Timco
Rails + Javascript
Wed Aug 08, 2012 9:30 pm
Hi all,
I'm just starting with my fantastic RaspberryPi.
I've managed to install successfully Rails but ..
I can't install therubyracer, nor libv8 (error with "Target architecture ia32")
Is anyone working with rubyracer here ? How can I install it ?
Danny72
Re: Rails + Javascript
Fri Aug 17, 2012 11:48 pm
The current build isn't setup for ARM.
https://github.com/cowboyd/therubyracer/issues/186
Until the implementation is fixed, you can get around it using another javascript package like Node.js
oniram
Thu Aug 23, 2012 1:49 pm
how can i make this: "Until the implementation is fixed, you can get around it using another javascript package like Node.js"
mellett68
Tue Aug 28, 2012 8:52 pm
Depends on your OS, but for Ubuntu (so probably Debian too) you can simply
sudo apt-get install nodejs
You don't need anything specific in your Gemfile. (At least, I never put anything in mine)
There's also a nodejs package for Arch, so
Pacman -S nodejs
