timurlenk
Need Help - Java into machine code
Mon Aug 27, 2012 8:43 am
I am trying to host a Minecraft server on the RPi using as less resources as possible. Right now I want to compile the Minecraft server source code, which I decompiled using MCP, into machine code. I read I could use gcj for it which is supposed to be integrated into gcc, but I have gcc (version 4.6.3-8+rpi1) and I don't have gcj as far as I can tell. How can I get gcj and what am I supposed to do afterwards?
joan
Re: Need Help - Java into machine code
Mon Aug 27, 2012 9:11 am
To install a package try
sudo apt-get install package-name
In your case try
sudo apt-get install gcj
I don't know how you'd use it for Minecraft. Does the article which referenced gcj give no idea?
p.s. if you are not sure of a package's name try
sudo apt-cache search some-letters-of-package-name
to give a list of likely candidates.
xranby
Mon Aug 27, 2012 1:56 pm
The correct way to use GCJ:
#First install gcj and ecj
sudo apt-get install gcj-jdk
#example 1: compile a HelloWorld with a known main class
gcj -o hello HelloWorld.java --main=HelloWorld
#then run the binary
./hello
#example 2: compile a standalone Java .jar or .class with a known main class
wget http://math.nist.gov/scimark2/scimark2lib.jar
gcj -o scimark2 scimark2lib.jar --main=jnt.scimark2.commandline
./scimark2
# complexity increases when you try to compile a .jar that in turn depend on other jars.
# i here use -findirect-dispatch to allow the compilation to continue in situations
# when the craftbukkit.jar contains references to classes in external jars, like ant and lucene,
# that can not be found at compiletime.
# If you have a lot of memory and then you should be able to compile the bukkit minecraft server
# by running the following:
gcj -findirect-dispatch craftbukkit.jar -o craftbukkit --main=org.bukkit.craftbukkit.Main
# unfortunately the raspberry pi do not have enough RAM to
# complete the static compilation of this large server application.
The complete manual to gcj is found here:
http://gcc.gnu.org/onlinedocs/gcj/
good luck!
Xerxes Rånby @xranby I once had two, then I gave one away. Now both are in use every day!
twitter.com/xranby
timurlenk
Mon Aug 27, 2012 5:07 pm
I did check the GNJ manual before but I didn't understand much from it so I didn't know where to look, but your post explains everything I need.
Thanks a lot!
