norc89
.NET No SDKs were found
Mon Jul 08, 2019 12:59 pm
I'm having trobles with correct configuration for dotnet. I need a help from someone who have experience with rasbian. Can someone tell me the correct command to add sdk to PATHs.
dobova86
Re: .NET No SDKs were found
Mon Jul 15, 2019 1:51 pm
How you installed Net core?
I install it normally in /opt
sudo mkdir -p /opt/dotnet
sudo tar zxf dotnet-sdk*.tar.gz -C /opt/dotnet
sudo ln -s /opt/dotnet/dotnet /usr/local/bin
Then I set the environment var in .bashrc:
export DOTNET_ROOT=/opt/dotnet
I've no problem with this setup for .NET and ASP.NET on Raspbian.
I'm now facing a SQL Server client (Sql.Data.SqlClient) problem on Pi4 Buster, locking inside the sqlconn.Open() call. I will try to figure out why.
John_Spikowski
Mon Jul 15, 2019 5:46 pm
.NET on Rasbian is about as ugly as Ruby.
