nemo096
Installing CPAN modules
Thu Jul 18, 2013 9:47 am
I have tried everything there is that has been posted to try and install some perl modules from CPAN as before I got my pi my main programming language is perl
Does anyone know how to successfully install CPAN modules?
Gibble
Re: Installing CPAN modules
Tue Jul 23, 2013 9:02 pm
Have you tried cpanm ?
scrapheap
Wed Jul 24, 2013 10:18 am
If you are still having trouble then the first two questions that spring to mind are
  • Which OS are you using?
  • Which module are you trying to install?
Knowing the OS will help determine if everything required to build a module is present and the knowing which module you are trying to install will help determine what needs to present to build the module.
nemo096
Thu Jul 25, 2013 4:19 pm
Thanks for the reply
The OS I am using is wheezy and I am trying to install modules like LWP and Twitter::Badge (retrieves twitter status) and a module that updates twitter status', and a module called Weather::Underground
Is there anything I can do without having to manually install every module and every dependency?
Thanks,
Ethan
scrapheap
Fri Jul 26, 2013 1:12 pm
To install LWP just use
sudo apt-get install libwww-perl
To install the other two you will probably have to use the CPAN module. Use
perl -MCPAN -e'shell'
to open a CPAN shell, let it auto configure if possible. Once you have the CPAN shell you can then install using
install Weather::Underground
and
install Twitter::Badge
Of course there are always a few modules that won't work on arm architecture as they contain code that only works on x86.
