in https://github.com/Pulse-Eight/libcec/b ... /README.md
2. Test, but still not working
3. Reboot. Not working (neither cec-client nor kodi)
4. Purge libcec3 (sudo apt-get purge libcec3)
5. Start Kodi and... VOILA! Cec working :D
6. Exit Kodi and test cec-client that works too :D
I don't understand why, but now everything about cec is working well.
Thanks Kratos for your support and, of course, your Kodi builds.
Regards.
Kratos
Thu May 19, 2016 12:31 am
Guide currently taken down for potential copyright issues. Hopefully I can clear it up soon.
Kratos
Avie02
Thu May 19, 2016 1:51 am
Kratos,
Is there a way to add the npvr add-on that normally comes packaged with kodi?
Kratos
Thu May 19, 2016 2:32 am
Yup.
sudo apt-get install kodi-pvr-nextpvr
Kratos
Kratos
Thu May 19, 2016 2:39 am
Actually, it looks like it is only supported on Windows:
NextPVR is a free Personal Video Recorder (PVR) application for Microsoft Windows.
Reference:
http://kodi.wiki/view/NextPVR
Kratos
gkreidl
Thu May 19, 2016 3:13 pm
gpu_mem should be at least 160 MB. 128 MB is good enough for omxplayer to play full HD videos, but kodi itself requires some memory for its OpenGL ES interface.
Minimal Kiosk Browser (kweb)
Return to “Media centres”
