tonyhughes
BASH script to check for Pi hardware and/or Raspbian
Fri Feb 22, 2013 2:08 am
I have a few routines in my software that are very Pi specific, but I would like to make the rest of it okay for x86 Debian based systems too.
I can check for the arm hardware with:
#! /bin/bash
WHAT_AM_I=$(uname -m)
echo "$WHAT_AM_I"
Which returns "armv6l".
Is that good enough to reliably determine we are running on a Pi?
I would also like to get more adventurous, and make my script work for different OSes on the Pi too - it is currently aimed at Raspbian, but if I can detect a different OS, then I can run routines specific to that OS (i.e. using pacman or yum instead of apt).
How can I reliably determine the OS breed. Preferably with a routine that will survive OS version number updates...
e.g. I'd like to create a variable who's contents are "Arch" or "Fedora" or "Raspbian" etc.
jojopi
Re: BASH script to check for Pi hardware and/or Raspbian
Fri Feb 22, 2013 4:05 am
To check specifically for a Pi (or very authentic clone) look at the Hardware and Revision lines in /proc/cpuinfo. But "uname -m" is better if you just want i686/x86_64/arm*.
You might want to know if the user-space ARM binaries are compiled for hard float. "readelf -a /proc/self/exe |grep Tag_ABI_VFP_args" will be non-empty if readlink is.
Debian/Raspbian systems will have a file /etc/debian_version (giving 7.0 for wheezy). Fedora-based systems have a slightly more verbose /etc/redhat-release (actually a symlink to fedora-release, unless you are running Red Sleeve). Arch has an empty file /etc/arch-release.
tonyhughes
Fri Feb 22, 2013 6:59 am
So massively incredibly helpful - thankyou!
gordon@drogon.net
Fri Feb 22, 2013 10:30 am
I used this for a project recently:
grep -q BCM2708 /proc/cpuinfo
Seemed to work well enough to let my project build script know if it was on a Pi or not. (check the exit code)
-Gordon
Gordons projects: https://projects.drogon.net/
dr_d_gee
Fri Feb 22, 2013 3:05 pm
There are also other options to uname, as you may already be aware.
uname -o
prints the operating system (I'm not on a Linux box at the moment so can't say exactly what it prints) and
uname - r
prints the kernel release. There are others; see http://linux.about.com/library/cmd/blcmdl1_uname.htm (or other sources). I *think* the kernel release output usually prints the distribution name (among other things).
tonyhughes
Fri Feb 22, 2013 9:42 pm
Thanks. For those playing at home, here is the output on a Pi.
tony@orangepi ~ $ uname -o
GNU/Linux
tony@orangepi ~ $ uname -r
3.6.11+
tony@orangepi ~ $
gordon@drogon.net
Fri Feb 22, 2013 9:44 pm
dr_d_gee wrote:There are also other options to uname, as you may already be aware.
uname -o
uname - r
I went through that too - I didn't find uname that enlightening - uname -o yeilds "GNU/Lunux" on a Pi, and the same on my x86 workstation.. -r isn't much help either - unless you're targetting a particular kernel release.
uname -m
Might be the closest though - you get armv6l on the Pi and i686 in my workstation, however I also get x86_64 on a 64-bit machine I am also using in my build process for the same project which wasn't what I was after, so I stuck with grepping for the hardware type in /proc/cpuinfo
I'm not even sure if there is a standard way to determine if your on Debian, Raspbian, RedHat Centos, Ubuntu either.. I saw some scripts a while back that simple looked for various files in existance to try to work out what the distro was.
-Gordon
ukscone
Fri Feb 22, 2013 10:03 pm
you could try
cat /etc/*-release
and/or
python -c "import platform; print platform.dist()"
won't work everywhere & probably not too trustworthy but might be enough
ahundt
Sun Aug 12, 2018 5:49 pm
This isn't 100% bash, but python comes on the pi so this should work on the pi & I have a check if python exists so it should not run on anything that does not have python! So hopefully this is pretty cross platform compatible! worked for me, ymmv.
# check if it is a raspberry pi, because we'll need a special ruby first
if [ -x "$(command -v python)" ] ; then
    R_PI=`python -c "import platform; print 'raspberrypi' in platform.uname()"`
    if [ "$R_PI" = "True" ] ; then
        # put your raspberry py code here, in my case I upgrade the ruby version:
        # run ruby upgrade script. source: https://gist.github.com/blacktm/8302741
        yes | bash <(curl -s https://gist.githubusercontent.com/blacktm/8302741/raw/install_ruby_rpi.sh)
    fi
fi
jahboater
Mon Aug 13, 2018 7:13 am
Slightly OT, but you might also be interested in:
/proc/device-tree/model
which provides the full model name as a NUL terminated string.
pi@Pi3:~ $ cat /proc/device-tree/model
Raspberry Pi 3 Model B Plus Rev 1.3
