Perl 5.8.3 or later and perl modules?
Posted: Mon Jan 28, 2013 4:17 am
by vector
does anybody know how I can get on my pi perl 5.8.3 or later and perl modules? :?
Re: Perl 5.8.3 or later and perl modules?
Posted: Mon Jan 28, 2013 4:48 am
by rpdom
You haven't said which Operating System version you are using.
If you have installed the Raspbian version, you should have perl and perl-modules 5.14 already installed.
You can check this in a terminal with "dpkg -l perl perl-modules" (That's a lower-case "L", not a capital "i" or number "1")
My system reports
pi@raspi:~$ dpkg -l perl perl-modules
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name               Version        Architecture   Description
ii  perl               5.14.2-16+rpi1 armhf          Larry Wall's Practical Extraction and Rep
ii  perl-modules       5.14.2-16+rpi1 all            Core Perl modules
pi@raspi:~$
Posted: Tue Jan 29, 2013 1:15 am
by vector
What about Perl 5.8.3 higher?
Posted: Tue Jan 29, 2013 3:19 am
by jojopi
In case it is not obvious, five.fourteen.two is higher than five.eight.three. In fact, 5.8.3 is a rather old version, released in January 2004.
Perhaps it would be better to explain what you are trying to do, and how it is not working.
Posted: Sun Feb 10, 2013 4:26 am
by technion
vector wrote:What about Perl 5.8.3 higher?
The CentOS 5 (with their reputation of being behind versions on everything) server I built roughly two years ago is running a more recent version than that. You would struggle to find something lower.
