gnrcampos
Java+MySql
Tue Aug 28, 2012 10:51 pm
First of all I would like to thanks everyone that is reading this thread. I've received my RPi a week ago, and since then I've been trying to build a Java application that will access a MYSQL database. Before the arrive of the RPi I had started the project on my Windows 7 computer but when I try to run it on the RPi I get this error:
java.sql.SQLException: No suitable driver found for jdbc:mysql://localhost/mydb
The code line that triggers this error is:
Connection v_Conn = DriverManager.getConnection("jdbc:mysql://localhost/mydb",p_User,p_Pwd);
I've been trying to find the JDBC suitable for this without success and it would be of great help if anyone could enlighten me on that.
ps: I'm using the 2012-08-16-wheezy-raspbian image and Mysql server version 5.5.24-7.
gnrcampos
Re: Java+MySql
Tue Aug 28, 2012 11:59 pm
It's quite impressive how fast things can solve itselves when you ask for help. I discovered that I had to use the "Export -> Runnable JAR File", not the "Export -> JAR File". Thanks anyway.
