Vinniek
Kodi - no visualisations avaialble
Tue Mar 24, 2015 1:38 pm
Hiya,
I'm using a NOOBs installation of Debian, and I used this guide to install Kodi: http://michael.gorven.za.net/raspberrypi/xbmc
I've been using XBMC since the original Xbox days, and one of the most impressive features for me is the visualisations. When I go Settings>Music>Playback - Get more, I get a blank list.
I can install other addons without a problem, probably something simple but I'm stuck!
Cheers
elatllat
Re: Kodi - no visualisations avaialble
Tue Mar 24, 2015 4:45 pm
You can use one of the pre-built solutions like osmc or you can add repositories to get access to more plugins.
SBC with 32GB RAM: https://hardkernel.com
FAQ : https://raspberrypi.stackexchange.com
Unanswered: https://www.raspberrypi.org/forums/search.php?search_id=unanswered
Mattywinter
Tue Mar 24, 2015 6:46 pm
This is quite an annoyance. Regardless of build, there are only two visualisations available, something due to the arm chip.
Return to “Media centres”
