Re: The Rust debate.
Thu Oct 03, 2019 10:48 am
John_Spikowski,
Portability is also a trait of C I enjoy.
Portability is very important to me as well. I don't want to even think about a language/language system that is not cross platform.
Which is why Rust is on my Radar, it's a fairly new language to the scene but it can already build code on and for a huge range of architectures and platforms: https://forge.rust-lang.org/release/pla ... pport.html
All the way from top end Intel servers down to tiny micro-controllers like the 16-bit MSP430.https://forge.rust-lang.org/release/pla ... pport.html
Which is to be expected as Rust gets the cross-platform capability from using the LLVM back end.
sal55
Thu Oct 03, 2019 11:29 am
John_Spikowski,
Supporting odd architectures is part of the reason C's type system is such a mess. It cannot even commit itself to the number of bits in a 'char' (or whether it is signed or unsigned); or whether 'long' is 32 or 64 bits, and is compatible with 'int' or 'long long int', or neither; or whether 'int' is 16 bits, or 32, or something else entirely; or whether 'uint32_t' is defined on top of 'unsigned int' or 'unsigned long' or something else, or even if it has 32 bits. Anyway, you get the idea!
Whereas more modern languages that have ranges of fixed-width types have standardised on widths of 8, 16, 32 and 64 bits, including Rust.
That MSP device may just fit into that scheme, but odder ones might not.
(Note that LLVM itself allows any integer bit-widths even up to 8388608 bits wide (2**23). I'm not sure how that works out in actual code.)
John_Spikowski
Thu Oct 03, 2019 11:41 am
ScriptBasic (ANSI C) ported to 64 bit and ARM with nothing more than a gcc command line addition.
jahboater
Thu Oct 03, 2019 11:42 am
Whereas more modern languages that have ranges of fixed-width types have standardized on widths of 8, 16, 32 and 64 bits, including Rust.
Precisely what C did 20 years ago ...
C99 introduced exact width types and others such as int_fast and int_least.
Forget about what they may map onto, it is of no interest to the programmer.
(sure int64_t may be slow on a 32-bit platform, but it works perfectly. There is no need for the code to be aware.)
CHAR_BIT is fixed at 8 (when did you last see a computer with 6 or 9 bit bytes?)
Yes the older types such as long may change between 32 and 64 bit platforms, which is sometimes useful.
PeterO
Thu Oct 03, 2019 11:47 am
#include <sdtint.h>
int8_t  a;
PeterO
Thu Oct 03, 2019 11:48 am
John_Spikowski,
It's lucky Richard Stallman started GCC over 30 years ago and inspired people to spend thousands/millions of man hours on it to make that possible.
jahboater
Thu Oct 03, 2019 11:51 am
I think that's rather impressive.
I'd like to know what that command line option was ???
John_Spikowski
Thu Oct 03, 2019 11:59 am
I think Peter Verhas's design and unlimited expansion is an example of vision at its best.
plugwash
Thu Oct 03, 2019 12:00 pm
Unfortunately the C99 typedefs don't fully solve the problem because of C's boneheaded promotion and overflow rules, consider for example.
uint16_t a = 0xFFFF;
uint16_t b = 0xFFFF;
uint16_t c = a * b;
You might expect this code to be well-defined, after all arithmetic on unsigned types has well-defined wraparound semantics.
Unfortunately promotion steps in to mess things up. If int is 16 bits or less then no promotion happens and the code is well-defined. If int is more than 32 bits then promotion happens, but is harmless. However if int is 32 bits then this code has undefined behaviour.
John_Spikowski
Thu Oct 03, 2019 12:15 pm
PRINT FORMAT("%0.f",0xFFFF * 0xFFFF),"\n"
pi@RPi4B:~/sbrt/examples $ scriba 32math.sb
4294836225
What are you expecting as a result?
sal55
Thu Oct 03, 2019 12:20 pm
They may have introduced them, but nobody uses them! At least, they seem to be rare in open-source code I've looked at.
This is it, they may map to the poorly defined char, short, int, long, long long (notice FIVE types which normally represent FOUR sizes of 8, 16, 32, 64).
'uint64_t' might map to 'unsigned long long int' on Windows, or 'unsigned long int' on Linux. This is important if you want to know whether to use "%lu" or "%llu" when printing its value (or you have to use PRi64d or whatever). It is little help when trying to call 'sprintf' as a foreign function from another language.
It's also important when your code, for example, might use int64_t*, but you want to call a library function that needs 'long int*' or 'long long int*. It's still a mess!
CHAR_BIT is at least 8 bits; POSIX implementations mandate 8 bits. But there are still special processors that don't have an 8-bit byte, so it either needs emulating, or CHAR_BIT for that device will be 16 or 24 or 32 or 37.
When is that? I've just glanced at the ScriptBasic sources (it was mentioned a few posts above) and they seem to use 'long' extensively. Which means that when long is 64 bits, and the hardware is 32 bits, it will now be wasting time doing unnecessary 64-bit ops. (And if it expects long to be 64 bits, it will fail when it's only 32.)
PeterO
Thu Oct 03, 2019 12:28 pm
And with opinion stated as fact you loose all credibility I'm afraid !
PeterO
jahboater
Thu Oct 03, 2019 12:36 pm
No.
On all the platforms around here, sizeof(long) == sizeof(char*)
So in 32-bit mode, long is 32-bits. Try it on the Pi.
In 64-bit mode, long is 64-bits. Try it on your Intel PC or the Pi with Gentoo
There is no hard guarantee however, so use the exact width types.
"long" is best avoided in general. Its a bit easier to read than ptrdiff_t when you are subtracting pointers (you cannot use int of course). But that's about all I can think of.
Thu Oct 03, 2019 12:44 pm
About 14 years ago when I was working on one.
jahboater
Thu Oct 03, 2019 2:10 pm
Yes, that's what I thought.
And its near 40 years since I used a machine without 8 bit bytes.
:) I am sure Peter O has some working computers in his museum with some other sizes :)
On a related note, I believe there are no longer any known computers where the integer arithmetic is not twos-complement. C++14 and the forthcoming C2x say that signed integer overflow is now a defined operation.
Like your 37-bit bytes, I shan't worry about making my code portable to sign-magnitude or ones complement hardware!
sal55
Thu Oct 03, 2019 2:15 pm
PeterO
And you snipped the bit where I qualified that remark. But if I google for "C tutorials", then the first hit doesn't mention those "int32_t" types, only the usual char, short, int, long. Neither did the 2nd. Or the 3rd. Or the 4th. Or a random 5th link.
With the few open source C projects on my PC, Lua doesn't use them (but tries to be c89 compatible); neither does Tiny C; Python mainly does (but also a mix of ordinary types, plus its own types); Sqlite3 (250Kloc) doesn't; the stb_image library mainly doesn't, especially for its API.
My point was, there is a considerable amount of C code and headers and APIs that doesn't use the stdint.h types, and it is necessary to deal with that. Partly that was because many projects used their own schemes to get around lack of those standards (even though stdint.h is at least 20 years old). The fact remains that you will come across int and long and int32_t - will int32_t* be compatible with int* or long*?
(ETA: this still leaves the print-format problem unresolved, especially calling printf-family functions from another language. What format code to use for your genuine (ie. not bolted-on to int or long) int32 and int64 types?)
sal55
Thu Oct 03, 2019 2:30 pm
No.
I've avoided dealing with 'long' for years. But some tests (on the same PC) gives the following for sizeof(long):
         32-bit  64-bit
Linux    4       8
Windows  4       4
So the size changes between 32-bit and 64-bit Linux; and between Windows and 64-bit Linux.
This doesn't change my point that if 'long' in that ScriptBasic app didn't need to be 64 bits, then it will be so unnecessarily on a 64-bit Linux.
There is still the risk of coming across a library that takes 'long*', although just a plain 'long' can also be a problem.
jahboater
Thu Oct 03, 2019 2:40 pm
Sal55,
The common memory model for 64-bits is LP64 - that is Longs and Pointers are 64-bits.
For 32-bit mode, the memory model should be ILP32 that is Integers, Longs and Pointers are all 32-bits.
Windows uses LLP64 which is Long Long and Pointers are 64-bits
Long remains 32-bits the same as int. Pretty daft but its a Windows issue from long ago (because they had a very commonly used #define from the 32-bit days). I am sure int64_t etc work as expected for Windows.
Linux sensibly does the right thing and uses LP64.
If this sort of thing is important for you then the compiler defines __LP64__ when its in effect.
jahboater
Thu Oct 03, 2019 2:52 pm
plugwash,
I thought that was to accommodate processors which cannot do arithmetic on types smaller than int - like the Pi's ARM CPU's. The Pi can load a byte or half word (16 bits) with ldrb or ldrh, but after that, arithmetic is done with full 32-bit wide registers. Just like the C promotion model.
Not needed on x86 of course than can fully do arithmetic on 8 or 16 bit registers, including setting the flags correctly.
However if int is 32 bits then this code has undefined behavior.
I thought all unsigned arithmetic was defined. I don't have my copy of C18 to hand which has a definitive list of all the undefined behaviors in C.
jahboater
Thu Oct 03, 2019 3:01 pm
Sal55,
You also have the problem of 64-bit literals.
In 64-bit modes the suffix is L, whereas on 32 bit mode, and Windows, its probably LL
In C of course its never an issue. For a 64-bit literal, just use INT64_C(123456789) and it will always be correct.
I can see your point about calling printf from another language.
Not something I have done, its easier to write everything in C.
Or I suppose any sensible host language will have decent formatted printing, why do you have to call C?
plugwash
Thu Oct 03, 2019 3:06 pm
The problem is if int is larger than 16 bits then the code snippet isn't unsigned arithmetic, it's conversion to int, followed by signed arithmetic, followed by conversion back to uint16_t .
jahboater
Thu Oct 03, 2019 3:27 pm
OK, if the original operand fits in a signed int then that's what it is promoted to.
Even though it would also fit in an unsigned int which would be more sensible!
It wont be undefined behavior for very long. Two's complement is now deemed to be universal.
Thu Oct 03, 2019 3:38 pm
This discussion of what C does where makes me think that the Rust folks have got a good idea!
It underlies the fact that a group of people cannot create bug free C code. Most of them only have a vague idea how it works, if they do it's so easy to make mistakes or miss those UBs. That's before we even start thinking about memory and thread safety.
Don't get me wrong, I love C, warts and all. Even if it is more of a random number generator than a high level programming language. For all kind of reasons I won't go into just yet.
Is it time for a "C Debate" thread?
Aside: I'm not sure of course but surely the fact that 16 bit ints get promoted to 32 bit whilst doing the arithmetic has no effect on the final result. I would expect that promotion to be unobservable. Or are you really saying that according to the standard that 16 bit by 16 bit multiply with 16 bit result does not have to produce the correct result? Is it really UB?
Thu Oct 03, 2019 4:05 pm
C has been referred to as "portable assembler" and such for as long as I can remember. Which is longer than I can remember, err, if you see what I mean.
I hold that up as praise rather than damnation. I think C is perfect for what it is supposed to be. No more no less.
paddyg
Thu Oct 03, 2019 5:01 pm
Anyway. Returning to the subject of this thread: after pondering why Rust bundles so much into its executables I read this post which gives a good justification (to avoid dependency issues etc) and also what to do if you really need to make it smaller. By adding additional flags to the cargo command the file drops from 2.5MB to 15k (10k after strip)
Compiling very large files is still going to be an issue and take a long time, and I think compile time is a problem generally for Rust, that the community is aware of and is trying to improve. (@sal55 I noticed nim on your comparison sheet - have you done anything serious with that?)
