depauw
network status script: synthax error
Wed Jan 11, 2017 4:34 pm
Hello there,
I've written a script to check if my pi has an internetconnection by pinging Google.
If not, it checks what type of connection I have (wifi and/or ethernet).
It restarts them 5 times.
If there is still no connection, the a reboot is executed.
When I run the code, I get a synthax error: synthax error, unexpected symbol 'done'
#!/bin/bash
for i in {1..5}
do
   echo "Test nr $i"
   ping -c4 8.8.8.8 > /dev/null
   if [ $? != 0 ]
   then
     echo "test connection type: wlan0 or eth0"
     ifconfig wlan0 | grep -i "inet addr:" | wc -l
     if [ $? != 0 ]
     then
        echo "wlan0 connection detected"
        if [ $i -lt 5 ]
        then
          echo "No internet connection, restarting wlan0"
          ifconfig wlan0 down
          sleep 5
          ifconfig wlan0 up
     else
        ifconfig eth0 | grep -i "inet addr:" | wc -l
        if [ $? != 0 ]
        then
           echo "eth0 connection detected"
           if [ $i -lt 5 ]
           then
              echo "No internet connection, restarting eth0"
              ifconfig eth0 down
              sleep 5
              ifconfig eth0 up
     else
       echo "No network connection, reboot"
       sleep 5
       sudo /sbin/shutdown -r now
     fi
   else
      echo "Connection ok!"
   fi
done
I hope someone can point me to what I'm doing wrong!
greetings,
Christophe
PeterO
Re: network status script: synthax error
Wed Jan 11, 2017 4:41 pm
At a first look you are missing some "fi"s
Five x "if" but only Two x "fi"
Looks at the examples http://www.tldp.org/LDP/abs/html/testconstructs.html
PeterO
B.Goode
Wed Jan 11, 2017 5:44 pm
In addition to what @PeterO has said -
This query has erroneously been posted in the Python sub-forum. (That itself is trivial and can be rectified.)
But if you are familiar with Python note that programming constructs like loops and conditionals in Shell script use specific keywords like done to terminate the loop, they do not rely on left hand indentation (which you have used a lot in a python-intro style.)
Just curious whether you might have made that assumption that has led to the if statements not being terminated?
The reference provided should make this clear.
Edit: a Moderator has now relocated this discussion to an appropriate sub-forum
depauw
Wed Jan 25, 2017 2:47 pm
Hey, sorry for the delay. Dayjob got a bit in the way
Thanks for the pointers and the links.
I started this script out as a python script, but then made a bash script of it. This explains a bit why there's a lot of python in it.
I've done some reading an googling and took another approach to my script.
The goal is still the same:
- check if there is an internetconnection (ping google)
- see what type of connection there is (wlan and/or ethernet)
- restart the active adaptor.
- if no result after 3 attempts: reboot
So, I've come up with this.
Something must be wrong, because I'm not getting the results I'm expecting.
You'll see there's a lot of 'echo' in the script (for debugging purpose) and there are no active commands in it. That is for later ;)
Really appreciate your help!!!
#!/bin/bash
wlan=$(ifconfig wlan0 | grep -i "inet addr:" | wc -l)
echo $wlan
eth=$(ifconfig eth0 | grep -i "inet addr:" | wc -l)
echo $eth
for i in {1..3}
do
        echo "test $i"
        ping -c4 7.8.8.8 > /dev/null
        echo $?
        if [ $? != 1 ]
        then
                echo "connection ok"
        elif [ $? != 0 ] && [ $wlan != 0 ]
        then
                echo "no connection, wlan detected. Restarting wlan adaptor"
        elif [ $? != 0 ] && [ $eth != 0 ]
        then
                echo "no connection, eth detected. Restarting eth adaptor"
        fi
done
echo "last check before reboot"
echo $?
if [ $? != 0 ]
then
        echo "reboot"
fi
B.Goode
Wed Jan 25, 2017 3:17 pm
Give us a clue...
What results do you get? How does that differ from what you were expecting?
depauw
Thu Jan 26, 2017 10:32 am
Did some editing to the posted code, it was a wrong version.
These are the results I get:
1
1
test 1
1
connection ok
test 2
1
connection ok
test 3
1
connection ok
1
I was not expecting to get a connection ok. It should be a no connection, first on wlan with restart and then on eth with restart.
maybe something is wrong with the way i'm storing the result of the ping test?
shuckle
Thu Jan 26, 2017 12:07 pm
$? is the status of the last command.
After
echo $?
it shows the status of echo, which is pretty often 0.
depauw
Sun Jan 29, 2017 6:52 pm
ok!
Now, I want to write the result of the ping test (0 or 1) into a variable.
I've tried this: png=$(ping -c4 7.8.8.8 > /dev/null)
but when I do 'echo $png' the output is nothing, of blank.
any idea's on this?
kind regards,
Christophe
shuckle
Sun Jan 29, 2017 7:21 pm
png=$?
depauw
Sun Feb 05, 2017 7:44 pm
@ shuckle: thanks for that! :oops:
really embarressed I didn't found this on my own.....
Back on track now!
I'll publish the finished code within the next few days, if the dayjob doesn't have to many surprises :o
Christophe
stderr
Sun Feb 05, 2017 9:24 pm
depauw wrote: I've tried this: png=$(ping -c4 7.8.8.8 > /dev/null)
any idea's on this?
I know you've got an answer but there are two issues, one is that the google server is at 8.8.8.8 so that will fail after some time and won't test if your connection is actually up.
But the reason you are getting a blank back in your variable is because of the /dev/null . Even if you really just wanted the success/failure value and didn't care to parse out, say, the time the ping took, it makes sense I think to not put in the > /dev/null until you have things at least working up to that point. Without that null dump, you'd have got the output in the variable or right out on the screen and then immediately realised the trouble.
depauw
Mon Feb 06, 2017 10:06 am
I used 7.8.8.8 for testing purposes so I could simulate the situation of no connection.
In the final script (below) I'm using 8.8.8.8
So here is my result:
- first check: is there connection with internet
- second check: what kind of connection: wifi or ethernet
- depending on the type of connection: the appropriate adapter is reset, 3 attempts are made
- if connection is not restored: a reboot is done
#!/bin/bash
ip='8.8.8.8' #ip you want to ping for connection. 8.8.8.8 is google
echo $wlan #0 means no wifi
echo $eth #0 means no ethernet
for i in {1..4}
do
        echo "test $i"
        ping -c4 $ip > /dev/null
	png=$?
        echo $png
        if [ $png = 0 ] && [ $i -le 3 ]
        then
		break #there is no need to do more tests when the connection is ok
        elif [ $png != 0 ] && [ $wlan != 0 ] && [ $i -le 3 ]
        then
		ifconfig wlan0 down
          	sleep 5
          	ifconfig wlan0 up
	elif [ $png != 0 ] && [ $eth != 0 ] && [ $i -le 3 ]
        then
		ifconfig eth0 down
              	sleep 5
              	ifconfig eth0 up
	elif [ $png != 0 ] && [ $i -eq 4 ]
        then
               	echo "no connection at all: reboot"
		sleep 5
        fi
done
I'd like to thank everyone who helped me out and pointed me to some very helpfull resources!
This has been a great learning experience, where I started out with a Python script with a lot of nested if/then and landed with a bash script with variables and nested condition tests.
