EinSoldiatGott
MariaDB is not asking for root Password
Sun Sep 30, 2018 12:50 pm
I'm using Raspbian GNU/Linux 9 (stretch) with 10.1.23-MariaDB-9+deb9u1 Raspbian 9.0
My problem is that when I run:
pi@raspberrypi:~ $ sudo mysql -u root
It enters to MariaDB without asking for a password and I need to avoid this.
Welcome to the MariaDB monitor.
Commands end with; or \g. Your MariaDB connection id is 20
Server version: 10.1.23-MariaDB-9+deb9u1 Raspbian 9.0
Copyright (c) 2000, 2017, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]>
I've tried with:
sudo mysql_secure_installation
SET PASSWORD FOR 'root'@'localhost' = PASSWORD('thepass');
But it didn't work
I'm using the raspberry to auto-execute a python script when it boots, this phyton script requires root privileges, so I run it with "sudo", then I don't want to force the system to ask for root password for all the commands, the only thing I'd want is MariaDB to ask for root password to access the database.
DirkS
Re: MariaDB is not asking for root Password
Sun Sep 30, 2018 1:05 pm
Does https://www.raspberrypi.org/forums/view ... p?t=193426 help (see last post in that topic)
EinSoldiatGott
Sat Oct 06, 2018 4:26 pm
Thanks, it worked!!!
