harzsr
Send Hex Value to Serial from PHP
Thu Sep 06, 2018 2:18 am
I am using PHP to execute some Output commands through Terminal to Serial Output
Its basically a button click and it executes this line
Terminal
echo -e "\x02\x03\x08\x01\x09" > /dev/ttyAMA0
PHP Code
echo exec("echo "\x02\x03\x08\x01\x09" > /dev/ttyAMA0");
Output
02 03 08 01 09 0D 0A
The problem comes when I try to send 0A in the command
Both Terminal and PHP when executed
Terminal
echo -e "\x02\x03\x09\x01\x0A" > /dev/ttyAMA0
PHP Code
echo exec("echo "\x02\x03\x09\x01\x0A" > /dev/ttyAMA0");
Output
02 03 09 01 0D 0A 0D 0A
I am not sure, why when I execute 0A it adds a 0D in between 01 and 0A. I know 0A is Line Feed and 0D is Carriage Return.
Is there any way to output only 0A without that 0D
Thank you
topguy
Re: Send Hex Value to Serial from PHP
Sun Sep 09, 2018 11:52 am
You dont have the "-e" echo option in the PHP code.
I use "-en" option for these things, then it should not add any line-ensds and you can control that yourself.
If you learn have to work with bytearrays directly in PHP you could just open ttyACM0 directly and write to it.
https://blog-en.openalfa.com/how-to-wor ... ata-in-php ( a bit old guide but maybe still helpful )
