jvalencia
[code] BME280 Linux library for Ruby
Mon Aug 15, 2016 9:00 pm
I've made my own library for this sensor on Ruby. It's a stand-alone library, it doesn't need any other gems to work.
The code is available here:
Re: Reading BME280 sensor with Ruby
Tue Aug 16, 2016 12:22 am
So where is it? Whatever it is.
jvalencia
Tue Aug 16, 2016 7:52 am
Heater wrote:So where is it? Whatever it is.
I've updated the first post with the source code.
yuasatakayuki
Sat Aug 20, 2016 11:52 am
Thanks jvalencia for sharing these useful scripts. :D
I confirmed that these script work properly with my Raspberry Pi 3 and a BME280 module as pasted below.
If possible, I would love to use these scripts in my non-commercial personal project, and which license should I apply when including these files into my code tree? It would be very much appreciated if it is MIT/BSD or similar open-source license.
Cheers,
$ ruby sample_bme280.rb
Temperature: 29.93 ºC
Pressure: 1003.34 mb
Humidity: 48.34 %
jvalencia
Tue Aug 23, 2016 12:17 pm
yuasatakayuki wrote:Thanks jvalencia for sharing these useful scripts. :D
Cheers,
Humidity: 48.34 %
Hi, good to know that it works for you ;) I've updated the scripts with the BSD license. Happy hacking.
yuasatakayuki
Re: [code] BME280 library for Ruby
Sat Aug 27, 2016 7:44 am
Thanks for updating the code with the license. It's very much appreciated! :D
Miyamoto
Fri May 11, 2018 2:01 pm
All links unavailable...so sad
jvalencia
Fri May 11, 2018 5:49 pm
Hello friend, I messed my github once. I've updated the top post with good links again.
sardar
Re: [code] BME280 Linux library for Ruby
Tue May 15, 2018 3:31 am
Thank you very much for your update. I can measure "temperature" "Pressure" and "humidity" but how can I send this data from my home to my office pc?
