imjustchew
74hc595n NodeJS help
Mon Feb 04, 2019 4:26 am
I'm trying to control the 74hc595n using NodeJS OnOff Library. I found an old topic here :https://www.raspberrypi.org/forums/view ... p?t=118962 but the code doesn't fully work, It does its pattern for a few bits then it goes haywire and turns off all the pins then a few seconds later works again.
I've tried hooking it up to an Arduino to test it and it does work there.
Any help is appreciated.
